johngilpin
Posted: Mon Jan 30, 2012 3:02 am Post subject: FireFly CofG |
I've been searching the archives for info regarding the CofG of FireFlys. All seem to end up pretty near the specified aft limit, but then it's a pretty mixed message, some quite comfortable with the CofG right back there, and some finding that they needed to carry weight in the nose for comfortable handling....
I'm inquiring because I've bought a FireFly that's waiting for me in Mississippi (I'm coming over from Australia in March to start to fly it.). I note that it has a 447 with C-box, clutch, and three-blade prop, and I only weigh about 160lbs, so it sounds like it'll be right back at the specified limit, if not even farther aft.... I've done enough flight testing in other aircraft to know not to believe all manufacturers numbers, and not even necessarily conventional 'wisdom'. It's actual performance, as determined by real life flight time, that really tells the story.
Is there anyone who has experience with this combo on the FireFly??
The reason I ask now before flying it, is that I have a spare B-box here that I can bring along if it would turn out to be necessary to swap it.....
JG
zeprep251(at)aol.com Guest
Posted: Mon Jan 30, 2012 3:39 pm Post subject: FireFly CofG |
JG.
Have you ever ridden a small boat over the wake of another boat?That's the feeling I experience in a Kolb in rough air if it is aft cg wise.A quick pitch up, then back to aerodynamic neutral,You can fly it,you can land it slightly aft,it just FEELS so much more stable if it.s closer to the center.Wear your lead soled shoes or bite the bullet and stick some weight up front,maybe a storage compartment in the nose cone where you can keep a heavy lunch.
G.Aman MK3C Jabiru 2200A 670hrs currently in Lakeland FL
johngilpin
Posted: Wed Feb 01, 2012 3:00 am Post subject: FireFly CofG |
| Quote: | >stick some weight up front, maybe a storage compartment in the nose cone where you can keep a heavy lunch.
Good idea. I really don't like to carry lead, but food and water is good. In the remote areas that I like to fly I always like to carry plenty of water anyhow. So I could live with a couple of water bags and some canned food right in the nose... If there's room....
My main concern is that a high thrust line pusher is a real trap for aft CofG. The prop thrust gives a nose-down moment, balancing the nose-up moment of the aft CofG, making it all balance well, until the engine stops........ and then that high thrust line suddenly becomes a high drag line, and then both the high drag line and the aft CofG nose-up moments are summed. At the same time the elevator authority is much reduced by the lack of prop blast. Kolb flyers know this from experience, and some have learned the h-a-r-d way..... I've had a couple of off-list emails strongly cautioning me to keep power on right to touch-down, and I take that advice seriously. I'm used to always pulling power at base leg and glide approach all the way to touchdown, but certainly won't be doing that in the FireFly, at least in the beginning. But still need to practice dead stick landings just in case.....
[b] | Quote: | [b] | Quote: |
| Quote: | Not sure of his plans after the tour.
| [/b]I think the costs and hassles wouldn't be worth it to ship it to Aus. And besides, I don't have to be restricted to the Cat-103 over here, so can have two seats, and more range.....
| [/b]
pj.ladd(at)btinternet.com Guest
Posted: Wed Feb 01, 2012 3:19 am Post subject: FireFly CofG |
I'm used to always pulling power at base leg and glide approach all the way to touchdown,>>
If the C of g is anywhere close to where it should be thats fine. I always use a trickle of power on the approach and close the throttle on finals in my Xtra.
The effect of the high thrust line is exaggerated in my opinion. You just deal with it automatically .
From Oz?. Why don`t you buy a Thruster? Good with a 503. Better with a Jabiru.
Pat
Posted: Wed Feb 01, 2012 6:01 am Post subject: FireFly CofG |
JC G/Kolbers:
Don't need power if you simply push the nose down to glide.
Since 1984, when I built and flew my first Kolb, I have made it a habit to
shoot landings at idle power settings just in case the two stroke quit. In
the early days two strokes had a habit of quitting at idle and just when you
needed power. I figured if I could make the field at idle, I could make the
field with dead stick. I carried through with the same habit of flying my
Kolb with the 912 engines for the last 19 years.
Carry power if you can't fly the Kolb.
Never had a problem of lack of elevator authority with a Firefly power on or
off.
Never had a cg problem with a Kolb unless someone built it with drastic
modifications that would change the cg of a plans built Kolb.
I like JC's comment of not carrying lead, but substitute cargo and survival
gear and supplies.
If my MKIII flies well with a 12+ lb Maule Tundra Tail Wheel, I don't think
I have an aft cg problem, power on or power off.
Kolb "quit" only happens to Kolb pilots that land above the airstrip and not
on it. Takes airspeed to stay above the stall.
_________________ John Hauck
Titus, Alabama |
Posted: Wed Feb 01, 2012 11:54 am Post subject: FireFly CofG |
Date: Wed, 1 Feb 2012 20:58:08 +1000
JP,
| Quote: | .......................
of the aft CofG, making it all balance well, until the engine stops.........
This is not the case. The high thrust line is above the profile drag
center. If the engine and thrust line is trimmed for level flight at cruise
and the engine quits, at that instant there will be no difference in profile
drag and wing drag. If the thrust line is pointing down at cruise, it will
try to hold the tail up and once the engine dies the nose will want to come
up. etc. If you let the nose pitch up wing drag and profile drag will
increase. So in all cases the best thing to do when the engine quits is to
move the stick forward and maintain best glide speed. Profile drag will
remain almost constant but wing drag will be reduced.
| Quote: | At the same time the elevator authority is much reduced by the lack of prop
blast.
Not so. Standard FireFly configuration puts very little if any air over the
horizontal tail surfaces. See:
http://jackbhart.com/firefly/firefly129.html
| Quote: | Kolb flyers know this from experience, and some have learned the h-a-r-d
beginning.
There is no reason not to pull power at the base leg, just keep your pattern
tight and keep the air speed over 45 mphi or higher. One of the best things
you can do to prepare your self for an engine out is to practice higher and
higher pattern approaches, closing the throttle at the same point and
learning how to spill altitude and to touch down at the same spot on the
runway.
Jack B. Hart FF004
Winchester, IN
Posted: Wed Feb 01, 2012 12:16 pm Post subject: FireFly CofG |
runway.
Jack B. Hart FF004
Jack H/Kolbers:
That was a good post.
However, you could saved a lot of typing by saying: "Fly the airplane."
It's pretty simple.
Most folks that have problems flying a Kolb don't fly the airplane and blame
it on the Kolb, i.e., Kolb quit and can't land without power.
Titus, Alabama |
herbgh(at)nctc.com Guest
Posted: Wed Feb 01, 2012 12:31 pm Post subject: FireFly CofG |
Good points Jack....do not think I ever want to be in an airplane
that will not glide.. even 6 to 1 is better than 1 to 1.... Herb
At 01:55 PM 2/1/2012, you wrote:
JP,
blast.
beginning.
runway.
Jack B. Hart FF004
Winchester, IN
neilsenrm(at)gmail.com Guest
Posted: Wed Feb 01, 2012 6:33 pm Post subject: FireFly CofG |
Our Kolbs have a tremendous capability to fly in and out of very short fields. The very steep approach angle with very little flair time is necessary to be able to complete incredibly short landings. It's what they were designed for. Pilots new to Kolbs are advised to maintain power on approach right down to the landing flair. Later after a few landings it is good to start gradually exploring the planes capability but go slowly. My GA experience made my transition to my Kolb more difficult. John is right it is just a simple matter of maintaining flying speed. It really is that simple. The problem is pilots new to Kolbs aren't prepared for the visual impact of seeing the high ground closure rate up so close and personal. The natural reaction is to flare way too high and without power, flying speed is lost very quickly and that isn't good. So we have a very well designed airplane, we just need to learn how to fly them properly to be able to use all their capabilities. In summery there is no such thing as Kolb quit there is only pilot quit.
