		stephen vestuti
				 Posted: Fri Jan 20, 2012 8:11 am    Post subject: Heater - From Ex. Silencer |
				Hi All,
 I am thinking about having a flange welded on to the exhaust
 silencer HEATSHIELD to accept a cabin heat assy. with hose out let
 to the stb. & port foot wells,
 has anyone tried this and if so is there enough " draft " from the
 silencer / heat shield gap to provide enough heat ?
 Steve.
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		pjeffers(at)talktalk.net Guest
				 Posted: Fri Jan 20, 2012 8:37 am    Post subject: Heater - From Ex. Silencer |
				Hi Steve,
 We have a classic Europa with pre XS engine installation and have for many
 years used air heated by only a small section of the exhaust surface area.
 The air flows into the cabin via 2" diameter scat hose and a butterfly valve
 (old Land Rover Carburettor throttle valve).  The flow is quite small, in
 fact very small but the cabin is so well sealed that we happily maintain
 20 c when the OAT is minus 5.
 Pete
		stephen vestuti
				 Posted: Sun Jan 22, 2012 12:52 pm    Post subject: Re: Heater - From Ex. Silencer |
				Thanks Pete,
 There's another builder that has fitted a heater so it has been done OK,
 I can now go ahead with more confidence,
 Steve,    Europa XS No. 630
		ploucandco
				 Posted: Wed Dec 26, 2012 8:17 am    Post subject: Re: Heater - From Ex. Silencer |
				Hello Stephen,
 Did you install your heater based on the muffler? Any specific recommendations to take into account? Do you have some pictures to share?
 Thanks, Jacques
		Roland
				 Posted: Wed Dec 26, 2012 11:49 pm    Post subject: Re: Heater - From Ex. Silencer |
				Hello Steve,
 I'm planning for a cabin heater installation based on a heat extraction from behind the oil cooler (http://www.customflightcreations.com/id18.html). I always considered this as the most obvious, simple and safe (no carbon monoxide) solution.
 Have you also checked this option and if so, I'm interested in the reasons why you decided against it.
 Roland
 PH-ZTI
 XS Trigear 914
