Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Tue Jan 24, 2012 11:23 am Post subject: Fuses instead of breakers |
I really like the idea of using fuses rather than breakers. The ATC
style fuses look like a excellent product.
However, I cannot find any "slo-blow" versions. Do they exist ? How
do I decide on the size of the fuse when manufacturers of products
recommend a breaker or slow-blo fuse ?
For example, the Lightspeed ignition instructions suggest a 5A breaker
with an 18AWG wire. So a 7.5A or 10A fuse could easily be used with
that wire.
An ATC fuse typically blows at 125% of rating within a second, much
faster than a breaker. How do I know what the peak current is on
various devices to know that there will not be a nuisance trip (a
really bad thing for electronic ignitions) with a fast blow fuse ?
Jeff Page
Dream Aircraft Tundra #10
Posted: Tue Jan 24, 2012 1:30 pm Post subject: Fuses instead of breakers |
They are . . .
Excellent question. It's not always clear to me why
any given installation instruction calls for a "slow-blow"
fuse. WAAaayyy back when, one could purchase fuses for a
given current rating that offered different time constants.
In automobiles I've found that many fuses are way 'oversized'
to the task while still appropriate to protection of the
wire. I don't think there are any fuses in my mini-van under
10A and most are over 10A.
that wire.
The Lightspeed ignition draws about 2.8A max (full increase
RPM and highest operating temperature) so a 5A fuse is
quite adequate to the load. Heavier wire is sometimes called
out just for mechanical robustness even when the current levels
are low. I think I heard one ol' greybeard at Beech speak
to a policy of "no wires under 20AWG in the engine compartment."
Magneto's were wired with 18AWG shielded even tho much smaller
wire would have provided proper electrical function.
There was a rule of thumb years ago for always-hot battery
feeders not to be protected at levels above 5A. But that
rule of thumb got codified later:
Sec. 23.1361 Master switch arrangement.
(a) There must be a master switch arrangement to allow ready disconnection
of each electric power source from power distribution systems, except as
provided in paragraph (b) of this section. The point of disconnection must be
adjacent to the sources controlled by the switch arrangement. If separate
switches are incorporated into the master switch arrangement, a means must be
provided for the switch arrangement to be operated by one hand with a single
movement.
(b) Load circuits may be connected so that they remain energized when the
master switch is open, if the circuits are isolated, or physically shielded,
to prevent their igniting flammable fluids or vapors that might be liberated
by the leakage or rupture of any flammable fluid system; and
(1) The circuits are required for continued operation of the
engine; or
(2) The circuits are protected by circuit protective devices
with a rating
of five amperes or less adjacent to the electric power source.
(3) In addition, two or more circuits installed in accordance with the
requirements of paragraph (b)(2) of this section must not be
used to supply a
load of more than five amperes.
(c) The master switch or its controls must be so installed that the switch
is easily discernible and accessible to a crewmember.
Now interestingly enough . . . one can do an experiment where
a 5A breaker and a 10A ATC fuse are connected in series. Dead fault
the circuit on a 12v battery and the fuse always blows before the
breaker trips. From this I would deduce that a 5A breaker of the battery
bus which is compliant with the FAR cited above can be replaced by a
10A fuse in the same location and still be satisfy the design goal.
The 10A fuse is faster than a 5A breaker and dumps less energy into
the fault than a the breaker.
High inrush devices are generally limited to motors and incandescent
lamps. For those circuits, fatter fuses and commensurate increases in
wire size are not without reasonable justification.
Input to the Lightspeed ignition has, at most, a filter capacitor
preceding the switchmode power supply. A 5A fuse is fine. But given
the fatter-wire recommendations for installation, then a 7.5 or
10A FUSE PROTECTED feeder can be brought from the battery bus
without insulting design goals for crash safety cited in 23.1361(b)(2)
above.
