MK3X Fiberglass wing tips
sconner
PostPosted: Fri Jan 27, 2012 3:53 pm    Post subject: MK3X Fiberglass wing tips Reply with quote
Was watching some you tube videos,and saw an MK3 that had fiberglass wing tips. Are these most likely custom built by the builder or is there a source for these?
Scott
Mike Welch
PostPosted: Fri Jan 27, 2012 5:03 pm    Post subject: MK3X Fiberglass wing tips Reply with quote
Scott,
Kolb Aircraft 'may' offer fiberglass tips for the Xtra. They did install a set on their factory demo Xtra once.
As far as making droop tips a common factory option, you'd have to ask them. Call Travis (at) Kolb Aircraft.
"Some" guys have built their own droop tips. Here is a picture of mine that I made for my plane last year.
Mike Welch
MkIII
Scott
http://forums.matronics.com/viewtopic.php?p=364995#364995
 Filesize:  126.31 KB
 Viewed:  4330 Time(s)
 Filesize:  126.81 KB
 Filesize:  115.32 KB
sconner
PostPosted: Sat Jan 28, 2012 6:44 pm    Post subject: Re: MK3X Fiberglass wing tips Reply with quote
Thanks Mike.
By the way yours look really good, nice work.
