AC powered fin strobe
Richard Lamprey
PostPosted: Fri Dec 09, 2011 10:12 pm    Post subject: AC powered fin strobe Reply with quote
My fin mounted 12V DC Filser strobe went u/s, and I have spent some time looking for a similar strobe that will fit in the hole in the fin (5 cm exact diameter). I settled on the Illusion strobe from the US (mostly used for ultralights), the only one that will fit, and this is powered directly from the Rotax 912 magneto generator, which supplies 12V AC. I am told it has an exceptionally bright flas. The strobe power box is wired in series between the 912 generator wires (yellow) and the Ducati voltage rectifier. Also, strangely, there is no circuit breaker or fuse in this system. Has anyone installed an Illusion AC system before, or similar? Are there problems, does it blow the rectifier? The supplier assures me this is a common installation with 912 engines, and there are no problems.
rholder(at)avnet.co.uk
PostPosted: Sat Dec 10, 2011 1:39 am    Post subject: AC powered fin strobe Reply with quote
problems.
Be advised that the AC voltage out of the stator can be as
much as 30 v at full power.
That might explain why it is so bright.
Unless you really meant "in series" rather than the usual
"in parallel" !
If it works in series then it might be OK with a slightly
higher engine rpm before the battery gets charge.
RFWH
frans(at)privatepilots.nl
PostPosted: Sat Dec 10, 2011 6:25 am    Post subject: AC powered fin strobe Reply with quote
On 12/10/2011 07:12 AM, Richard Lamprey wrote:
The
Wait a minute. Is it really in series? If both yellow wires go to the
Ducati AND both go to the strobe, it is parallel. If one yellow wire
goes to the strobe, and one yellow wire to the ducati, and a new wire is
used to connect the remaining ducati and strobe connectors together
(like how X-mas tree lights are wired), it is indeed series.
It is quite important to know whether it is parallel or series, hence my
question.
This would make sense if it is series indeed, otherwise you should use a
fuse.
Anyway, I would advise for quite a number of reasons against a series
diagram, but a parallel diagram would be ok. I would be surprised if it
is series indeed, but you never know.
Assuming it is parallel, as it should be, I think it is a great
solution. Strobes work on high voltages, so any strobe power supply
needs to convert the low voltage DC into high voltage AC and then
rectify it again. By feeding it directly from the alternator (where it
is still AC) quite some losses can be avoided, and it also does not load
the Ducati (which has a tendency to burn out easily). An AC-fed strobe
can not be powered from the battery, but if the alternator fails the
strobe is the first thing you should power down anyway, so this is no
real disadvantage.
You should put a fuse between the alternator and strobe power unit.
(Don't use a CB here, as you should never try to reset a tripped strobe
CB during flight: it is not essential equipment and malfunctioning
strobe power supplies are quite a hazard, so don't play with these
things and just use a "one-time" fuse here to avoid any temptation!). I
would put a switch in between too, as it is considered somewhat impolite
to wait at the holding point with bright flashing strobes while there is
someone on final, especially when it isn't very bright weather. I would
also like to power down the strobe if I would smell any fuel during flight.
Frans
Richard Lamprey
PostPosted: Sun Dec 11, 2011 4:06 am    Post subject: Re: AC powered fin strobe Reply with quote
Yes, really meant in series... its is mak by Aircraft Spruce, heres the description, also the attachment shows the circuit:
Has no effect on the charging or electrical system.
*Works on a simple lighting coil system only...without a regulator or
*Will work along with a complex battery charging system...with a regulator
Designed for most Light plane engines..... Rotax, HKS, Hirth, Zenoah, MZ......
THE BRIGHTEST AC POWERED STROBE LIGHT AVAILABLE
25 JOULES (watt-second) and yet...
It is the most efficient strobe light available because...
It uses only the power that is normally wasted by a voltage regulator...
Unlike automobile regulators, U.L. regulators short to ground OR
dump all the current that is not used with the battery, wasting 4 to 15 amps and
that is why this strobe is so BRIGHT.
