Nastiest Yak Jobs
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
rijaeger(at)wausau.k12.wi
PostPosted: Fri Jan 13, 2012 6:09 am    Post subject: Nastiest Yak Jobs Reply with quote
Muscles I didn't even think I had are aching today from assuming the shape of a human cannonball inside the front cockpit while I painstakingly reattached my aileron push tubes to the stick bellcrank. Oh...that was FUN! And making sure that annoying little "keeper" is properly-oriented adds SO much delight. And then the cherry on top is the 1.5" of space you have to insert and configure that cotter pin...TWICE!
As someone once told me, I'd LOVE to hire one of the 3', 10-inch-fingered line-workers that built these machines to assist me!
OK, the complaints are light-hearted as I continuously remind myself I'm blessed to have the privilege and responsibility of being the current caretaker of this great aircraft. But as I'm finishing up the 5 hour job I'd originally set aside 1 hour to do, I started pondering what might be the nastiest duties to perform on a Yak. The aileron p/p tubes in the belly have to be in the TOP 10. But everyone reading this has more time (and scars?) on / from this machine than I. So...what do you think? What's the WORST Yak - or CJ - task?
GOOD WEEKEND TO ALL!
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
tigeryak18t
PostPosted: Fri Jan 13, 2012 9:27 am    Post subject: Nastiest Yak Jobs Reply with quote
I propose : Carb setting or air starter setting is also great !!!!
Didier
2012/1/13 Rico Jaeger <rijaeger(at)wausau.k12.wi.us (rijaeger(at)wausau.k12.wi.us)>
st" target="_blank">http://www.matronics.com/Navigator?M14PEngines-List
tp://forums.matronics.com
____________________________
Didier BLOUZARD Portable : +33 6 24 24 36 72
Email: didier.blouzard(at)gmail.com (didier.blouzard(at)anolistech.fr)
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
MONTY(at)bpaengines.com
PostPosted: Fri Jan 13, 2012 9:40 am    Post subject: Nastiest Yak Jobs Reply with quote
Changing the compressor is also a b----, even on the test cell.
Monty Barrett
jackpot
PostPosted: Fri Jan 13, 2012 10:04 am    Post subject: Nastiest Yak Jobs Reply with quote
Installing new elevator trim cable in CJ.
On Jan 13, 2012, at 9:37, "Monty Barrett Sr" <MONTY(at)bpaengines.com (MONTY(at)bpaengines.com)> wrote:
[quote] Changing the compressor is also a b----, even on the test cell.
Monty Barrett
jan.mevis(at)informavia.b
PostPosted: Fri Jan 13, 2012 12:06 pm    Post subject: Nastiest Yak Jobs Reply with quote
Finally, whatever job you have to do on these planes, when you start getting old(er), everything is difficult. It’s way easier for the young, slim, and very handy (but they lack the experience …).
For most of us, elder guys, it’s swearing and cursing all the time (at least it is in my case).
But once the job done, it is very rewarding.
Only my 2 cents: take your time, and be prepared to start all over again if it’s not good enough.
Jan
(already older generation, but I won’t give up yet)
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Gary Gabbard
Sent: vrijdag 13 januari 2012 19:02
To: m14pengines-list(at)matronics.com
Subject: Re: Nastiest Yak Jobs
Monty Barrett
PostPosted: Fri Jan 13, 2012 1:32 pm    Post subject: Nastiest Yak Jobs Reply with quote
I'm guessing I'm right there w/ ya on age, Jan! And I know what you mean in all you said. I went to bed making sure all my skinned knuckles wouldn't leave Yak Blood everywhere...woke up sore, but had that "O yea! DONE!" sensation! I'm fortunate to be able to work in my airport's heated maintenance facility where my A & P works on numerous other projects simultaneously. He's had pretty much an "advisory-only" role in the Yak yet has been extremely helpful. He sensed my frustration and asked if I was getting anywhere. When I replied "more slowly than surely" he asked if I'd tried swearing at it - said it was an old A & P trick. And when that fails to throw my wrench across the room...I DID recall I still have to go in and re-attach that darn little ground strap on the left side. There are many more hurdles to leap over but I'm LOVING the journey...and I have the REWARD dead in my sites! Smile
>> "Jan Mevis" <jan.mevis(at)informavia.be> 1/13/2012 2:03 PM >>>
Jan
Monty Barrett
dsavarese0812(at)bellsout
PostPosted: Fri Jan 13, 2012 2:16 pm    Post subject: Nastiest Yak Jobs Reply with quote
Also applies to the Yak 52. Equally a horrible job is replacing the
bungee cord on the Yak 52 rear slider canopy....ie:attaching it to the
rear attach bracket.... Smile)))
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/13/2012 12:02 PM, Gary Gabbard wrote:
[quote] Installing new elevator trim cable in CJ.
> Monty Barrett
PostPosted: Fri Jan 13, 2012 2:20 pm    Post subject: Nastiest Yak Jobs Reply with quote
Hey Monte - did anyone ever tell you that your suppose to wait until the
engine cools down before you remove the exhaust and surrounding
components to get at the compressor? Only kidding my friend. Enjoy
your weekend
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
Monty Barrett
Yak Driver
PostPosted: Fri Mar 16, 2012 5:33 pm    Post subject: Re: Nastiest Yak Jobs Reply with quote
Try fitting the grommets on the oil cooler hoses on a Yak 18T. The ones on the fuselage side, under the floor near the oil cooler. Great fun. Mad
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