For all other systems (not critical to keeping the engine running!)
the experiment is low risk. If you get nuisance trips, upsize the
fuse. You need not necessarily upsize the wire too. Keep in mind that
20A through a 22AWG wire will not burn the wire. See:
http://aeroelectric.com/Pictures/Wire/22AWG_20A.pdf
While your concerns are noteworthy, they can be addressed with
a very broad brush applying common sense. If I were building
an airplane today, I'd protect the electronic ignition battery
feeders at 10A and wire with 20AWG wire that still fits in
the smaller pins for fire wall penetration and/or interface to
the electronics. This offers a mechanically and electrically
robust feeder to the ignition that does not argue with crash
safety design goals.
fvalarm(at)rapidnet.net Guest
Posted: Tue Jan 24, 2012 1:44 pm Post subject: Fuses instead of breakers |
I used a lot of fuses (4 fuse blocks) and about a dozen breakers (for things
that I need/want control of in flight or during maintenance. I like to have
each on it's own circuit. I don't know of any Slo-blo fuses, but there may
be. It may be that you would simply use a higher value fuse. Something
that protects the wire against hard faults.
I was going to use Lightspeed but changed my mind to P-mags partially for
this reason, they are self powered once flying, therefore do not depend on
ship's power for normal operation.
Bevan
mauledriver(at)nc.rr.com Guest
Posted: Tue Jan 24, 2012 8:38 pm Post subject: Fuses instead of breakers |
You could use a breaker for this particular circuit. I haven't thought about electronic ignitions specifically but I too like fuses over breakers. But convinced myself to use 4 breakers anyway, 2 for the 2 voltage regulators, 1 for the AP, and one for the flaps. Not sure I would have used all 4 now that I've flown it a bit but it made sense to me at the time. So I still have 2 dozen fuses...
Just a thought.
Bil
Sent from my iPad
On Jan 24, 2012, at 2:16 PM, Jeff Page <jpx(at)qenesis.com> wrote:
I really like the idea of using fuses rather than breakers. The ATC style fuses look like a excellent product.
However, I cannot find any "slo-blow" versions. Do they exist ? How do I decide on the size of the fuse when manufacturers of products recommend a breaker or slow-blo fuse ?
For example, the Lightspeed ignition instructions suggest a 5A breaker with an 18AWG wire. So a 7.5A or 10A fuse could easily be used with that wire.
An ATC fuse typically blows at 125% of rating within a second, much faster than a breaker. How do I know what the peak current is on various devices to know that there will not be a nuisance trip (a really bad thing for electronic ignitions) with a fast blow fuse ?
Jeff Page
Posted: Wed Jan 25, 2012 8:53 am Post subject: Fuses instead of breakers |
As long as your wiring is adequately protected then
what you've installed is not "wrong" . . . just different.
If the voltage regulators are fitted with crowbar
ov protection, then panel mounted breakers are
indicated. If you believe that the AP and flaps
have failure modes for which you desire a crew
driven mitigation, then in-reach breakers are also
indicated. Some folks may find justification for
debating the rationale for your design but the
bottom line is this. What you've done does not
increase risk. It MIGHT drive some small risk to
a yet smaller value. But everybody hopes that you'll
fly this airplane throughout it's useful lifetime
never having encountered an urge to touch any of
those breakers in flight.
Dennis Johnson
Posted: Wed Jan 25, 2012 9:08 am Post subject: Fuses instead of breakers |
Hi Jeff,
Regarding what size fuse to use, I have a Lightspeed electronic ignition with a 5 amp fuse. In about 500 hours of flying, I've blown the fuse once. Don't know why it blew, and the engine kept running on the magneto. On the ground, I replaced the fuse and it's been fine since. Next time I have convenient access to the battery bus, I might put a 7.5 amp fuse instead.