Rick Neilsen
Redrive VW Powered MKIIIC
On Wed, Feb 1, 2012 at 3:11 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
runway.
Jack B. Hart FF004
Jack H/Kolbers:
It's pretty simple.
http://forums.matronics.com
le, List Admin.
capedavis(at)yahoo.com Guest
Posted: Wed Feb 01, 2012 7:14 pm Post subject: FireFly CofG |
John and Jack and Kolbers , I agree that is no reason to not pull the power at base i was in the habit of pulling power as soon as I turned downwind but that was from flying Gliders thats why I believe that the best training one can get for any light powered aircraft is in a Glider , there you learn to fly the aicraft you learn to be infinitely variable as things change what you do changes you got to land the aircraft the first time everytime, there are no gorounds, there is no blaming the aircraft because the training gliders 2-33 or the equal have been landed successfully in every condition , its all you, just fly the aircraft . just my 2 cents Chris
Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly
Sent: Wednesday, February 1, 2012 3:11 PM
Subject: RE: Kolb-List: Re: FireFly CofG
runway.
Jack B. Hart FF004
Jack H/Kolbers:
It's pretty simple.
Tit.matronics.com/Navigator?Kolb-List" target=_blank>http://www.matronics.co========================
johngilpin
Posted: Thu Feb 02, 2012 1:36 am Post subject: FireFly CofG |
OK, that all sounds just fine. I'm used to diving at the ground on final approach, with plenty of airspeed right to a round-out just in time, then holding off one foot above the ground until airspeed decays such that it absolutely can't fly any more. That's just the way I flew my Spectrum Beaver for 1000 hrs. Somehow I'd got the impression that the Kolb was different, but now I'm really looking forward to this.
Thanks for all the input.
JG
Posted: Thu Feb 02, 2012 4:18 am Post subject: FireFly CofG |
JG
[quote] The Fire Fly is a scaled down Sling Shot. With a 40 hp engine it is a little hot rod, very agile, quick roll rate. It does well in rough air. john hmkIIITitus, Alabama [b]
Titus, Alabama |
Posted: Thu Feb 02, 2012 10:56 am Post subject: FireFly CofG |
Listers'
99% of my MK3 landings,short spring steel gear legs,are full stall 3 point events.Approach with engine at idle,Jabiru 2200a 900rpm static idle,and w/vg's.Only with stiff cross winds do I wheel land it or use some power .It's just like any other tail wheel aircraft.
G.Aman
rickofudall
Posted: Thu Feb 02, 2012 1:01 pm Post subject: FireFly CofG |
Gary, Ken's Mk III has the wings set at 2.8 degrees relative to the engine mount and has the long steel tube gear. I tried a full stall landing, she landed tail wheel first. Hence I wheel her on three.
Rick
On Thu, Feb 2, 2012 at 12:51 PM, Gary Aman <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
[quote] Listers'
G.Aman
Posted: Thu Feb 02, 2012 1:19 pm Post subject: FireFly CofG |
Rick,
What is the plans built angle for the old MK3?
Gary
Posted: Thu Feb 02, 2012 6:54 pm Post subject: FireFly CofG |
Listers'
G.Aman
Me too, Gary.
I also use full flaps (40 degrees), unless strong cross wind
or at "real" airports with long runways.
If I stall above the ground, the aircraft will drop, whether
Kolb, Cessna, or Piper.
Woodville, Florida
Titus, Alabama |
Posted: Thu Feb 02, 2012 7:06 pm Post subject: FireFly CofG |
Rick
Don't pull the nose up so high.
The US three points perfectly.
My original FS did too, because it had 35.5" long main gear
legs.
My MKIII does the same because the main gear have been
reconfigured and got the nose in the air.
Titus, Alabama |
Posted: Thu Feb 02, 2012 7:12 pm Post subject: FireFly CofG |
Rick,
Gary
It is variable, depending on how the builder interpreted the
rigging insturctions. I'll bet there aren't many rigged the
same. Doesn't make a whole lot of difference. Most of us
would never be able to tell.
Titus, Alabama |