Will NOT drain battery and, in fact, NO BATTERY IS NEEDED !!
Can be connected directly to the lighting coil, NO voltage regulator is required
Uses the yellow wires out of the engine OR any 2 to 14 amp AC power source.
Illusion SimpleWiring-wSwitch.doc
 Filename:  Illusion SimpleWiring-wSwitch.doc
 Filesize:  24.5 KB
 Downloaded:  390 Time(s)
PostPosted: Sun Dec 11, 2011 1:34 pm    Post subject: AC powered fin strobe Reply with quote
It doesn't say so in the description. Why do you think it is intended to
be connected in series?
I didn't see any attachment.
Free electricity. Sounds to be too good to be true.
Maybe the Rotax two-cycle engines are different, maybe they are talking
about that family of engines?
The voltage regulator of the 912/914 doesn't "waste" enough power to
power a strobe.
I have the schematic diagram of the Ducati regulator somewhere, but as I
recall it doesn't short to ground. If that were true, the regulators
would become hotter when less current is used in the electrical system.
That doesn't seem to reflect the reality.
If it uses both yellow wires it is a parallel system.
Anyway, it is interesting but I could nowhere find any more information
than the one given on ACS, and that is a bit of gibberish to me.
So far I get the impression that the selling point of this thing is that
you don't need a battery or regulator, which may be of interest to
owners of ultra light aircraft, gyrocopters and other minimal setups.
Frans
paul.the.aviator(at)gmail
PostPosted: Sun Dec 11, 2011 3:14 pm    Post subject: AC powered fin strobe Reply with quote
I am guessing that this strobe is targeted towards the 2 cycle family of Rotax engines.  It's appeal would be in its simplicity to wire up.  Neat idea.
do not archive.
On Sun, Dec 11, 2011 at 3:29 PM, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
[quote]--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
It doesn't say so in the description. Why do you think it is intended to be connected in series?
Maybe the Rotax two-cycle engines are different, maybe they are talking about that family of engines?
The voltage regulator of the 912/914 doesn't "waste" enough power to power a strobe.
I have the schematic diagram of the Ducati regulator somewhere, but as I recall it doesn't short to ground. If that were true, the regulators would become hotter when less current is used in the electrical system. That doesn't seem to reflect the reality.
Anyway, it is interesting but I could nowhere find any more information than the one given on ACS, and that is a bit of gibberish to me.
So far I get the impression that the selling point of this thing is that you don't need a battery or regulator, which may be of interest to owners of ultra light aircraft, gyrocopters and other minimal setups.
Frans
jan_de_jong(at)casema.nl
PostPosted: Mon Dec 12, 2011 4:19 am    Post subject: AC powered fin strobe Reply with quote
Voltage regulator is a "rectifier-regulator".
It is a "full wave rectifier" with 2 of the 4 diodes replaced by SCRs
(thyristors).
All output current is supplied through the 2 alternating sets of 1 diode
and 1 thyristor in series.
The voltage drop across these when they conduct (ideally zero)
determines the loss.
The peak current through these is a multiple of output current because
they conduct only a small fraction of the time. The peak current is
limited by the internal resistance of the alternator coils and the
internal resistance of the output storage capacitor.
See forward voltage at 50 A and 100 A for the SCR:
http://www.datasheetcatalog.org/datasheet/on_semiconductor/2N6504-D.PDF
See forward voltage at 50 A and 100 A for the diode:
http://www.datasheetcatalog.org/datasheet/on_semiconductor/MR2500-D.PDF
Ballpark voltage drop is 3 to 4 volts - 21 to 28% of output volts. Heat
dissipation as a percentage of output power (watts) is the same number.
From the datasheets it is clear that the voltage drop and therefore
loss percentage increases quite progressively with high and increasing
current.
If you can power a 40 W strobe directly from AC you may save 10 W or so
in heat generation in the voltage regulator.
