phactor9
Posted: Wed Nov 16, 2011 12:32 pm Post subject: Where to buy two stroke oil? |
Next topic: What oil do you use, why, and where can you get quantities, and at what price?
Castrol TTS cannot be found (discontinued).
My bike mechanic (Powersports Honda) recommended Amsoil hp injector ($35/gal) and Amsoil interceptor ($39/gal, higher temperature additives for "power valves"). I told him it wasn't for marine, snow or road transport but for an ultralight, and I wanted all the obvious qualities involved in feeding my two-stroke engine.
He said HE could no longer get Castrol TTS from either of his suppliers, either, and suggested Amsoil would be the best.
Phil H.
donaho1(at)verizon.net Guest
Posted: Wed Nov 16, 2011 1:49 pm Post subject: Where to buy two stroke oil? |
Check out Aeroshell II plus (I think that is what it is called). I
haven`t tried it yet, however, after reading about it, I plan to use
it next spring. N598LF At 03:28 PM 11/16/2011, you wrote:
| Quote: | Next topic: What oil do you use, why, and where can you get
Phil H.
<http://www.buildersbooks.com>www.buildersbooks.com
<http://www.matronics.com/contribution>http://www.matronics.com/contribution
<http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List
Posted: Wed Nov 16, 2011 2:24 pm Post subject: Where to buy two stroke oil? |
http://www.conocophillipslubricants.com/brands-products/Single.aspx?pid=39&b
rand=
That ought to fill the bill for Rotax air cooled engines.
That is as far as I looked.
_________________ John Hauck
Titus, Alabama |
clydemacquarrie(at)eastli Guest
Posted: Thu Nov 17, 2011 5:13 am Post subject: Where to buy two stroke oil? |
I found Castrol TTS at the local Wal-Mart here in Nova Scotia, Canada for $28.00 Plus taxes. Clyde MacQuarrie.
Sent: Wednesday, November 16, 2011 8:30 PM
Subject: Re: Where to buy two stroke oil?
"Two stroke AeroShell Oil Sport Plus 2 is the first aviation quality oil that has been specifically developed for Light Sport, Very Light and Ultralight 2-stroke engines such as the ROTAX® air and water-cooled series engines." http://www.shell.com/home/content/aviation/products/lubricants/piston_engine_oils/sports_plus2/
Rick Girard
On Wed, Nov 16, 2011 at 2:28 PM, Phil <phactor9(at)yahoo.com (phactor9(at)yahoo.com)> wrote:
| Quote: | Next topic: What oil do you use, why, and where can you get quantities, and at what price?
Phil H.
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
gyrodude
Joined: 15 Nov 2011 Posts: 16 Location: Stanfield N.C.
Posted: Fri Nov 18, 2011 6:41 am Post subject: Re: Where to buy two stroke oil? |
I had a friend that worked in the lab at Homelite. They tested all the oils on the market at the time. Texaco Havoline with Royalgard won. Any good quality organic oil is fine as long as it contains a TCW-3 which is a rust inhibitor. Do the Amsoil products contain a rust inhibitor? I've flown behind Rotaxes for over 25yrs now with no oil related problems.
flyingfischead
flypoker(at)windstream.ne Guest
Posted: Fri Nov 25, 2011 3:44 am Post subject: Where to buy two stroke oil? |
I used to buy stuff from Danny Day. I haven't heard anything from him in a
few years or any advertisements in several years. I don't know if he is
still around.
Jerry
GeoB
Posted: Sat Nov 26, 2011 1:21 am Post subject: Where to buy two stroke oil? |
A quick search reveals an old 2007 post;
Colorado Unlimited Adventure Corp.
P.O. box 100 Tumacacori, AZ. 85640 (520)398-8311
CUA-101 Engine Lubricant 1-GAL 43$
I haven't tried it to see if it works.
GeoB
_________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
jim.baker(at)windstream.n Guest
Posted: Sat Nov 26, 2011 2:32 pm Post subject: Where to buy two stroke oil? |
The CUA 101 was, in fact, a repackaged product called Optimol, now
called Opti-2
http://www.opti2-4.com/html/opti-2.html
I've been running 100:1 using this product for over 450 hours, no
decarbon, no plug changes. Am I pushing this oil? No! I am, however,
an advocate of 100:1 oil for the reasons stated above. One of the
little known facts of "50:1" oils is that they are pre-cut with a
diluent, such as Stoddards Solvent, to aid in miscibility. Such
dilution renders the mix less than 50:1 right from the outset. Fact
is, unless you know precisely the amount of base stock and the other
constituents, your 50:1 estimation is strictly by volume and has
little relation to lubrication quantity.
Does that mean 50:1 oils are bad? Nope. All it means is that I prefer
something else. That's all it means......
To: <kolb-list(at)matronics.com>
Date sent: Sat, 26 Nov 2011 01:19:16 -0800
Send reply to: kolb-list(at)matronics.com
Jim Baker
Elmore City, OK
580.788.2779
405. 426.5377 cell
captainron1(at)cox.net Guest
Posted: Sun Nov 27, 2011 8:52 am Post subject: Where to buy two stroke oil? |
I know it ain't fancy and glamorous but I used the full synthetic 2 cycle oil from Walmart in my recent Cuyana adventure, and it was very smooth running and no plug fouling and inexpensive. Still have plenty left I was using it in 40 to 1 if I remember it right. Back in my Yamaha motorcycle 2 stroke days I used whatever cheap 2 cycle oil I could find mostly because I had no idea about one oil from another. Sometime in the 70's I switched over to synthetic oil and was surprised at the lack of smoke and the improved smoothness. Nowadays when the occasion arises I use only 2 stroke synthetic lube and am happy with it. I need to add I never had a 2 cycle motor failure,, ever!!!!
I think the Walmart brand is called Super Tech oil, I doubt we would find anything better at 3 times the price, and its probably down the street from all of us, excluding Pat; poor fellow no Walmart in Britannia.
Ron (at) KFHU
rand=
kugelair.com
flyingfischead
Posted: Mon Apr 16, 2012 12:12 pm Post subject: Re: Where to buy two stroke oil? |
I just heard from the guy that bought my NEIUPORT back in Sept. I had used CUA 101 2 stroke oil in the 503 since right after breakin. About 200 hrs. Plugs always looked good-never any problems. The new owner of my NIEUport decided to rebuild the engine just to get it back to 0 time. He told me last week the mechanic who did the job said the engine looked brand new inside with no detectable wear. It had to be the oil. I also used CUA 101 gear box additive with the regular gear lube and he also said the gearbox inside looked and checked out like new. Engine and gearbox - 20 years old with 225 hrs tt. I would still use it if I could find it. Going to be running a 447
Dennis Thate
Posted: Mon Apr 16, 2012 7:42 pm Post subject: Re: Where to buy two stroke oil? |
http://www.theultralightplace.com/choosing_oil.htm
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
Richard Pike
Posted: Tue Apr 17, 2012 5:23 am Post subject: Re: Where to buy two stroke oil? |
| Dennis Thate wrote: | | http://www.theultralightplace.com/choosing_oil.htm |
Excellent resource - thanks!
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