Dennis
bicyclop(at)pacbell.net Guest
Posted: Wed Jan 25, 2012 9:27 am Post subject: Fuses instead of breakers |
Just one more thing to think about if you are doing this with a Lightspeed ignition. From what I've read, there is some sort of crowbar inside the ignition module to protect it from an overvoltage event. If a fuse is fitted and the crowbar kicks it, you'll not be able to reset it as easily as with a breaker - if you can reach the fuse at all. I've heard of at least one case where an airplane was brought down because it was wired differently than the installation instructions in that regard.
Ed Holyoke
On 1/25/2012 8:48 AM, Robert L. Nuckolls, III wrote: [quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> (nuckolls.bob(at)aeroelectric.com)
--> AeroElectric-List message posted by: Bill Watson <mauledriver(at)nc.rr.com> (mauledriver(at)nc.rr.com)
Posted: Wed Jan 25, 2012 9:48 am Post subject: Fuses instead of breakers |
| Quote: | Next time I have convenient access to the battery bus, I might put a
Good idea.
Posted: Wed Jan 25, 2012 10:00 am Post subject: Fuses instead of breakers |
Can you elaborate on what you've read and give us sources?
I'm unaware of any crowbar ov protection built into the
LSE system. Is this called out in any of their published
literature? I found this on the Lightspeed site:
Electrical System Requirements
All Plasma CDI systems can be used with 12 or 24 volt electrical systems. Input voltages above 35 volts or reversed polarity can cause system damage.
For this reason it is mandatory that all aircraft using Plasma CD Ignitions are equipped with over-voltage protection in their alternator charging system(s). Over-voltage protection is a requirement for certified aircraft. Power connection must be directly to the battery terminals to avoid voltage spikes and electrical noise. Aluminum should never be used as an electrical conductor for the Plasma CDI. Use only the supplied aircraft quality stranded wire.
Minimum supply voltage for starting is 6.5 Volts.
Minimum operating voltage is 5.5 Volts.
This statement argues against any built-in ov
protection. At the same time, the very wide operating
voltage for the system guarantees that a properly
designed 14v system will NEVER offer a threat to
the LSE system.
I am presently participating in an analysis of
cause and effect for simultaneous failure of
dual LSE systems. Root cause for that event
was a failure to craft a failure tolerant
architecture . . . a design goal which is foundation
for all efforts here on the AeroElectric-List.
It's a certainty that no builder who participates
here on the List will suffer such an event.
Bob . . . [quote][b]
Tundra10
Posted: Wed Jan 25, 2012 2:29 pm Post subject: Fuses instead of breakers |
I appreciate everyone's comments regarding sizing fuses.
The reference to the FARs regarding battery bus circuits was useful.
My design doesn't exceed those specifications. Fortunately, with an
amateur-built aircraft, no bureaucrat can claim that a 5A circuit
protective device would be the size of both the fuse and the circuit
breaker.
So a 10A fuse will probably work reliably with a Lightspeed ignition. Thanks.
How about another example ? The popular approach is to use a pullable
breaker for the hydralic pump for the amphibious landing gear. If I
use a switch and a fuse, what size fuse ? I appreciate that I can
always install a bigger fuse if nuisance pops occur, but it seems more
professional to do the initial design with a good idea that the
correct fuse was chosen in the first place
So, does this logic work ?
The pressure switch deactivates the pump at 500psi, but there will
likely be short term pressure spikes above that. So, pick 1000psi.
The current versus pressure chart for the motor, shows 3A at 500psi
and 5A at 1000psi, as well as 23A at 3000psi, which is probably almost
stalling the motor. So assume a typical current of 3A and spikes of
less than a half second to 10A.
Since a 10A fuse should blow after 1 second with 12.5A, that should be
sufficient to avoid a nuisance pop ?
During that half second, I want full power to the motor, so I will use
10A for the gauge versus wire length calculation. To drop 5% power
through wire resistance, that gives me 18' for 16AWG wire. I should
be able to get to the pump and back in less than 18', so 16AWG should
be sufficient.
