Posted: Fri Nov 18, 2011 8:27 am Post subject: antenna connections |
Is there anything different about this type of antenna compared to
the one I'd suggested, outside of a streamlined base?
Probably. I didn't intend to suggest that antennas
made from aluminum are not practical. When you have
the engineering and purchasing options to optimize a
design to its intended purpose, then the product can
be pretty finely tuned with respect to trade-offs.
Metals are finicky things. A perfectly robust piece
of metal can become very fragile when scratched. Cutting
threads on a rod might be called "very deep scratches."
Disruptions of an otherwise smooth surface become local
stress risers that predict where a crack will start.
I'm not a processes and materials guy so my working
knowledge is limited to what 'rubbed off' while working
around folks who really good at it.
Given that I have no control over materials, processes and
target airframes, my recommendations have to be as
goof-proof as I can imagine. As long as your airplane isn't
a pusher, then there's no risk to the airframe for shedding
an antenna. If you're interested in crafting a recipe for
success and find the risks acceptable, then give it a try.
messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Fri Nov 18, 2011 9:02 am Post subject: Re: antenna connections |
Interesting. How wide and thick is this spiral wrap? What is the gap between one wrap and the next? And why don't we see this feature in airplane antennas? Where weight is the devil, seems saving an ounce would make it attractive to antenna makers.
_________________ Dan |
LynnCole(at)foxvalley.net Guest
Posted: Fri Nov 18, 2011 12:31 pm Post subject: antenna connections |
The antenna, itself tapers from about 0.175" at the base to about 0.100" at the tip. The wrap is quite thin - about 0.005-0.008" diameter, and the pitch of the spiral is about 1 inch. The wrap is solidly bonded to the antenna for its entire length. I suspect that it adds some drag to the antenna, but in the car the added drag would be very minor compared to the overall drag of the vehicle. It's a good question as to why we don't see such a wrap on aircraft antennae.
Lynn Cole
LynnCole(at)foxvalley.net (LynnCole(at)foxvalley.net)
On Nov 18, 2011, at 11:02 AM, messydeer wrote:
[quote]--> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com (messydeer(at)yahoo.com)>
Dan
http://forums.matronics.com/viewtopic.php?p=358381#358381
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts provided
by:
* AeroElectric www.aeroelectric.com
* The Builder's Bookstore www.buildersbooks.com
* HomebuiltHELP www.homebuilthelp.com
List Contribution Web Site:
--> http://www.matronics.com/contribution
Thank you for your generous support!
- The AeroElectric-List Email Forum -
--> http://www.matronics.com/Navigator?AeroElectric-List
- MATRONICS WEB FORUMS -
--> http://forums.matronics.com
- List Contribution Web Site -
Posted: Fri Nov 18, 2011 4:19 pm Post subject: antenna connections |
At 11:02 AM 11/18/2011, you wrote:
Adding the wrap is another process that adds to
cost of the finished product. If you can make the
critter survive without it, then perhaps you're
a few shekels ahead in the game. Then too, that
fix applies only to the phenomenon identified
as vortex shedding. There's turbulence in the
air behind a propeller that supplies yet another
vibration input.
Float Flyr
Several aviation antennae are actually embedded in fibreglass forms so you actually don’t see any of the actual antenna. On some composite planes the antennae are built in to either the wings or the tail leaving nothing exposed at all. Having worked with Scaled Composites, Bob must have a wealth of experience in that field..
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Lynn Cole
Sent: November 18, 2011 4:57 PM
Subject: Re: Re: antenna connections
Lynn Cole
Dan
by:
01234567890123456789012
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Nov 18, 2011 4:29 pm Post subject: antenna connections |
At 02:26 PM 11/18/2011, you wrote:
| Quote: | The antenna, itself tapers from about 0.175" at the base to about
aircraft antennae.
It's possible that the wrap we see on car antennas
has two purposes. The first being aerodynamic as
previously explored. The second may be that the wrap
is also a metallic conductor that serves as
the antenna supported on a Fiberglas rod.
Posted: Sat Nov 19, 2011 9:02 am Post subject: antenna connections |
A magnet sticks to the shaft of my car's antenna. Your idea of a metallic wrap on a fiberglass rod might save a little weight in an airplane.
Lynn Cole
On Nov 18, 2011, at 6:26 PM, Robert L. Nuckolls, III wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | The antenna, itself tapers from about 0.175" at the base to about 0.100" at the tip. The wrap is quite thin - about 0.005-0.008" diameter, and the pitch of the spiral is about 1 inch. The wrap is solidly bonded to the antenna for its entire length. I suspect that it adds some drag to the antenna, but in the car the added drag would be very minor compared to the overall drag of the vehicle. It's a good question as to why we don't see such a wrap on aircraft antennae.
by:
