Electrical Gremlins
jonlaury
PostPosted: Sat Jan 14, 2012 8:53 am    Post subject: Electrical Gremlins Reply with quote
1.) I installed an EyeBeam Mini as a cabin light. It's in a housing that also contains the radio speaker. It gets its power from the battery bus.
Whenever I turn on the PS Engineering 7000B audio panel, or key the mike, the EBM starts flashing and is unresponsive to its on/off switch or built-in dimmer. The only way to get it to stop is to pull the power.
The dimming/switching are by capacitance sensing (touch). Everything in the airplane is connected to a single point ground.
Suggestions much appreciated
Very Happy
2.) I installed an AEC 9005 LVW module per instructions but the LVW lamp flashes (blinking LED) when I power the system from my bench 13.6v power supply.
3.) Same as 2 above for my B&C LR3 regulator. I did all of their troubleshooting diagnostics and everything was to spec.
Thanks for any help,
