Okanogan Lew
Posted: Sat Jan 07, 2012 2:18 pm Post subject: CJ6 Compressor Valve |
Guys, I disassembled the air out banjo fitting on the compressor to clean the valve & noticed that the required spring was missing. I got an overhaul kit from Doug, installed the new spring & seals. Now, there is almost no air and "snot" released when I open the "snot" valve after flying. Before, there was a considerable amount ejected. I check all the fittings with soapy water and there are no leaks. Air pressure in the plane is normal & everything works as before. Any thoughts on why installing the spring would make a difference? Thanks.
Paul lewis
