Uneven fuel feed CJ6
Goto page Previous  1, 2
wlannon(at)shaw.ca
PostPosted: Mon Jan 16, 2012 9:36 am    Post subject: Uneven fuel feed CJ6 Reply with quote
Pete;
What year is your CJ? If 1980 or later it could have the factory modified
flapper valves .
Pete Fowler
PostPosted: Mon Jan 16, 2012 10:07 am    Post subject: Re: Uneven fuel feed CJ6 Reply with quote
Mine's a 1966...with that dead flat tie-down, every time I got back to the plane the tanks were perfectly level and they'd stay that way all through flight (at least 2 hour flights which was the maximum I could do with the plane).
The other thing is that I spent a lot of time trimming the tabs so that at cruise speed, it was nearly hands-off. I also watch the ball frequently to be sure I'm not putting extra pressure on one foot (which is a normal tendency).
brian(at)lloyd.com
PostPosted: Mon Jan 16, 2012 10:40 am    Post subject: Uneven fuel feed CJ6 Reply with quote
On Mon, Jan 16, 2012 at 10:07 AM, Pete Fowler <pfdesign1(at)cox.net (pfdesign1(at)cox.net)> wrote:
--> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net (pfdesign1(at)cox.net)>
Pete, I agree with you 100%. Most of the time it IS a pilot-induced problem. But Walt is right too: there have been occasional problems with the flapper valves. My fix for that is to violently yaw the airplane.
BTW, you can fly 3.5 hour legs in a CJ6A with stock (42gal) fuel and legal reserves if you are careful. I have done several cross-the-US trips when I had mine (flying) and the ability to reduce the number of total hops reduces the total time to cross the country even though you may be flying at a lower true airspeed. A fuel stop consumes a lot of your potential flying time. Oh, and it costs less too. Smile
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
Page 2 of 2
