user9253
Joined: 28 Mar 2008 Posts: 1932 Location: Riley TWP Michigan
Posted: Thu Dec 01, 2011 12:44 am Post subject: EFIS brownout capacitor |
Bob and all,
Is it feasible to provide brownout protection for an EFIS during engine cranking with a large electrolytic capacitor? A capacitor would not have to be replaced periodically and it might not weigh as much as a backup battery. Each brand of EFIS might have a different supply voltage requirement. But for this discussion, let's assume that 9 volts are required to prevent the EFIS from rebooting. How long is the battery voltage below 9 volts when starting the engine? The starter will draw the most current when it is first energized. Once the starter is rotating, back EMF will reduce the current draw. So for the first several milliseconds, the battery voltage will be at the lowest. If a large capacitor could support the EFIS voltage for one second, would that be long enough? If an EFIS draws 1 amp, what size capacitor would be required? Some EFISs have dedicated terminals for a backup battery. I assume that those EFISs have an internal diode to prevent discharge of the backup battery into the aircraft electrical system. Otherwise an external diode is needed.
Could a capacitor provide brownout protection? Or would it have to be so large as to make it impractical?
Joe
_________________ Joe Gores |
Posted: Thu Dec 01, 2011 6:59 am Post subject: EFIS brownout capacitor |
At 02:44 AM 12/1/2011, you wrote:
Bob and all,
Probably. It might even be as short as 250 milliseconds. See:
http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1_2.gif
http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1.jpg
http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_3.gif
http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_1.gif
The traces above were taken from the two vehicles
we were driving at the time. The Saturn has a PM
starter motor, the Safari has a wound field. The
larger depression of battery voltage in the Saturn
trace can be partially attributed to the the
greater inrush current for the PM motor.
diode is needed.
It's been done. Consider that the rate of change
across a capacitor is defined by V/S = A/F
1 Amp of charge (or discharge) on a 1 Farad
capacitor produces a voltage change rate
of 1 Volt per Second. Of course, few devices
draw a constant current as the voltage varies
so this relationship has a practical limitation
that falls apart for more than short durations.
Of course, that's what we're talking about.
Of the top of our head, we could estimate that
a capacitor charged to .7 volts below battery
voltage (12.5 - .7) = 11.8 volts. The goal is
to limit voltage drop to 2.8 volts over a .25
second interval
So, V/S = A/F
(V/S)F = A
F = AS/V = .25/2.8 = .09 Farads
There's an RC vs. V calculator at
http://www.bowdenshobbycircuits.info/rc.htm
which can be used to do the same math. In
this case, plug in some essentially constant
current combination, say 100 volts and 0.1K
ohms (1A). Then plug in time of 250mS and
voltage change of 2.8 volts. The tool calculates
88029.7978 microFarads or 0.088F.
Unfortunately, fat-caps don't come in the
range of incremental sizes as their smaller
cousins. Also, 16V ratings is in the realm
of high voltage for a super-cap. Here's a
device that would fit our hypothetical:
http://search.digikey.com/us/en/products/BZ12GA124ZAB/478-6281-ND/2506257
It's a 120 milliFarad device described in this
data sheet:
http://www.avx.com/docs/Catalogs/bestcap.pdf
This exercise suggests to the practicality of using
more 'active' forms of bus voltage regulation. If
I were writing specs for a modern EFIS system
where design goals called for improved immunity
to starter brownout, I'd call for the switchmode
power supply output to be stable down to 7 or 8
volts. Of course, input currents to the supply
would double during the brownout interval but
it's a short duration.
Bottom line is that its a lower cost of ownership
to design brown out protection into a device than
to paste it on outside.
I proposed a scheme to a customer some years
back where we explored the addition of a 3 volt,
DC to DC converter to be switched in as a bus
voltage booster during cranking times. The customer
tried it in the lab with positive results . . .
don't know if it ever went into production.