Jan de Jong
Richard Lamprey
PostPosted: Mon Dec 12, 2011 9:58 pm    Post subject: Re: AC powered fin strobe Reply with quote
Many thanks for all the replies, especially Frans and Jan for their technical responses. I attach again the simplified wiring diagram, showing the in series connection, this diagram enclosed with the strobe, and also re-confirmed with the original manufacturer Air-Tech Inc.
I am an ignoramus on electrical matters, so I'll close my eyes when making the final connection and hope there isnt a big bang from the rectifier (obviously this thing will only work when the engine is running). One reason I am a little cautious is that Ducati rectifiers are not very consistent and reliable, and having seen this one serve me well for about 7 years I would hate to wreck it.
All best
Richard
Europa Classic 168, Kenya
ILLUSION AIRCRAFT STROBE from Aircraft Spruce.pdf
 Filename:  ILLUSION AIRCRAFT STROBE from Aircraft Spruce.pdf
 Filesize:  87.54 KB
 Downloaded:  936 Time(s)
 Filesize:  24.5 KB
 Downloaded:  371 Time(s)
PostPosted: Tue Dec 13, 2011 8:54 am    Post subject: AC powered fin strobe Reply with quote
Hi Richard,
Not the way we are used to connecting loads to power sources indeed.
I don't like the fact that your DC power supply and your strobe box are
now mutually dependent.
Mind that the optional switch drawn has to carry 15 A average and 100 A
peak (<1 ms).
But it will probably work well enough.
A power supply is generally used as a voltage source. The load takes
some current away that does not affect the voltage (ideally).
In this case usage is reversed. The load takes some voltage away that
does not affect the current (too much, we hope).
The strobe input may be an up transformer with a few fat primary
windings and many thin secondary windings.
It probably takes away a certain percentage of the AC voltage available.
You will need somewhat more RPM than before for DC to reach normal
performance.
That should be all, actually.
Jan de Jong
PostPosted: Tue Dec 13, 2011 9:10 am    Post subject: AC powered fin strobe Reply with quote
Inc.
It is indeed in series!
Well, my ideas on this:
The total aircraft electrical power consumption will have to go through
the strobe box and its associated wiring. All of it. This means that if
you put the strobe box in the fin, all electrical current for whatever
avionics you have, will have to travel through the wires, forth and back
to the tail.
This has the following implications:
1) you need to run very heavy wires, to keep current losses acceptable.
The wires do not just carry the current for the strobe, but the current
for the total electrical load of the entire aircraft.
2) You can not install a light fuse, you have to use a fuse higher than
the total power demand of the aircraft. Think about something like 30
Amps. If you have a short circuit somewhere but the current stays below
30 Amps, the fuse won't blow but all this energy is converted into heat.
This is a fire hazard.
3) The long wires will act like an antenna. Alternators AND strobes are
both notorious for their electrical noise. It may have an influence on
your radio.
Therefor, I would highly recommend to put this strobe box as close to
the alternator as possible. This again has the implication that you will
have to run long wires to the strobe bulb, but at least these wires do
not carry large currents.
Also be aware that your electrical system becomes completely dependent
on the strobe box. If it blows open circuit, it takes the whole
electrical system with it. You definitely need to incorporate a
short-circuit switch, to bridge the strobe box in case it fails open
circuit.
There is no such thing as "free electricity". Anything in series with
the voltage regulator will have its impact on the performance of the
electrical system. I can't judge from here how bad it is. But the Rotax
power system isn't powerfull to start with.
Best regards,
Frans
Richard Lamprey
PostPosted: Wed Dec 14, 2011 7:14 am    Post subject: Re: AC powered fin strobe Reply with quote
Thanks Frans and Jan,
An additional wiring diagram shows the switch that by-passes the strobe box from the AC supply as 20 Amp, so there's a hefty current. I'll be putting the box as close to the rectifier as possible, and use the existing 22 AWG strobe wiring from the previous installation for connection to the strobe in the tail. There will be no point to running the AC strobe continuously, but mainly flying in the circuit, approach, on the apron, etc. Lets see what happens.
Best
Richard
