				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| Martin Olliver
				|  Posted: Mon Feb 13, 2012 2:17 am    Post subject: Lightning Strike |   |
				| Hi All. Has anyone experienced a lightning strike in a Europa? If not what is the perceived result of such a strike? A few years ago in the south of England a plastic glider was struck and broke up in flight both occupants survived as parachutes were deployed. A luxury I am unable to have due to size issues (not saying I am fat just well built!) My concern with the Europa is the lack of bonding between components and conductors to ensure components don't explode apart, as happened with the glider.
If as I suspect we all take a risk with this issue has any one considered any possible remedial action to improve the situation?
 Martin.
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| nigel henry
				|  Posted: Mon Feb 13, 2012 2:44 am    Post subject: Lightning Strike |   |
				| Dont fly ! As for well built Iv had lunch with you in Mcdonnalds ! and two of us in one europa I think might be a no no as not able to add fuel for w&b issues, so safety is bliss see you soon Nigel Ps will be down in the next few days put the coffee on ...... and no buns ! and yes will bring your gascolator top.
[quote] Subject: Lightning Strike
 Date: Mon, 13 Feb 2012 02:17:46 -0800
 --> Europa-List message posted by: "Martin Olliver" <martflynut(at)aol.com>
 Martin.
 http://forums.matronics.com/viewtopic.php?p=366176#366176
		| Back to top |  |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Mon Feb 13, 2012 2:47 am    Post subject: Lightning Strike |   |
				| Martin, Paul McAlister had a lightning strike on his
Europa which produced only modest damage and left the
 plane fliable, detailed at:
 http://europa363.versadev.com/LightningStrike.html   It
 was clearly a much lower energy strike than the one that
 blew up the glider. It apperas to havetravelled along thge
 wires to his nav ligfhts and thus avoided the control
 runs. When I was contemplating flying to Ausralia I did a
 fair bit of research on the topic and found it exremely
 difficult to get any authoritive advice other than the CAA
 publication triggered by the glider incident  (CAA
 AIL/0014, 2001, ISBN 1 904862 19 5) which gives
 recommendations for protecting gliders. It makes excellent
 sense for Europas contemplating getting near to Cu Nims.
 ( And although I usually feel it best to stay very well
 clear of such things, it is not possible to get to
 Australia without risking doing so unwittingly). My plan
 had been to run some aluminium mesh along the aileron and
 flap close outs to link with the rear lift pins and the
 bar across the fus behind tghe seats, with foil extensions
 from the outer aluminium mesh around the wing tip. I also
 planned to run a link from the engine frame to the tail
 wheel spring.
 Hope that helps, David Joyce, G-XSDJ
 On Mon, 13 Feb 2012 02:17:46 -0800
 "Martin Olliver" <martflynut(at)aol.com> wrote:
  	  | Quote: |  	  | <martflynut(at)aol.com>
 glider.
 Martin.
 Un/Subscription,
 Forums!
 Admin.
		| Back to top |  |
		| trevpond(at)aol.com Guest
				|  Posted: Mon Feb 13, 2012 2:49 am    Post subject: Lightning Strike |   |
				| What do Cirrus do?
 Trev
 G-LINN
 On 13 Feb 2012, at 10:17, "Martin Olliver" <martflynut(at)aol.com> wrote:
  	  | Quote: |  	  |
 Martin.
		| Back to top |  |
				|  Posted: Mon Feb 13, 2012 2:55 am    Post subject: Lightning Strike |   |
				| Martin, Sorry that link to Paul's strike doesn't seem to
work, but perhaps he will come back with one that does!
 David
 On Mon, 13 Feb 2012 10:46:25 +0000
 "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
  	  | Quote: |  	  | <davidjoyce(at)doctors.org.uk>
 thge wires to his nav ligfhts and thus avoided the
 control runs. When I was contemplating flying to Ausralia
 I did a fair bit of research on the topic and found it
 exremely difficult to get any authoritive advice other
 than the CAA publication triggered by the glider incident
 (CAA AIL/0014, 2001, ISBN 1 904862 19 5) which gives
 excellent sense for Europas contemplating getting near to
 Cu Nims.
 extensions from the outer aluminium mesh around the wing
 tip. I also planned to run a link from the engine frame
 to the tail wheel spring.
 >glider.
 > Martin.
 >Un/Subscription,
 >Forums!
 >Admin.
 Un/Subscription,
 Forums!
