AW: Aluminium Pipe for Fuel Inlet
hpreusser(at)vtxmail.ch
PostPosted: Mon Nov 28, 2011 9:52 am    Post subject: AW: Aluminium Pipe for Fuel Inlet Reply with quote
Hello Tim
Would like to have one too.
Regards Hans-Peter Reusser Kit # 498
Hans-Peter Reusser
Spiezbergstrasse 13
CH-3700 Spiez
Switzerland
T:  +41 33 654 00 24
M: +41 78 748 00 24
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Tim Ward
Gesendet: Sonntag, 27. November 2011 19:58
An: europa-list(at)matronics.com
Betreff: Aluminium Pipe for Fuel Inlet
Hi Europa Builders,
I have had a request for more Aluminium pipes for the fuel Inlet between the “cobra” and the fuel tank.
Are there any other builders interested in one?
See the attachment.
Cheers,
Mono Classic #292 ZK-TIM
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
PostPosted: Mon Nov 28, 2011 10:41 am    Post subject: AW: Aluminium Pipe for Fuel Inlet Reply with quote
Hello Hans Peter ,
That is fine. If you could send me a cheque (local is ok) for 45 Swiss francs and I will send it to you as soon as possible.
I have your address below so that is good.
Many thanks,
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 29/11/2011, at 6:48 AM, "hpreusser" <hpreusser(at)vtxmail.ch (hpreusser(at)vtxmail.ch)> wrote:
[quote] <![endif]--> <![endif]-->
Hello Tim
Hans-Peter Reusser
Spiezbergstrasse 13
CH-3700 Spiez
Switzerland
T: +41 33 654 00 24
M: +41 78 748 00 24
Von: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Tim Ward
An: europa-list(at)matronics.com (europa-list(at)matronics.com)
Betreff: Europa-List: Aluminium Pipe for Fuel Inlet
Hi Europa Builders,
See the attachment.
Cheers,
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
ctric.com
www.buildersbooks.com
uilthelp.com
matronics.com/contribution
tp://www.matronics.com/Navigator?Europa-List
cs.com
