		graeme bird
				 Posted: Tue Jan 03, 2012 12:49 pm    Post subject: Rotax 912 exhaust springs going walkabout |
				During 'shake down' flights we twice lost an exhaust spring, both front, left then right, whether snapped or shaken loose, who knows. New engine, new springs, new exhaust - why should this be? Applied with a string not pliers, Anyone else had this? now wire locking but need more hours to see what happens.
 Maybe its the stiffness of the new engine creating lots of movement on startup?
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
		ward.t(at)xtra.co.nz Guest
				 Posted: Tue Jan 03, 2012 2:01 pm    Post subject: Rotax 912 exhaust springs going walkabout |
				Graeme,
 I was told to put some high-temp RTV Silicone gasket maker by Permeatex on the springs between the wires to absorb the shaking. Haven't had a problem with them. Don't know if it was due to the above application however they are still attached. I also lock wire the to the muffler to avoid the departure.
 Tim Ward
 12 Waiwetu Street
 Fendalton,
 Christchurch,  8052
 New Zealand.
 Ph 64 3 3515166
 Mob 0210640221
 On 4/01/2012, at 9:49 AM, "graeme bird" <graeme(at)gdbmk.co.uk> wrote:
  Graeme Bird
  G-UMPY
  Mono Classic/XS FWFD 912ULS/Warp drive FP
  Just Test Flying to obtain permit
  http://forums.matronics.com/viewtopic.php?p=362354#362354
				 Posted: Wed Jan 04, 2012 12:44 am    Post subject: Rotax 912 exhaust springs going walkabout |
				Graeme
 check the holes in the tabs on the muffler downpipes. I've seen some very sharp corners/burring on them which cut through the spring hooks. I once spent half an hour deburring all the holes on one that I worked on.
 Graham
  Sent: Tuesday, 3 January 2012, 20:49
  Subject:  Rotax 912 exhaust springs going walkabout
 --> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
 Graeme Bird
 G-UMPY
 http://forums.matronics.com/viewtopic.php?p=362354#362========================http://www.matronics.com/Navigator?Eurp;  -->
		tennant
				 Posted: Thu Jan 05, 2012 12:52 pm    Post subject: Re: Rotax 912 exhaust springs going walkabout |
				Hi Graeme,
 Over 14 years I have replaced many of the stainless springs supplied with the kit. This all ended when I changed from stainless to galvanized springs. Since then no more breakages.
 Just a tip.
 Best regards
 Barry Tennant
  _________________ Barry Tennant
D-EHBT
At EDLM  -  Germany |