A 3v, 1A supply is an ittty-bitty critter compared
to a super-cap.
user9253
user9253
Posted: Thu Dec 01, 2011 9:41 am Post subject: Re: EFIS brownout capacitor |
When the master switch is turned on, would the inrush current to a 0.1F capacitor be a problem?
Thanks, Joe
Posted: Thu Dec 01, 2011 12:08 pm Post subject: EFIS brownout capacitor |
Thanks, Joe
Good question. If the cap is fed with say,
4' of 22AWG (16 mOhm/ft) then there is
potential for a 150+ Amp inrush. You might
want to consider some ballasting resistance
or perhaps an inrush limiter sized to your
operating loads.
Posted: Thu Dec 01, 2011 2:37 pm Post subject: EFIS brownout capacitor |
At 01:35 PM 12/1/2011, you wrote:
Quote: |
<nuckolls.bob(at)aeroelectric.com>
After some sifting through the gray matter archives, I retrieved
the core principals behind an active 'bus booster' that I
crafted some years back. Making this technology work for brown-out
protection would look something like this:
http://aeroelectric.com/Pictures/Schematics/Royer_Oscillator_Bus-Booster.pdf
I've used this style power oscillator in dozens of products.
It's designed around a saturable core transformer that operates
in the 1000-4000 Hz range. These are usually tape-wound toroidal
cores.
This particular implementation uses 'upside down PNP' power
transistors with grounded collectors. The assembly staff really
liked that . . . no insulating washers and grease!
This would be a DC-DC power supply that produces say 3.5 volts
for a 12 volt input. The instant the starter contactor is
energized, battery voltage applied to the protected device
is boosted to about 16.0 volts. When the starter inrush
hits, battery voltage drops to say 9 volts with a
proportional drop in boost level to about 2.4 volts
which is added to the 9 volts for a 'protected' output
of 11.4 or so.
When the starter is de-energized, the oscillator is
unpowered, boosting is replaced by normal bus power through
the upper, diode-isolated input. To handle a 1A load, output
power would be under 5 watts. This is a really small oscillator.
user9253
Posted: Fri Dec 02, 2011 6:57 am Post subject: Re: EFIS brownout capacitor |
Bob,
Thanks for the Bus-Booster circuit.
I was thinking that an inductor in series with an EFIS would limit the inrush current to a large capacitor. And when the main battery voltage dropped during cranking, that an inductor will try to maintain current flow to the EFIS while the capacitor tries to maintain the voltage. I do not know what size inductor is required. Inductors are heavy compared to capacitors. It is starting to look like a small backup battery is the easiest solution to brownout protection.
Joe
Posted: Fri Dec 02, 2011 11:57 am Post subject: EFIS brownout capacitor |
At 08:57 AM 12/2/2011, you wrote:
Quote: |
Bob,
An inductor would have that effect . . .
but on a scale of weight and volume that
would be exceedingly unattractive.
Yes, batteries are effective energy
storage devices when their weight and
volume are compared with other technologies.
The cost-of-ownership driver for standby batteries
is maintenance. What would be really cool is to
craft a cell technology that might offer a
fraction of the energy storage capability
for popular cells but high longevity numbers.
klehman(at)albedo.net Guest
Posted: Fri Dec 02, 2011 12:23 pm Post subject: EFIS brownout capacitor |
pretty hard to beat a couple of D cell flashlight batteries (and a mini
relay) for a couple of seconds of 1 amp 3 volt boost if that is still
the situation being discussed.
One could even leave the batteries in the flashlight so that it can be
used as a --- flashlight.
Ken
Posted: Sat Dec 03, 2011 5:15 am Post subject: EFIS brownout capacitor |
mini relay) for a couple of seconds of 1 amp 3 volt boost if that is
still the situation being discussed.
be used as a --- flashlight.
Absolutely! I can recall the use of alkaline
or ni-cad cells being suggested while mulling over
design options. I think zero-maintenance circuitry
consistently won out over the use of components
with a shelf or service life.
Of course, that was the T/C market which is driven
by different design goals.
