		pmdental(at)btinternet.co Guest
				 Posted: Sun Dec 04, 2011 10:37 am    Post subject: tufnol bearings |
				Hi Paul Munford again. Forgot to ask from prev'  message. Can you you grease/ lubricantsetc on tufnol ? any no - no's ? Thanks  again
		Rocketman
				 Posted: Sun Dec 04, 2011 11:28 am    Post subject: tufnol bearings |
				Paul,
 Greasing the tufnol will make it swell, so no, do not do it...
 Jeff - Baby Blue
 On 12/4/2011 12:34 PM, Paul & Vanessa Munford wrote:
  	  | Quote: | 	 		   Hi Paul Munford again. Forgot to ask from prev' message. Can you you
		klinefelter.kevin(at)gmai Guest
				 Posted: Sun Dec 04, 2011 11:57 am    Post subject: tufnol bearings |
				I agree, no lube on my tufnol so far and all is smooth.
 Kevin
 N211KA, 380 hours
 On Dec 4, 2011, at 11:25 AM, Jeff B <topglock(at)cox.net> wrote:
  Paul,
  Jeff - Baby Blue
		asarangan(at)gmail.com Guest
				 Posted: Wed Dec 07, 2011 8:33 am    Post subject: tufnol bearings |
				Do we know this for a fact? I looked on tufnol.com and found the following:
 "One potentially useful feature of TUFNOL materials is their ability
 to be lubricated with water, or with a water-based process fluid.  In
 many applications, this can allow the design to be simplified by
 eliminating the need for a sealed bearing with oil or grease inside.
 Although TUFNOL laminates are used dry in a great many less demanding
 wear applications, TUFNOL bearing materials are not generally
 self-lubricating and it usually is preferable to use a lubricant to
 develop their full bearing potential. CBM grades are designed to give
 good performance with minimal lubrication.  However, properly designed
 and lubricated, TUFNOL bearings give excellent service for many years
 and are frequently a cost-effective choice."
 On Sun, Dec 4, 2011 at 2:25 PM, Jeff B <topglock(at)cox.net> wrote:
  Paul,
  Jeff - Baby Blue
				 Posted: Wed Dec 07, 2011 9:05 am    Post subject: tufnol bearings |
				Andrew, If it is any help, I have applied a little light oil to my Tufnel
 bearings each year for the last 10 and they are as friction free as ever.
 Regards, David Joyce, G-XSDJ
