Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
JonSmith
Posted: Tue Jan 31, 2012 11:55 pm Post subject: Throttle Cables |
My throttle cables are a bit stiff, particularly when reducing power at low power settings. Increasing power is fine. I think I have the cable routing the best I can achieve and the binding is definitely in the cables and not the throttle box itself. The throttle lever arms on the carbs seem nice and free and the springs seem in good order (the throttle opens nice and smoothly).
With the cables dismantled should I lubricate the cables? Squirt some WD40 down the outers perhaps? Currently they are installed dry.
Cheers, Jon
_________________ G-TERN
Classic Mono |
mau11(at)free.fr Guest
Posted: Wed Feb 01, 2012 1:19 am Post subject: Throttle Cables |
Hi Jon,
In the pas I have the same problem I take another way, Piano wire.
I use this perfect solution since 10 years if you are interested I send to you a Pdf Doc off line.
Michel AUVRAY
Builder mono 145
wdaniell(at)etb.net.co Guest
Posted: Wed Feb 01, 2012 6:04 am Post subject: Throttle Cables |
Me too please – I remember seeing several threads about this
BTW I have just had an issue which caused my heart rate to go up a tad. One of the cables was sticking causing one throttle to be about 90% while the other was 100%. Caused significant vibration…
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
Sent: 01 February, 2012 04:15
To: europa-list
Subject: Re: Throttle Cables
Hi Jon,
Michel AUVRAY
Builder mono 145
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234567
klinefelter.kevin(at)gmai Guest
Posted: Wed Feb 01, 2012 6:20 am Post subject: Throttle Cables |
I replaced the cable sheaths that came with the kit and went to the bike shop and bought Teflon lined sheaths. Smooth.
Kevin
On Feb 1, 2012, at 6:00 AM, "William Daniell" <wdaniell(at)etb.net.co (wdaniell(at)etb.net.co)> wrote:
[quote]p.MsoNormal {margin-left:7.5pt;} <![endif]--> <![endif]-->
Will
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
To: europa-list
Hi Jon,
Michel AUVRAY
Builder mono 145
01234567
8
g-iani(at)ntlworld.com Guest
Posted: Wed Feb 01, 2012 6:57 am Post subject: Throttle Cables |
Kevin
Teflon lined cable sheath is very nice and smooth but I would be cautious about using it. I had some installed on my heater inlet valve (above and behind the radiator duct, so not near the exhaust). At some stage the Teflon melted and locked the cable solid. Not something you would want to happen on a throttle cable. It could be that the cable I used was sub standard.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
europapa
Posted: Wed Feb 01, 2012 7:29 am Post subject: Re: Throttle Cables |
As it goes I just replaced my cables last Sunday. (Believe it ore not, it took me 5 hours. )
I have been alarmed as the right carburetor did not fully open as I engaged the throttle in the cold hangar. The part outside of the housing bend instead of moving into the housing. Don't want to experience this during a flight!
I also used high end bike parts (Jagwire) to replace them. (The original cables have got a very poor quality).
I want to encourage at least the builders that have not already installed the
cables that came with the kit to use a better quality ones.
Now the cables are pulled by the carburetor spring instead of pushed by the throttle arm.
Regards Juergen
Posted: Wed Feb 01, 2012 8:13 am Post subject: Throttle Cables |
Perhaps some testing would be a good idea.
The sheaths I installed during the build have performed perfectly for nearly 400hours now.
Kevin
On Feb 1, 2012, at 6:54 AM, "G-IANI" <g-iani(at)ntlworld.com (g-iani(at)ntlworld.com)> wrote:
Kevin
e-mail g-iani(at)ntlworld.com (g-iani(at)ntlworld.com)
cs.com
matronics.com/contribution
Posted: Thu Feb 02, 2012 12:32 am Post subject: Throttle Cables |
Hi! Juergen,
It is my understanding that the original type of cables should always have
been spring pulled to fully open (in the event of cable breaking ) at no
time were they to be used in the "push" mode. In my opinion the most likely
cables to be used to have a push or pull capability would be a Boden cable
specifically designed for such application and also specifically length
sized also, but as good as they are it would be unlikely that the existing
springs would be suitable under such arrangement .
Bob Harrison G-PTAG .
europapa
Posted: Thu Feb 02, 2012 5:07 am Post subject: Re: Throttle Cables |
Hello Bob,
due to my basic English I am not sure what you want to tell me.
I too think that the cables always should be pulled by the springs.
In my case the were pushed caused by to high friction.
That´s why I replaced them.
But maybe I got something wrong.
Regards Juergen
Posted: Thu Feb 02, 2012 6:24 am Post subject: Throttle Cables |
Hi! Juergen
Your first e-mail on the subject seemed to indicate that before you had the
plane the cables were PUSHED by the throttle then you changed it.#
Bob H G-PTAG
europapa
Posted: Thu Feb 02, 2012 8:10 am Post subject: Re: Throttle Cables |
yes Bob,
they have been pushed due to a suboptimal routing and the high inner friction. Now with the old, cold grease the possible, dangerous potential became obvious.
Juergen
graeme bird
Posted: Sat Feb 25, 2012 11:14 am Post subject: Re: Throttle Cables |
I am just getting checked out on G-UMPY after build. I used piano wire from Airworld/jodel as the originals started kinking. Trouble is these are now stiff and sticking. I had to stop flying dismantle, oil and re route. It seems they should really be longer and either PFTE coated wire or a coated housing. The orginal stranded ones are lower resistance but maybe it was the routing that was the real culprit. Not sure whats best now.
_________________ Graeme Bird
G-UMPY
Mono 912S/Woodcomp 3000/3W
Newby: 55 hours 1 year
g(at)gdbmk.co.uk |
rlborger(at)mac.com Guest
Posted: Sat Feb 25, 2012 6:09 pm Post subject: Throttle Cables |
Graeme,
I replaced my kinked, stranded wire with solid, teflon coated wire purchased from McMaster-Carr here in the States ( McMaster.com ). There's probably a similar product available in the U.K. It seems to be working well, but only 25 hrs on it so far. Hopefully, more time will be accumulated starting next month.
If I were doing again today, I'd probably go with hi-tech, teflon, cycle brake cable and sheath ( Amazon.com search: teflon brake cable ).
Perhaps I'll try that over next winter down time.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Feb 25, 2012, at 1:14 PM, graeme bird wrote:
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Just waiting for the Permit to Fly to arrive after submitting test flight report
G(at)gdbmk.co.uk
