		RV7ASask
				 Posted: Tue Nov 15, 2011 2:46 pm    Post subject: Canopy Open |
				My RV7A, after nearly nine years, is just about ready to fly. I have been taxiing around and managed to iron out a couple of small bugs. The only big hurdle left is the final inspection. I think I have all the paperwork in order but there is one conundrum.
 An old boss once told me if you copy someone’s work it is plagiarism; if you use more than one source it is research. I have done extensive research and with my own input have come up with “Normal Operating Checklists” (one page two sides), “Emergency Checklists” (two pages totaling 3 sides) and a “Pilot’s Operating Handbook” (now at 100+ pages and growing).
 In my “Emergency Checklists” I have three occasions; for “CARBON MONOXIDE FUMES”, CABIN SMOKE REMOVAL” and “DITCHING”, where I have stated either “Canopy.... Unlatch” or “Canopy.... Slightly Open”. Then, I added a “WARNING... Unlatching the canopy in flight may result in separation of the canopy from the aircraft”.
 What do we know about flying an RV6, RV7 or RV9 with the canopy open? Has anyone ever done this? Has anyone ever intentionally opened the canopy in flight? Has anyone ever had a canopy separation from the aircraft? This is again just part of the research.
 David Lamb
 RV7A
 C-FLAM – almost ready to fly
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		franz(at)lastfrontierheli Guest
				 Posted: Tue Nov 15, 2011 3:42 pm    Post subject: Canopy Open |
				I assume that you are talking about a slider. I had mine open up once just
 after take off, due to me not following the checklist. It opened up about
 15cm and then stopped. I could close it with one hand, after stabilizing the
 aircraft in cruise flight. On the other hand we had a crash of an RV9 at a
 neighboring field due to the same oversight, details not known to me
 Cheers
 Franz
 RV7A 600h
 On 15/11/11 2:46 PM, "RV7ASask" <rv7alamb(at)sasktel.net> wrote:
  with my own input have come up with “Normal Operating Checklists†(one
  page two sides), “Emergency Checklists†(two pages totaling 3 sides) and a
  “Pilot’s Operating Handbook†(now at 100+ pages and growing).
  In my “Emergency Checklists†I have three occasions; for “CARBON
  MONOXIDE FUMESâ€, CABIN SMOKE REMOVAL†and “DITCHINGâ€, where I have
  stated either “Canopy.... Unlatch†or “Canopy.... Slightly Openâ€.
  separation of the canopy from the aircraftâ€.
  David Lamb
  RV7A
  http://forums.matronics.com/viewtopic.php?p=358061#358061
				 Posted: Tue Nov 15, 2011 3:55 pm    Post subject: Canopy Open |
				On 11/15/2011 4:46 PM, RV7ASask wrote:
  David Lamb
  RV7A
 I don't think you will have any major issues (except underwear
 laundering) with either the tipup or slider. Sliders will typically open
 a few inches & you can't force them any farther open while at normal
 speeds. Tipups will rise a few inches in the rear (no more) & can't be
 pulled closed unless you slow down a lot & deploy the flaps.
 I've seen some forum chatter supporting my slider statement, but I can't
 point you to any slider references (checking with Van's is always the
 best policy on safety issues anyway). A friend has tested the tipup
 (can't remember if it was a 6A or 9A; he's built both). He got the
 results detailed above.
 The -4 with tipover is another matter entirely. If the safety doesn't
 catch it, it will 'unzip' the hinge rivets. (This is a design feature to
 allow the canopy to depart if the occupants need to follow.)
 Hope that helps,
 Charlie
		RV7ASask
				 Posted: Tue Nov 15, 2011 6:09 pm    Post subject: Re: Canopy Open |
				Thanks for the comments. My 7A is a slider.
 David
