		doffill(at)cableone.net Guest
				 Posted: Wed May 24, 2006 7:42 pm    Post subject: AnywhereMap |
				Does anyone use the AnywhereMap software with a PDA while flying.  If so
 please provide a pirep.  I'm trying to decide to between the AnywhereMap
 with the Dell PDA or the Lorance 600c GPS.
 Danny
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Geoff Heap
  Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
				 Posted: Thu May 25, 2006 3:38 am    Post subject: Re: AnywhereMap |
				I used anywhere map with an Ipaq untill about 18 months ago. When my 701 is finished I'll put a dedicated unit in it. Probably a Garmin 296. The AW map on my Ipaq worked just fine. I liked it a lot. It does all they claimed. Refresh was a litttle slow but the Ipaq was a 2002 model. What turned me off was that it was installed in volatile memory and if I let it sit for a month the batterry would die and lose the AW map. Soooo I had to keep reinstalling it. You can move it to a non volatile area of memory but the installation has to be just right. I personally think it was too much trouble. I have an older black and white unit that I havn't used for years and I know that I can turn it on tomorrow and it will pick up 3 satellites and give my location within 2 minutes. Maybe the pocket PC's they make today are better in this respect, probably. Cut a long story short. The software is great.......Geoff
		John Bolding
				 Posted: Thu May 25, 2006 3:53 am    Post subject: AnywhereMap |
				I have used the Anywhere Map for several years and have found ways to =
 work around the couple of things that give me problems.
 Their customer support is VERY good. At Oshkosh and Sun Fun they update =
 any Controlvision unit for free.
 The display and its operation keep me using it.
 The thing that gave me trouble at first was the fact that I'm not =
 computer literate and downloading updates always hit a snag. Solved it =
 by having the program loaded to a flash card and keeping it with the =
 unit.
 If the battery on the pda runs down it dumps the program and must be =
 reloaded, big problem for me if doing it on the computer ,no problem if =
 using the flash card. Takes about 5 min.
 For a nominal charge I got Control Vision to burn a card for my wife's =
 PDA as well so I can carry a backup for less than $50.
 I use an Ipac PDA, a larger screen on a tablet computer would be worth =
 the money.   John
		gkrysztopik(at)satx.rr.co Guest
				 Posted: Sat May 27, 2006 5:31 am    Post subject: AnywhereMap |
				I think the features are great, and with a new PDA the speed and
 brightness are good.  The stylus can be tricky in turbulence but has
 been manageable.
 I may be selling mine to consolidate the panel into one bigger piece of
 glass.  I just bought a new iPaq (2950?) and new s/w update that is
 still good for a while.  I have the StreetMap database too with cables
 setup for easy removal in car/plane.
 gary
		mileski(at)sonalysts.com Guest
				 Posted: Mon May 29, 2006 12:17 pm    Post subject: AnywhereMap |
				I just installed one in my 701.  The wireless GPS with bluetooth Dell Ax=
 im PDA are great. There are no more concerns with dead batteries and hav=
 ing to reinstall the software with any Windows Mobile 5 PDA.  The wirele=
 ss operation is great, you can pull the unit out of the mount and hand i=
 t to your copilot/passenger and they can check gas prices ahead.  All so=
 rts of convenience features in that software now, and as the software im=
 proves, you upgrade for free as part of your annual subscription. Then t=
 he PDAs improve every year or two, and then you upgrade, for a few hundr=
 ed dollars, if you have to have the best. Harder to do that with a Garmi=
 n.     =20
   =20
 =20
		ggower_99(at)yahoo.com Guest
				 Posted: Mon May 29, 2006 11:16 pm    Post subject: AnywhereMap |
				There is (was) only one AnywhereMap here in our Club (about 4 years ago).
    He liked it very much, the only concern was to see the map with the sun ( I dont know what PDA model or brand he used).   He uses now a Garmin instead.
   Probably newer PDA's  have solved this problem.  I used to have a Palm.  and only could see the programs inside a room.  even tree shades were not enough.
   Saludos
   Gary Gower.
 n.
