jindoguy(at)gmail.com Guest
Posted: Tue May 23, 2006 9:35 am Post subject: Electric fuel pump installation |
I'd ordered almost everything on my list to do a parallel Facet fuel pump o
n
my MkIII, when I came to check valves. The nice person at CPS informed me
that they had stopped carrying the little cheap plastic jobs because their
inferior quality made them dangerous. It was then that I realized that a
primer bulb has check valves in both ends. It will be a clunky install, but
it gets the job done. Functionality wins over elegance again.
Rick Girard
"Pining for a home on the Range"
rlaird
Posted: Tue May 23, 2006 9:47 am Post subject: Electric fuel pump installation |
I haven't confirmed it myself, but supposedly both pumps already have
check valves in them, so you won't need another point-of-failure
(primer bulb). (I do know my Facet pump has check valves in it, I'm
just not sure about the mechanical pump.)
-- Robert
On 5/23/06, Richard Girard <jindoguy(at)gmail.com> wrote:
n
Rick Girard
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
jdm(at)wideworld.net Guest
Posted: Tue May 23, 2006 9:59 am Post subject: Electric fuel pump installation |
Aren't the check valves in the primer bulb prone to failure? I was told
this some time ago and incorporated a bypass loop around the bulb. When I
squeeze the bulb I pinch the bypass shut to force the fuel to the carbs.
I'm looking at adding a pump also as a backup. Id be interested in knowing
what check valves you find and how reliable they are.
John Murr
ulflyer(at)verizon.net Guest
Posted: Tue May 23, 2006 3:15 pm Post subject: Electric fuel pump installation |
This primer bulb with their "sticky" check valves have brought down
more than one plane which is why if you install one in your fuel line
it is recommended you install a bypass line around them, when you use
the primer you pinch off the by pass, although I found I didn't have
to on my plane. This is where redundancy creates more potential
problems than they solve. Remember to KISS-it.
I believe NAPA auto parts stores sell the check valves for the Facet
fuel pumps.
jerb
At 12:33 PM 5/23/2006, you wrote:
n
Rick Girard
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Tue May 23, 2006 6:09 pm Post subject: Re: Electric fuel pump installation |
Gosh, I really hate to start this over again, but here goes. You all right and some of you are wrong.
NOT all facet pumps have check valves. Ask and make sure. Second, redundancy brought down my instructors Challenger, that and a faulty internal facet check valve.
I will attempt to take pictures of my assemblies as soon as possible. I am presently building this onto my Kolb.
Solution, at least for me as I write, I am doing this as is my instructor in his Challenger (I in my Kolb Firestar KXP 503).
Check valves from Mc_Master Carr. Check valve is 1/8" NPT . I probably would consider a slightly larger check valve next time because of the restriction. However, for my instructor and myself, the system still delivered more than enough fuel into a bucket in a given time to exceed any demand the 503 with duel carbs will require.
7775K61
Brass Spring-Loaded Piston Check Valve 1/8" Nptf Dryseal Male Connections, Viton Seat
$10.89 You will need two of these.
Next:
from
aircraftspruce.com
40105 40105 FACET SOL ST FUEL PUMP 2.00 0.00 28.60 you will need one if you are also using the mechanical one that came with the engine.
04-00202 MANIFOLD AL FITTING FAB-2-0-2 2.00 0.00 12.900 Yu will need one of these.
Now what we did. You may choose to do otherwise. Connect check valve on manifold there are as you will note 2 pieces check valve, with viton seals. One manifold. The manifold has 5 holes. One from one end, two on top and two on bottom. Plug side hole with 1/8" NPT pipe plug or install pressure gauge (0-6 P.S.I.) install the check valves with any necessary elbows. Install Female 1/8" NPT x 1/4" hose barb. TOne line goes back to a "T" at the output of the mechanical pump on the engine. The other check valve connection goes to the electric fuel pump. Remember to install before the suction side of both pumps, a proper filter. Be sure to put the filter where you can look at them on some frequency. If not you will have a new problem to deal with. Now out of the two remaining 1/8" NPT holes, install a 1/8" NPT male to 1/4" barb fitting. Install the line from these to the two pumps.
NOW, If a pump fails ,it's pumping or lack there of will be nipped at the manifold and the other pump will continue to do it's job.
In starting the engine, turn on electric fuel pump switch. watch gauge. It should show pressure. Start the engine, turn off the electric fuel pump, watch gauge, it should show pressure. Bob's your uncle.
Now this is the "skinny version". I have made a cutout in the back of my fuselage on top and installed a door. I can remove this door and look down into the back of the framework where I have mounted my electric fuel pump, and its fuel filter and the fuel filter for the mechanical pump is mounted right next to it. It doesn't get any simpler than that. I don't believe.