A 30 degree rise for 16AWG wire requires 19A, so I could safely upsize
to a 15A or 20A fuse.
With your experience, should I start with a 10A or 15A fuse and expect
it not to nuisance trip ?
Are there any other reasons why a pullable circuit breaker would be
preferred for this situation ?
Jeff Page
bcondrey
Posted: Wed Jan 25, 2012 6:34 pm Post subject: Re: Fuses instead of breakers |
I'll second the earlier comment on LSE ignitions having a crowbar setup. I had initially installed fuses to power a dual Plasma III setup. During a discussion with Klaus he quickly took exception to this and told me verbally that they DID have a crowbar setup (but I did not get into a discussion with him about the triggering criteria). Since it's a pretty long wire run in an RV-10 from the standard battery location to where the ignition boxes are located, he recommended having 7.5 amp CBs on the panel and if I felt the need to protect the feeders (he didn't) from the batteries to use 10 amp CBs back there, guaranteeing that the 7.5s would be what tripped during whatever event trips the crowbar.
His very clear preference is to simply run the shielded, #18 (I think) wire all the way back and direct connect to the battery. I couldn't in good conscience live with a pair of always hot, unprotected wires for a run of that long and replaced the fuses near the batteries with 10 amp CBs and put 7.5 amp CBs on the panel as he recommended.
Above conversation took place with him about 3-4 years ago but I remember it very clearly.
Bob C.
Posted: Wed Jan 25, 2012 6:52 pm Post subject: Fuses instead of breakers |
breaker.
Who said anything about regulations? Just because it's
in a holy-watered book doesn't mean it's not a
valuable ingredient in a recipe for success.
Absolutely.
breaker for the hydraulic pump for the amphibious landing gear. If I
BIG and beefy . . . in fact for things like hydraulic pump
motors you would consider ANL style current limiters. That's
what we used on the Beech products.
Absolutely!!!!! Which is why we have the List. There are
fuses, then there are Fuses and then FUSES. Circuit breakers
come in many flavors of operating speed too. The differences
can be significant in crafting a trip-free system. Recall
years back we discussed the fact that there are tens of
thousands of TC aircraft flying with an alternator b-lead
breaker designed to nuisance trip? 60A circuit breakers
on 60A alternators. An alternator that will put out MORE
than 60A under some conditions.
Don't agonize over it. You're wanting to protect what size wire?
Scratch that. Wire with 10 AWG and use an ANL35 or equal. 10AWG
is plenty heavy and will reduce voltage drop in the system. It's
the 10x inrush current of what is probably a PM motor that drives
the selection of protection . . .
be sufficient.
I'd go with the 10AWG. If 23A and 5000 PSI is a data point, then
its doubtful that the motor is anywhere near stall. I'll bet inrush
is 2 to 3 times that amount.
What controls the pump motor . . . a contactor?
Is it tailored for intermittent duty, hi-inrush
service like a starter-contactor? Sticking of this
device might pose an in-flight concern. However,
if you have a dual path e-bus, you can kill the
main bus and shut down a runaway pump motor while
retaining the electro-whizzies needed for comfortable
completion of flight.
Your question goes to exactly the kind of exercise
every electrical system benefits . . . failure mode
effects analysis, "What if . . . and how do I deal
with it as a maintenance event as opposed to an
emergency?" If an FMEA calls for a second disconnect
such as a pullable breaker, then by all means.
Worrying about poorly considered failures tends to
stack redundancy on top of redundancy. It drives up
parts count, cost of ownership and adds to system
complexity. Complexity makes the pilot's job more
difficult and risky. Well considered FMEA tends
to produce the elegant solution: Just enough hardware
with minimum risk and simpler to operate.
