		wdaniell(at)etb.net.co Guest
				 Posted: Mon Jan 23, 2012 5:34 am    Post subject: Radio coax question |
				I am now installing my radio
 I have some left over RG58 A/U cable braided outer and core
 The question I have is :  I have Belden 8259 and Xcom recommends Belden 8219.
 Can anyone help me with the difference if any?
 Will
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jimpuglise(at)comcast.net Guest
				 Posted: Mon Jan 23, 2012 6:11 am    Post subject: Radio coax question |
				Will-
 There are all sorts of grades of RG58AU.  Some cable TV companies use it and it is trash.  Radio Shack sells it, and it is trash.  Other suppliers sell it and it is OK.  If you don't know the source, it is not worth the risk.  I'd either go with the manufacturer's recommendation or high quality RG-400
 Jim Puglise
 Europa XS
 Sent: Monday, January 23, 2012 8:31:26 AM
 Subject: Radio coax question
   <![endif]-->   <![endif]-->
 Will
		mcoates
				 Posted: Mon Jan 23, 2012 6:16 pm    Post subject: Re: Radio coax question |
				XCOM Here.....    we only recommend RG400 coax in all installations.   Thanks Michael Coates XCOM Avionics
		frans(at)privatepilots.nl Guest
				 Posted: Tue Jan 24, 2012 2:29 am    Post subject: Radio coax question |
				On 01/23/2012 02:31 PM, William Daniell wrote:
  	  | Quote: | 	 		   I am now installing my radio
 "Left overs" can be anything. A particular danger with coax is moisture
 creeping in at the ends. This causes huge losses. But if it hasn't been
 used outside it is probably ok.
  	  | Quote: | 	 		   The question I have is :  I have Belden 8259 and Xcom recommends Belden
  8219.
 Standard recommendation is always for high quality cable. The truth is
 that the lenght needed for your airplane is so small that the losses are
 not meaning anything. Use the cable with the lowest weight. I used RG58
 A/U for my europa and it works perfect.
 Frans
		stephen vestuti
				 Posted: Tue Jan 24, 2012 1:32 pm    Post subject: Re: Radio coax question |
				Will,
 I bought a new 100M drum of RG58 when I built my first Europa,
 if you need a length I can post it out to you free of charge - as long as
 you are in the UK !
 contact me off list,
 Steve,
 Europa XS No. 630
