				 Posted: Sat Jan 14, 2012 6:52 am    Post subject: Warp Drive prop |
				Ellery- Did anyone ever find out about the prop that came apart?  Last I remember, there was a discussion as to whether or not it was a stock factory Warp Drive.
                                               Bill Sullivan
                                               Windsor Locks,  Ct.
                                               FS 447, Warp Drive prop
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		elleryweld(at)aol.com Guest
				 Posted: Sat Jan 14, 2012 3:28 pm    Post subject: Warp Drive prop |
				Yes the NTSB report was finally finished up about 3 weeks ago it is a Warp drive Prop and I have been talking to a lawyer
    I am out an airplane and could have been out of life because of that Prop Who do they think they are using the public as
    a test bed for there props why wasn't there ever a service bulletin out on there props to prevent this from happening again this is not
    the first time this has happened to one of there props  from what the FAA has told me
      Ellery Batchelder Jr.
		herbgh(at)nctc.com Guest
				 Posted: Sat Jan 14, 2012 5:47 pm    Post subject: Warp Drive prop |
				May be old news?
   http://www.ultralightnews.com/
   http://www.ultralightnews.ca/advisories1/warpdrivefailure.htm
  Herb
  At 05:25 PM 1/14/2012, you wrote:
  [quote]Yes the NTSB report was finally finished up about 3 weeks ago it is a Warp drive Prop and I have been talking to a lawyer
				 Posted: Sat Jan 14, 2012 7:49 pm    Post subject: Warp Drive prop |
				ERA11LA150
		rmurrill(at)cox.net Guest
				 Posted: Sat Jan 14, 2012 11:31 pm    Post subject: Warp Drive prop |
				The “Full Narrative” doesn’t go into much detail, but the fact that all  three blades showed chordwise cracks as an apparent combination of fatigue and  static overload I would think would be a real concern.    The lab  report didn’t say so, but one would assume that is the precursor for the delams  and eventual shedding of parts.  The report has one phrase about “bending  forward under airload.”???   Some of the Warp hubs had the crack  problem a few years back, but I think most people consider the blades pretty  much bullet proof.   So seems to me you end up with two primary likely  scenarios.....you got three bum blades.....or, more likely, something in this  particular configuration caused higher inplane loads than normal and led to the  chordwise cracks.   In the certified world there would be a bunch of  expensive rotor dynamics manpower and computers calculating coupled modal  frequency placement followed by an order of magnitude more expensive strain  gaged flight test.
  One would hope that if there are other instances of “transverse” cracks in  the trailing edges of similar blades, then that information would be quickly  shared regarding types of aircraft and engine, time in service, etc. ..
  Sent: Saturday, January 14, 2012 8:47 PM
  Subject: Re: Warp Drive prop
   ERA11LA150
  -----Original  Message-----
 To:  kolb-list <kolb-list(at)matronics.com>
 Sent: Sat, Jan 14, 2012 10:42  pm
  Ellery, Do you have  the NTSB report #?
  Rick Girard
  On Sat, Jan 14, 2012 at 5:25 PM, Ellery Batchelder Jr  <elleryweld(at)aol.com (elleryweld(at)aol.com)> wrote:
   	  | Quote: | 	 		     Yes the NTSB report was finally finished up about 3 weeks ago it is a    Warp drive Prop and I have been talking to a lawyer
 From: william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)>
 To:    kolb list <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
 Sent:    Sat, Jan 14, 2012 9:52 am
 Subject: Warp Drive prop
                                                        Bill          Sullivan
                                                        Windsor Locks,          Ct.
  Zulu Delta
  Mk IIIC
  Thanks, Homer GBYM
  It isn't  necessary to have relatives in Kansas City in order to be unhappy.
   -  Groucho Marx
 get=_blank>http://www.matronics.com/Navigator?Kolb-List
 p://forums.matronics.com
 blank>http://www.matronics.com/contribution
				 Posted: Sun Jan 15, 2012 6:10 am    Post subject: Warp Drive prop |
 Kolbers:
 Be interesting to know the history of Ellery's Warp Drive Prop.  Wasn't it one of the first generation Warps? or very early on in WD's history?
 I have flown WD props since 1993 on my 582, 912UL, and 912ULS.  All have had the HP Hub.  That hub has been upgraded several times since I got my first one.
 Direct drive engines had problems with WD props because of the lack of torsional vibration dampening, if I recall correctly.
  _________________ John Hauck
Titus, Alabama |
		byoungplumbing(at)gmail.c Guest
				 Posted: Sun Jan 15, 2012 9:11 am    Post subject: Warp Drive prop |
				ok...   are we talking the warp blades of  the early foam core,,,  or the new warp designes?
  boyd y
  mkiii 912 warp drive 68 inch
				 Posted: Sun Jan 15, 2012 9:36 am    Post subject: Warp Drive prop |
				the older version of the warp blades  but they are not foam core  but I am not sure what it is ,its a tan color hard material
		rickofudall
				 Posted: Sun Jan 15, 2012 11:23 am    Post subject: Warp Drive prop |
				Warp Drive props still have some sort of core, but I cannot tell you what it is. When I cut one down last Monday the first thing I noticed was that the center of each blade was a light gray color surrounded by the black carbon surface material which is about .09 to .12 thick. This prop is a 2005 vintage.