Posted: Wed Jan 25, 2012 6:55 pm Post subject: Fuses instead of breakers |
| Quote: | During a discussion with Klaus he quickly took exception to
Hmmmm . . . I'll be seeing Klaus in the not too distant
future. I'll inquire.
loboflyer(at)gmail.com Guest
Posted: Wed Jan 25, 2012 7:51 pm Post subject: Fuses instead of breakers |
Bob, please do. In the meantime, for those of us just getting to wiring, would this be reasonable, or overkill?
Battery Bus Input terminal (not fused) ---> Fusible Link ---> Panel Breaker ---> Switch ---> LSE box?
I'm not sure how ground would best get there since Klaus calls out shielded wire and it might be a little bit of a run to the FW ground or battery ground.
Thoughts? (Or am I overthinking this?)
-Jeff-
On Wed, Jan 25, 2012 at 7:52 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Posted: Wed Jan 25, 2012 8:31 pm Post subject: Fuses instead of breakers |
At the moment, I see no reason to treat the LSE
ignition system any differently than any similar
system offered to the TC aircraft world.
If based on what I know now, I'd go 10A fuse at
the battery bus driving a 20AWG non-shielded wire
to an ON/OFF switch on the panel and then to the
ignition system.
or battery ground.
Shielded wire for this application is completely
unwarranted. There is no potential antagonist/
victim scenario which would capacitively couple
into our out of the LSE product. Grounding of the
LSE ignition module should be no more complex
than to take a 20AWG wire to the firewall ground
bus.
I don't think so. Klaus worries about some things
that are either insignificant or non existent. "Noise"
on the bus is NOT mitigated by connecting to the
battery. I think I explain this in the battery
chapter of the book. Batteries are simply not
filters of any small excursions of bus voltage
at any frequency.
This is precisely why DO-160 and Mil-STD-704
tell the TC aircraft designer to EXPECT certain
kinds of noise on the ship's DC bus. See:
http://www.aeroelectric.com/Pictures/Curves/MSTD704_28V_Noise.jpg
That flat top in the plot between 1 and 5 Khz
is 1 volt RMS or about 3 volts peak to peak
on a 28 volt system. Cut those numbers in half
on a 14 volt system. The amplitude for expected
noise falls off on either side . . . but the
point is, NOTHING . . . especially the battery
will mitigate this noise. Hence the admonition,
"It's there son, learn to live with it."
Indeed we who have run the gauntlet on qualification
for TC aircraft have learned to live with it . . .
in face, it's such a benign stress that "dealing
with it" is not even much of a technically intellectual
exercise.
It makes no sense to build crowbar ov protection
into a product when it's so easy to build passive
shutdown protection. I did this little fast-disconnect
switch to qualify an automotive seat warmer onto
a 28v aircraft.
http://aeroelectric.com/Pictures/Schematics/80v_Surge_Protection.jpg
this circuit simply 'disconnects' the vulnerable
device from the bus during the transient and reconnects
when the event is over.
But more important is the fact that in a 14 volt
airplane, the maximum alternator-runaway event is
limited to 20 volts . . . which is well inside the
LSE's NORMAL operating voltage.
Finally, you could treat a robust feeder from
battery to ignition system just like a fat feeder
to the e-bus. It might look something like this:
http://aeroelectric.com/Pictures/Schematics/Battery_Feed_for_Ignition.pdf
This satisfies the design goals for crash safety
by having a pilot operated disconnect at the battery.
The relay only draws about 100 mA so it's not a big
budget energy consumer for battery only operations.
Modern relays are quite reliable . . . and this one
gets pre-flight tested.
Point is there's a lot of ways to skin cats-of-
legitimate-worry. The task is to separate real worries
from bogus worries.
Posted: Thu Jan 26, 2012 4:47 am Post subject: Fuses instead of breakers |
P.S. to previous post.
I too would like to see an ignition system power from
the battery bus. NOT for reasons of noise but for
reasons of risk mitigation. When I have smoke in the
cockpit, I'd like to KILL the entire electrical system
without causing the engine to stop. This is why I've
advocated that ANY electrically dependent engine get
power directly from battery busses. This philosophy
is illustrated in the Z-figures.
