Posted: Sun Dec 11, 2011 10:28 am Post subject: In-flight fuel mixture |
I am a great believer in reed valve engines with ceramic coated aluminum
cylinders. They will take much more abuse than the steel liners with
aluminum pistons.
Jack B. Hart FF004
Jack H/Kolbers:
Hope the new engines work out ok. Rotax could use a little competition.
Reed valves were very popular back in the 60's and 70's on two stroke dirt
bikes. Made those little two strokes scream, until they swallowed a reed.
I believe it was Polson that came up with a non-metallic reed valve to
preclude destroying an engine when a reed valve broke and went through it.
I am not familiar with "ceramic coated aluminum cylinders". The 912's use a
metallic coated cylinder that comes out of the factory with .000" to .001"
cylinder wall to piston clearance. That's tight.
Was interested in your statement above, "They will take much more abuse than
the steel liners with aluminum pistons." Is the ceramic coating more
durable than nikasil and other metallic cylinder wall coatings?
_________________ John Hauck
Titus, Alabama |
Posted: Sun Dec 11, 2011 10:58 am Post subject: In-flight fuel mixture |
Titus, Alabama |
Posted: Mon Dec 12, 2011 5:14 pm Post subject: In-flight fuel mixture |
At 12:56 PM 12/11/11 -0600, you wrote:
Posted: Mon Dec 12, 2011 6:18 pm Post subject: In-flight fuel mixture |
Also one can run higher EGT with out fear of melting the pistons.
With reduced piston to wall clearances, one can run simple very thin, light
and inexpensive piston rings.
When I purchased the Victor 1+, which has a Nikasil coated cylinder, I asked
about TBO. I was told to replace the piston rings after 600 hours, at 1,200
hours replace the piston and rings, at 1,800 hours replace the rings, and at
2,400 hours to replace the cylinder, piston and rings.
Jack B. Hart FF004
Jack H/Kolbers:
Can you run higher EGT because the pistons are also coated?
The TBO figures are quite impressive. Do you have knowledge of an owner
that has attained this much time on a Victor?
I wonder if those figures are for the user or lab environment?
Titus, Alabama |
Posted: Mon Dec 12, 2011 7:55 pm Post subject: In-flight fuel mixture |
At 08:16 PM 12/12/11 -0600, you wrote:
John,
There are other ceramic coatings that are used as thermal barriers that can
be applied to the top of the piston, the head inner surface and the exhaust
ports. When these have been applied, one can run higher EGT's.
I do not know of anyone who has run a Victor 1+ up to these hours. 600 hours
for a ring replacement is not all that high when little four cycle diesel
engines run several thousand hours with no ring replacement. Also in
searching the web I found:
http://www.ncccoat.com/PDF/NCCSAEtechnicalpaper.pdf
and:
http://www.mt-llc.com/tour/98winter_snowtech_article.pdf
The first is pretty technical. The second describes repair.
I suspect these hours were found by running an engine for a given number of
hours and then the engine was torn down and measurements were taken of the
rings, piston, and cylinder. And then from the wear found, extrapolations
were made to come up for the TBO, ring, piston, and cylinder replacement.
Jack B. Hart FF004
Winchester, IN
Posted: Mon Dec 12, 2011 8:18 pm Post subject: In-flight fuel mixture |
Jack B. Hart FF004
Jack H/Kolbers:
Not really any comparison between longevity of a diesel four stroke and a
gasoline two stroke.
There is a facility in Auburn, Alabama, that recoats cylinders. I rebuilt
my son's 450 Yamaha MX engine. The cylinder was really buggered up. They
did a good job, but it was expensive.
Good luck with the Victor.
Titus, Alabama |
Thom Riddle
Posted: Tue Dec 13, 2011 7:44 am Post subject: Re: In-flight fuel mixture |
Jack,
The second link you posted regarding repair, came up fine but when clicking on the first link all I go was several blank pages. They are both .pdf files so I know that is not the problem. I would very much like to read the first document. Any chance there might be another way to get to it?
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Tue Dec 13, 2011 5:35 pm Post subject: In-flight fuel mixture |
At 07:44 AM 12/13/11 -0800, you wrote:
Jack,
Thom,
I could not view it on my old computer as it will not accept the latest pdf
viewing program upgrade. On my new machine it came up just fine.
I hope this helps.
Jack B. Hart FF004
Winchester, IN
Posted: Tue Dec 13, 2011 6:04 pm Post subject: In-flight fuel mixture |
At 10:16 PM 12/12/11 -0600, you wrote:
Jack H/Kolbers:
John,
True, but the piston rings, the piston, and cylinder system is common to
both two and four stroke engines. The one difference is one power stroke
per one revolution versus two revolutions. With time, technology has
marched forward and all engines are much more reliable. I have an Impala
with 240,000 miles and a Ford van with 330,000 miles. No oil has to be
added to either between oil changes. I estimate the conservative running
time (miles/60 mph) to be 4,000 hours on the Impala and 5,500 hours on the
Ford.
These figures lead me to believe that a 600 hour ring life time for the
Victor 1+ may be conservative. Also, I believe there are many Rotax two
cycle engines flying that have long passed the 300 hour TBO period.
All it takes to beat these TBO times is to use a good oil, and not too much
of it, and keep the engine head and exhaust gas temperatures below the
manufacturer's recommended maximums.
Jack B. Hart FF004
Winchester, IN
Posted: Tue Dec 13, 2011 6:24 pm Post subject: In-flight fuel mixture |
Jack B. Hart FF004
I agree.
Also, Rotax TBO for other than certified engines, is recommended TBO. Not
mandatory to tear down a good engine just because it has reached
"recommended TBO".
I pull with a 1992 Dodge/Cummins with approximately 6,500 hours on it. That
is 388,000+ miles. Engine is still as strong now as it was when new.
Sitting here patiently waiting for some of you Kolbers to get out there and
start putting some serious time on your engines, especially two strokes, no
matter what make or model.
The only way we are going to know if manufacturers of ultralight engines are
telling us the truth or blowing smoke is to get out there and fly.
mkIII-3,100+ hours
912ULS-560.0+ hours
Titus, Alabama |
