MikeDunlop
Posted: Mon Jan 02, 2012 11:11 am Post subject: Composite aircraft grounding systems. |
For Bob Nuckolls (or anyone else with knowledge of composite aircraft grounding systems),
I have recently bought your book, 'The AeroElectric Connection' (12th Edition) and have also looked at all the FAQ documents and archive posts such as 'Airframe Grounding' etc. Very, very interesting reading.
I'm starting the electrical system on a Rutan Long-EZ project (all composite as you will already know). The original builder had built in one copper 1/2 inch ID tube from front to back and I'm contemplating using it for possibly two purposes, a) a main earth rail. b) a conduit to carry the main power cable to the starter. The battery is in the nose and the distance from battery to starter (B&C light weight) is 14 ft (4.3 metre). Cable suppliers in the U.K. shows #4 as being suitable for starters but B&C responded to my question saying for a Long-EZ use #2, presumably for voltage drop reasons.
I've settled on the Z-12 setup with a automotive alternator and B&C LR-3 controller as primary power with a B&C SD-8 system for secondary power. I would like to seek valued opinions on the following:
Questions:
1. Would having a main power cable inside a copper ground tube generate unforseen problems (besides lots of sparks if shorted out!).
2. Can I use welding cable instead of the very heavy and very expensive #2 Tefzel coated aviation cable (circa $15 per foot in the U.K.)
3. Should the Starter solenoid be close to the battery or on the firewall (live power in the cable only at starting or all the time)
My main concern and objective at the moment is to establish a suitable and reliable earthing system before moving on to other matters.
Bob, many thanks for your excellent book and resources.
Mike Dunlop (U.K.)
rparigoris
Posted: Mon Jan 02, 2012 11:42 am Post subject: Re: Composite aircraft grounding systems. |
Hi Mike
I'm building a composite Europa. There's a builder in Canada that put Eric Jones copper clad wire:
http://www.periheliondesign.com/fatwires.htm
inside a copper pipe as you suggest. I don't think he's flying yet, but here are a few pics:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=78200
I think the yellow with green is heat shrink he added.
The aluminium wire is expensive but will save you some weight. It is not very flexable and fatugues more easily than thin stranded copper. If you need to make hard turns, best use welding cable for that area? I looked into welding cable and www.mcmaster is one resource. The #2 CCA is thicker in diameter compared to Tefzel, but has approx the same resistance.
Ron Parigoris
Posted: Mon Jan 02, 2012 1:39 pm Post subject: Composite aircraft grounding systems. |
M: Bob,
I've just joined the AeroElectric-List and will post the following
when the acount is activated...
Thank you.
Correct.
LR-3 controler as primary power with a B&C SD-8 system for secondary
power. I would like to seek your valued opinion on the following:
Then you don't want Z-12 but Z-13/8.
Questions:
generate unforseen problems.
No, But you do want to craft your tube-to-wiring connections
by soldering copper wrap-around flag terminals to the copper tube.
2. Can I use welding cable instead of the very heavy and expensive #2
Absolutely. In fact I prefer it.
3. Should the Starter solinoid be close to the battery or on the
Close to the starter. Then use the same feeder
to bring b-lead power up front from the main alternator.
But a current limiter in the b-lead connecting right
were it attaches to the hot-side of the starter contactor
on the firewall.
suitable earthing system before moving on to other matters. I could
go on asking questions like this all day but I'm sure you have other
things to do and I need to concentrate on getting this bit sorted first.
The conduit ground system is fine.
Many thanks for your excellent book and resources.
I'm pleased that you find it a good value . . .
steve(at)tomasara.com Guest
Posted: Tue Jan 03, 2012 6:36 am Post subject: Composite aircraft grounding systems. |
Mike and the group:
Regarding the the placement of the starter solenoid there is, as usual,
more than one way to skin this cat. There are some trade-offs. Bob's
recommendation to put the solenoid back by the starter and use the one
big feed line for both the starter supply and Alternator B lead, which I
think is a good one for many people, eliminates an otherwise needed
additional wire (#8 in my case) for the alternator B lead running from
the alternator back to the bus and thus saves it's weight.
My LongEz was flying when purchased but I immediately grounded it and
spent ~4 years reworking it before putting it back in the air again.
It's been flying it since August '11. When I totally replaced the
electrical system in the my LongEz, I read the book, considered all the
options, posted lots of question on the forum and I ended up with the
planned location for the starter solenoid up front. Here's why:
My goal, in recognition that I was new to experimentals in general and
LongEzs in particular, was to stick pretty close to the plans and owners
manual authored by Burt unless they had been superseded by CPs, or a
perceived (and well reasoned) consensus on the yahoo group
canardaviators. With that in mind, I wanted all my initial flight
testing without a starter (even though it had one when I bought it) to
keep the CG as far forward as I could and keep it as light as possible.
I haven't yet installed the heavy feed or return cables back to the
firewall that will be required if I later reinstall the starter.
I did, keeping a future installation in mind, reserve space up front for
the starter solenoid and I kept the #8 firewall return (i.e. ground)
wire separate from the laced bundle going back to the firewall so that
it would be easy to replace it with welding wire (or CCA) later if required.
The two biggest reasons I went this route is that, when I am running
without the starter as I am now, I'm not carrying around the heavier
wire and it allowed me to protect the #8 B-wire with an ANL up near the
master relay and battery so that I didn't have an unprotected
high-current feed running from the master relay (or buss) all the way
back to the firewall. As I understand it (and Bob is the authority
here, not me) there is nothing wrong with having the unprotected feed
from the buss going all the way back to the firewall but I was more
comfortable not doing so. Another benefit was that I could keep all
this stuff together up in the nose (which is also where I moved the
regulator) rather than back on the firewall (which is already crowded
enough on a LongEz, esp. if you have electronic ignition as I do).
If and when I do re-install the starter, the downside for going the
route that I did is that I'll be carrying around a single extra #8 wire
running from back to front. That wasn't a problem for me given that
I'll also be adding two long lines of welding wire and a starter at that
time as well... A purest might reconfigure at that time to the
configuration Bob recommended to save the weight of the #8 wire. I won't.
btw: I recommend both the canardaviators forum and Central States
Association. There is a lot of good information out there on LongEzs
beyond the plans and CPs but it takes some digging to get to it.
In completing your LongEz be sure to be more concerned about "completion
drag" than "aerodynamic drag". Anything you do that hasn't already been
done before, and been well documented in the process, will cost you more
time (i.e. be a drag on getting your bird flying) than you imagine...
Steve Stearns
Boulder/Longmont, Colorado
CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less)
Restoring (since 1/07) and flying again (8/11!): N45FC O235 Longeze
Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Tue Jan 03, 2012 8:40 am Post subject: Re: Composite aircraft grounding systems. |
I sell lots of Copper-Clad Aluminum cable to 300 mph fuel dragster and racecar builders, weird groups doing strange things where the weight is important. I even sell the stuff to the companies building remote-controlled drones. Predator drones and the more advance secret stuff...
Airbus and Boeing use similar CCA configurations.
I sell Super-2-CCA, Super-4-CCA, AWG-6-CCA (same dimensions as AWG-6 but CCA with Tefzel insulation), and Super-CCA RG+142
See my website. CCA is 60% the weight of copper for the same conductivity.
If you have the battery on the firewall, you are okay. Otherwise, use CCA.
Also see Bob's most excellent article, http://www.aeroelectric.com/articles/economics_of_weight_reduction.html
and on my website: http://www.periheliondesign.com/fatwires_files/Coppercables.pdf
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