 Rick Girad
 On Sun, Jan 15, 2012 at 11:33 AM, Ellery Batchelder Jr <elleryweld(at)aol.com (elleryweld(at)aol.com)> wrote:
 [quote] the older version of the warp blades  but they are not foam core  but I am not sure what it is ,its a tan color hard material
				 Posted: Sun Jan 15, 2012 1:49 pm    Post subject: Warp Drive prop |
 [b]Ellery Batchelder Jr.[/b]
 Boyd y
 [quote]************  Daryl sent me two sets of WD props to test on my Firestar in 1989.  Both sets were solid carbon fiber.  I didn't know they made a "cored" blade until Ellery had his fail.  BTW:  I didn't like the square tip or the fast taper tip blades.  I was hooked on Jim Culver's two blade with polyurethane edges.  Believe it was a 60X30 or 32, and worked perfect with the 447 and the FS. Seems that WD system (cored) should be well over 20 years old.  Don't think it stayed in production but a short time. john hmkIIITitus, Alabama [b]
Titus, Alabama |
				 Posted: Sun Jan 15, 2012 2:01 pm    Post subject: Warp Drive prop |
 [quote] *****************  That's hardly enough to call it a core. john hmkIIITitus, Alabama [b]
Titus, Alabama |
		flykolb(at)pa.net Guest
				 Posted: Sun Jan 15, 2012 3:05 pm    Post subject: Warp Drive prop |
				Isn’t Rick saying the carbon fiber surface material is only .09 to .125 thick?  (Grammatically that  is what he is saying.)
 If that is at the tip, it is one thing, but if that is at the thicker section at the root, then that is another.
 I would be interested to know where along the blade that section was cut from.
 Dennis
 From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck
 Sent: Sunday, January 15, 2012 4:59 PM
 Subject: RE: Warp Drive prop
  	  | Quote: | 	 		  |  *****************  That's hardly enough to call it a core. john hmkIIITitus, Alabama    | 	  01234567890123456
				 Posted: Sun Jan 15, 2012 3:34 pm    Post subject: Warp Drive prop |
 Dennis 	  | Quote: | 	 		  |    Dennis/Kolbers: Yes, you are correct.  I misunderstood what he was saying. I don't see a core in his photos. I have also cut off WD blades to shorten.  All I cut were solid.  | 	  01234
Titus, Alabama |
		bransom(at)ucdavis.edu Guest
				 Posted: Tue Jan 17, 2012 10:02 pm    Post subject: Warp Drive prop |
				Sorry for being into this thread late but I'd like to know Ellery, did you ever notice any signs of trouble on the prop prior to failure, such as the cracks or anything other than a normal smooth surface?
  -Ben Ransom
    From: Ellery Batchelder Jr <elleryweld(at)aol.com (elleryweld(at)aol.com)>
  Reply-To: <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
  Date: Sat, 14 Jan 2012 18:25:21 -0500
				 Posted: Wed Jan 18, 2012 6:33 am    Post subject: Warp Drive prop |
				there was no signs damage or defects of the propellor blades prior to the last flight even though I did have
     one of the hub plates crack and I sent to warp and purchased new hub plates 30 Hours prior to this
				 Posted: Wed Jan 18, 2012 6:57 am    Post subject: Warp Drive prop |
  	  | Quote: | 	 		  |    Ellery B/Kolbers: Correct me if I am wrong. The current version of solid carbon fiber WD blades has been in production since the early 1990's.  I tested a couple in the last 80's on the Firestar and started using them on my MKIII in 1993, first on the 582 and then the 912's. Weren't the blades you that failed on your MKIII a set of first run blades manufactured prior to the beginning of the solid carbon fiber blades?  | 	  012345678
Titus, Alabama |
				 Posted: Wed Jan 18, 2012 9:23 am    Post subject: Warp Drive prop |
				yes my blades are from the earlier version
				 Posted: Tue Jan 24, 2012 5:13 am    Post subject: Warp Drive prop |
				The reason I was asking about the identification of Ellery's prop is that the photo of the inside of it does not match photos others have posted.  I have an old WD with 2 sets of blades.  One blade was broken when I flipped the plane over.  The inside of that blade doesn't seem to look like any other photo posted.  The conversation has been quite informative.  I have used tap testing on various laminates at work, and wasn't aware that it could be used as a tool on the prop.  Come spring, I will check mine.  My FS is one of the very early ones- no serial number- and the engine and prop may be the same age.  No reason was given for the extra blades that came with it, but there had been a storm flip over.
   Based on all the comments, my gut feeling is that old WD's may be of different construction, and the  newer one's are much stronger.  I may just send all I have down to Daryl at WD for inspection.  If I can figure out my camera and post a photo, I'll try.  My computer skills leave a lot to be desired.
                                               Bill Sullivan
                                               Windsor Locks,  Ct.
                                               FS 447, WD
 --- On Sat, 1/14/12, william sullivan <williamtsullivan(at)att.net> wrote:
 From: william sullivan <williamtsullivan(at)att.net>
 To: "kolb list" <kolb-list(at)matronics.com>
 Date: Saturday, January 14, 2012, 9:49 AM
                                               Bill Sullivan
                                               Windsor Locks,  Ct.
  | 	   [quote][b]