Paul Valovich
Posted: Thu Jan 26, 2012 7:01 am Post subject: Fuses instead of breakers |
I built my RV-8A referencing Z13/8: forward mounted battery, one LSI, one mag. Three fuze blocks in fwd baggage compartment inaccessible in flight. Three panel mounted CBs – Alt Field, Aux Alt Field and LSI.
I do not feel that a fuze-blowing event for most circuits would benefit from restable CBs – something caused the initial overvoltage and chances that the fix is a reset CB are very slim. Design redundant systems, include internal avionics batteries where it makes sense, execute proper failure procedures, land as soon as practicable – or as soon as possible – and sort it out on the ground.
For the normal and backup alternators – and LSI – I felt that there was benefit from a reset capability. Nuisance trips, one time spikes, intermittent short, etc. I just might need the few minutes (perhaps) between trigger events to land.
140 hours of trouble-free electrons so far.
Paul Valovich
N192NM
bcondrey
Posted: Thu Jan 26, 2012 12:01 pm Post subject: Re: Fuses instead of breakers |
FWIW, this subject has been discussed before on the AeroElectric list. Use the search function for the words "Klaus" and "crowbar" and you'll find a couple threads from early 2009. Turns out that it's not just over-voltage events that will cause them to crowbar but apparently over-temp. This was posted on Feb 1, 2009:
"I have had to do one inflight reset on the Plasma III on one system
once. The reset was successful and power was restored to the unit. I
removed the unit and sent it back to Klaus for inspection. The fault
was determined to be an overheat situation. That unit was located in
an area without any real ventilation and without an form of cooling
while operation in Arizona during the summer. the compartment temp
was estimated to have exceeded 200 deg. F. The unit was modified to
the latest version (lower heat output components and a ventilation
port. The aircraft was modified to provide air circulation in that
compartment. After 300+ hours on that unit no faults noted. The
point, when the unit faulted it tripped the CB and was then reset and
provided service throughout the remainder of that flight. "
Without getting into the discussion of whether the design should or shouldn't be modified, my purpose on posting (now and back in early 2009) is simply to make those with dual LSE ignition setups aware that fuses can't be arbitrarily substituted for CBs in this case.
Bob C
Tundra10
Posted: Thu Jan 26, 2012 12:46 pm Post subject: Fuses instead of breakers |
| Quote: | The reference to the FARs regarding battery bus circuits was useful.
breaker.
I merely meant that a 5A fuse and a 5A breaker behave differently, but since
the protection type is not specified, the rule could be interpreted as
a maximum
of a 5A fuse.
| Quote: | Are there any other reasons why a pullable circuit breaker would be
The float manufacturer (Montana) supplies the pump and control circuitry
already mounted. The relays are Bosch 12V/20A 0 332 209 137
The diagram shows a 25A pullable breaker feeding the relays. A 1A fuse
protects the relay control wiring. So a pullable breaker would be a
convenient
way to deal with a stuck relay or a defective pressure switch. That
is perhaps
what I should do.
I will be interested in the results of your discussions with Klaus
about powering the Lightspeed ignition. I know two people who are
about to install these.
Thanks again for all the great advice. Even while lurking, I learn
something new
and useful every week !
Jeff Page
longg(at)pjm.com Guest
Posted: Thu Jan 26, 2012 12:57 pm Post subject: Fuses instead of breakers |
I tried the "fuse" test once. The test was to install the P-III with a fuse and see if I could guess where I might be when it fails. Mine failed on the run-up pad. I promptly pulled up to the hangar and wired it directly to the battery per Klaus's instructions. I always figured he wrote them for a reason. Been working ever since. I mounted mine upside down on the bottom of the avionics panel where they get plenty of fresh air.
Best Wishes,
Glenn
