Solid fuel lines
steve.freeman(at)syntaxds
PostPosted: Wed Dec 07, 2011 12:42 pm    Post subject: Solid fuel lines Reply with quote
Hi Guys,
Can anyone who switched out the ZAC supplied rubber fuel lines with solid line offer any advice and guidance on doing this?
I am thinking about running solid lines from my wings to fuel selector valve
Valve to Gascolator
Gascolator to engine.
Suggestions on what products to purchase (Especially connectors!!!) size of lines and tips on how to properly flare ends/make connections or whatever else I might need to do would be greatly appreciated.
Any photos are of course always a super bonus.
thanks,
Steve Freeman
650B – Lycoming 0235
N902AL
Poking along on Fuselage but making progress.
Received brand new shiny engine on Sunday. To cool!
bryanmmartin
PostPosted: Wed Dec 07, 2011 1:47 pm    Post subject: Solid fuel lines Reply with quote
I used 3/8" O.D. 3003 aluminum tube with AN flare fittings from the tank to the fuel valve because I didn't want to have to remove the wings to replace rubber lines sometime in the future. The rest of my lines are the supplied flexible hose. I did not have a 37° flaring tool for the fittings so I used a standard 45° flaring tool to partially flare the tube and tightened the fitting down to finish the flare. The 3003 tubing is soft enough to make this work and I have had no trouble with them in six years and 360 hours.
You should use some kind of flexible hose for the segment between the airframe and engine, otherwise the vibration of the engine in its mounts will likely cause a solid tube to fail.
On Dec 7, 2011, at 3:39 PM, Steve Freeman wrote:
Hi Guys,
Valve to Gascolator
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
do not archive.
Bryan Martin
do not archive.
vk3eka(at)bigpond.net.au
PostPosted: Wed Dec 07, 2011 9:58 pm    Post subject: Solid fuel lines Reply with quote
Steve,
I did the same as Bryan and ran 3/8 tube from the tanks to the fuel selector. I also ran it to the fuel pumps on the firewall. Check out http://zodiac.cpc-world.com/images/IMG_0106_JPG.jpg.
http://zodiac.cpc-world.com/images/IMG_1315_JPG.jpg shows the fuel selector end. You can see I mounted a coupling to the center section so I don't have to remove the center console sides if I have to remove the wings for any reason.
Not many other photos I'm afraid. All the fittings are AN and I used a flexible line from the fuel pumps to the carby. Don't use a solid line there otherwise you will experience cracking due to the engine vibration.
Follow Bryans advice regarding the tube ends. It the same method as I followed!
Have fun
Peter
Wonthaggi Australia
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Steve Freeman
Sent: Thursday, 8 December 2011 7:39 AM
Subject: Solid fuel lines
Hi Guys,
Valve to Gascolator
thanks,
Steve Freeman
N902AL
DaveG601XL
PostPosted: Fri Dec 09, 2011 4:39 am    Post subject: Re: Solid fuel lines Reply with quote
Same here. 3/8" 3003 aluminum tubing. Although it is not shown in the attached pictures, where the line penetrated a rib or fuselage side skin, I used the silicone tape to provide chafe resistance. I did find a reasonable priced 37 degree flaring tool on E-bay. Flex lines from firewall to engine.
Good luck,
 Filesize:  53.66 KB
 Viewed:  3792 Time(s)
 Filesize:  54.38 KB
David Gallagher
Cincinnati, OH area