Had I just not posted our problem on the site, I would not have concerned myself with this because well, the factory pump on the 503 seems to satisfy many of the posters. And ironically many of the facet users have not faced a problem with two pump systems. This isn’t bulletproof by any stretch of the imagination, but it is better to put check valves close to the use point than , IMHO, at the pump.
"Disclaimer::: Warning! This is working for me. It does not mean it will work for you. This is installed by me on my plane. My plane is an experimental. I am experimenting. Your experimentation with like components on a like aircraft may not deliver the same results. Certain side effects can occur, way past nose bleeding or upset stomach. Always ask an aeronautical engineer before attempting. Death may result in misuse! I take no credit for any of the information contained above. There is no warranty implied or expressed. This "Warning" covers all my responsibility and I will not become responsible for any damage derived from the outcome of the above, even if used correctly.
Steven Green
Posted: Tue May 23, 2006 6:12 pm Post subject: Electric fuel pump installation |
Rick,
No need for more check valves. There is a check valve at the discharge of
each pump already.
Steven
_________________ Steven Green |
Mnflyer
Posted: Wed May 24, 2006 9:37 am Post subject: Re: Electric fuel pump installation |
I am curious, I fully ubderstand the desire for dual pumps in the event that one pump fails, but why you anyone install a paralle sytem, there by doubleing the chances for failure, double the fuel lines and check valve that are prone to failure generally in the open postion? A dual series system only requires an electric fuel pump with and out put check valve a single fuel line to the pulse pump and then on to the carbs.
_________________ GB
MNFlyer
Flying a HKS Kitfox III |
Posted: Wed May 24, 2006 10:22 am Post subject: Electric fuel pump installation |
I have to admit that I might like some back up for my single pump,
but the Facet is heavy enough by itself without doubling up.
Inline looks like a poor way to go as any blockage would put both out
of business.
Parallel, if indeed they both have internal check valves, would work.
----if the check valve on the failed pump still remained functional.
This assumes you are running both full time. In which case you will not
actually be aware of the failure when it occurs.
Next idea is a pressure switch activated back up pump (that would have
to
reset after each startup to take it off line).
Too many gremlins. Too bad the engine is at the high spot, out of the
reach
of good old gravity.
-BB, one precarious pump. do not archive
On 24, May 2006, at 1:37 PM, Mnflyer wrote:
the carbs.
GB
MNFlyer
http://forums.matronics.com/viewtopic.php?p=36241#36241
ElleryWeld(at)aol.com Guest
Posted: Wed May 24, 2006 8:40 pm Post subject: Electric fuel pump installation |
I am still confused why do you guys think it is so important to have a check
valve in your little planes fuel system? are you putting so much G-Force on
it that you cant keep fuel to the carb I have that problem once in a while but
I will someday install a electric fuel pump so I can force fuel to the carb
and I wont keep having almost engine outs Buzzing others that enjoy it as much
as I enjoy doing it
Ellery in Maine
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Thu May 25, 2006 2:56 am Post subject: Electric fuel pump installation |
Ralph Hoover
Posted: Fri May 26, 2006 6:34 am Post subject: Re: Electric fuel pump installation |
For your reading pleasure. Not all Facet pumps are created equal!
FACET MIN - MAX ANTIPART
SHUTOFF POSITIVE MIN DRY FITTING QUIET CHECK SIPHON
NO. PRESSURE GPH LEAD LIFT INCHES SIZE VALVE VALVE VALVE
40104 2 - 4 28 12 1/8-27 INT NO NO NO
40105 3 - 4.5 34 12 1/8-27 INT NO NO NO
40106 4.5 - 7 34 12 1/8-27 INT NO NO NO
40107 7 - 10 50 12 1/8-27 INT NO NO NO
40108 4.5 - 6 32 .25 BLADE 12 3/8 FLARE NO NO NO
40109 4.5 - 9 32 24 3/8-18 INT NO YES NO
See Facet pdf file at Facet site for details. I was under the impression that the 40-105 did have a check valve. It has a buldge on the intake.
Oh well,
Ohio Ralph
Ralph Hoover
Posted: Fri May 26, 2006 6:46 am Post subject: Re: Electric fuel pump installation |
I forgot in my earlier response to give this site as good info for our Facet pumps.
Far more than I had imagined for thoses of you using Facet pumps that thought they had anti-siphoning or checkvalves, etc. One size does not fit all. Now my instructor tells me he will not even consider flying my Kolb if I do not install filter BEFORE pump. Whats a guy to do? Haa! Ha! So amny opininons, so little time. Guess thats why they call it experimental!
http://www.facet-purolator.com/mcl/pages/frame_src/ttips_frmsrc.html
Ohio Ralph
