		planes_by_ken(at)bellsout Guest
				 Posted: Thu May 25, 2006 4:30 am    Post subject: Cortec 373 and airframe ground continuity |
				Rory Davis wrote:
  Has anyone using Cortec 373 primer had any problems with high airframe ground
  resistance or intermittent grounding?
  Cortec being a plastic (insulator), doesn't it electrically isolate each side of
  the metal joint if applied between the two halves, with ground continuity
  relying on the rivets and scratches/imperfections in the primer?
  I'm getting ready to close up the first wing on my 701 kit and in the process of
  installing the strobe box and fuel tank grounding got to thinking about this. I
  scraped away the layer of primer at the grounding points but then realized all
  the ribs and channels may be electrically isolated from each other. This could
  make for noisy radio comms or odd electrical faults in the future.
  Any comments?
  Rory
  Lacombe, LA
  CH701 Working on wings
 Also, an anodized surface is high resistance.  I don't know about
 alodine.  Allot of airframes are bonded (glued sheet metal)
 construction.  I wonder if they have any problems.
 Ken Lilja
 601XL rudder done.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		gfmjr_20(at)hotmail.com Guest
				 Posted: Thu May 25, 2006 3:42 pm    Post subject: Cortec 373 and airframe ground continuity |
				Ken--
   I used cortec throughout, however, I cleaned all electrical contact area.
 I'm running an all electrical panel using Dynon EFIS and Dynon FlightDeck
 along with autopilot, com ,nav, and transponder  and have had no problems so
 far in my electrical checkout.  No noise on radio and the Dynons are working
 ok so far.
 George May
 601XL 912s
  	  | Quote: | 	 		  From: Ken Lilja <planes_by_ken(at)bellsouth.net>
 Reply-To: zenith-list(at)matronics.com
 Subject: Re: Cortec 373 and airframe ground continuity
 Date: Thu, 25 May 2006 08:29:09 -0400
 ground
 side of
 continuity
 process of
 this. I
 realized all
 could
  > Any comments?
  > Rory
  > Lacombe, LA
 Ken Lilja
 601XL rudder done.
 FREE pop-up blocking with the new MSN Toolbar  get it now!
 http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
		steveadams
				 Posted: Fri May 26, 2006 3:25 am    Post subject: Re: Cortec 373 and airframe ground continuity |
				You will want to remove the primer and have bare metal wherever you connect a ground directly to the airframe, but I wouldn't worry about lack of continuity at the joints due to the primer. Even with some resistance due to the primer, there is such a huge surface area that I don't think it is an issue with the currents we are talking about. I am no expert, so you may want to search the aeroelectric list to see what they have said about it.
				 Posted: Fri May 26, 2006 4:13 am    Post subject: Cortec 373 and airframe ground continuity |
				I think insulation in the joints could ruin the ground provided by
 the airframe.  Even though there is a lot of good conductor between
 the joints something close to complete circuit isolation could take
 place at the joints.  If this happens there will be no ground
 connection at all for the remote circuits.
 The biggest problem (besides complete circuit failure) I would expect
 would be interference with radio clarity generated by the strobes.
 Fortunately, it is relatively easy to measure the impact of joint
 isolation.  Just measure the resistance from one end of the plane to
 the other with a multimeter.   I would be concerned with anything
 over 100 milliohms.  If the resistance is large the solution would be
 to run separate ground wires from the remote devices to the battery
 or common ground point.
 Paul
 XL wings
 recovering circuit designer
 At 04:25 AM 5/26/2006, you wrote:
  	  | Quote: | 	 		  You will want to remove the primer and have bare metal wherever you
		dredmoody(at)cox.net Guest
				 Posted: Fri May 26, 2006 5:47 am    Post subject: Cortec 373 and airframe ground continuity |
				The rivets should provide enough electrical continuity through the joints.
 Ed Moody II
 Rayne, LA
 601XL / wings