 Admin.
		| Back to top |  |
				|  Posted: Mon Feb 13, 2012 3:31 am    Post subject: Lightning Strike |   |
				| Pete, It was a flight experience/trial lesson flight, with
P2 having his first glider flight (and his last, inspte of
 being offered a free second one in view of his first being
 curtailed!) There was no water ballast, but there was some
 speculation that some water contamination (?condensation)
 might have added to the force of the heat generated
 expansionof the air in the wing, which effectively blew
 the two surfaces apart. What was established is that the
 energy in the bolt was exceptionally high, significantly
 more, in fact, than airliners are built to withstand.
 Regards, David Joyce
 On Mon, 13 Feb 2012 06:16:04 -0500
 Peter Zutrauen <peterz(at)zutrasoft.com> wrote:
  	  | Quote: |  	  | Hi Martin,
 I was under the impression that the glider you referred
 to broke up in
 flight due to the water ballast in the wings?
 Indeed in the archives you should find Paul Mcallister's
 lightning strike
 experience. Quite a read!
 http://www.aeroelectric.com/articles/Anatomy_of_a_Lightning_Strike.pdf
 Pete
 A239
 On Mon, Feb 13, 2012 at 5:17 AM, Martin Olliver
 >Europa? If not what
 >ago in the south of
 >concern with the
 >glider.
 >any one considered
 > Martin.
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Mon Feb 13, 2012 4:20 am    Post subject: Lightning Strike |   |
				| Hi Martin,
 I documented a lightning strike at http://www.europa.net.nz/363/index.html.  Its under the drop down on the left hand side.
 Paul
 On Mon, Feb 13, 2012 at 4:17 AM, Martin Olliver <martflynut(at)aol.com (martflynut(at)aol.com)> wrote:
 [quote] --> Europa-List message posted by: "Martin Olliver" <martflynut(at)aol.com (martflynut(at)aol.com)>
 Martin.
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Mon Feb 13, 2012 5:02 am    Post subject: Lightning Strike |   |
				| Pete & Martin
It was the control runs I think, but probably also moisture in the core of the composite skins, I remember reading that the wings exploded like confetti.
 Graham
 Sent: Monday, 13 February 2012, 11:16
 Subject: Re: Lightning Strike
 Hi Martin,
 I was under the impression that the glider you referred to broke up in flight due to the water ballast in the wings?
 Indeed in the archives you should find Paul Mcallister's lightning strike experience. Quite a read!
 Pete
 A239
 On Mon, Feb 13, 2012 at 5:17 AM, Martin Olliver <martflynut(at)aol.com (martflynut(at)aol.com)> wrote:
 Martin.
 target="_blank">http://www.matronics.com/Navigator?Europa-List
 le, List Admin.
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matroniclow" target="_blank" href="http://forums.matronics.com">http://forums.m=   --> [b]
		| Back to top |  |
		| kheindl(at)msn.com Guest
				|  Posted: Mon Feb 13, 2012 6:22 am    Post subject: Lightning Strike |   |
				| I have had a minor strike some years ago. Judging by the trail of 'damage' it appears to have entered by the tailpipe and exited via the radiator. But it was minor and no repair was necessary.Manufacturers like Cirrus and Diamond have integrated aluminum or copper mesh into the wing skins.
Karl
 Subject: RE: Lightning Strike
 Date: Mon, 13 Feb 2012 10:44:08 +0000
 .ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Tahoma;}    Dont fly ! As for well built Iv had lunch with you in Mcdonnalds ! and two of us in one europa I think might be a no no as not able to add fuel for w&b issues, so safety is bliss see you soon Nigel Ps will be down in the next few days put the coffee on ...... and no buns ! and yes will bring your gascolator top.
  	  | Quote: |  	  | Subject: Lightning Strike From: martflynut(at)aol.com
 Martin.
 [/b] 	  | Quote: |  	  | [b]
		| Back to top |  |
		| raimo.toivio(at)rwm.fi Guest
				|  Posted: Mon Feb 13, 2012 6:53 am    Post subject: Lightning Strike |   |
				| Martin,
 I had a case 8.th of June 2008. It went in via a
 fin top mounted strobo (it melted and remainders
 are in my "museum" now). Never found an outcoming
 hole. It broke also an electric trim and we had to
 land when trimmed for a cruise speed. It visited
 also a radio but no radio damages. I felt it via
 power lever and co-pilot got some electric
 experience via his headsets.
 That occurred when we flew between two black CBs,
 distance was about 10 nm /each. I cannot verify
 was it a strike or so called St. Elmo´s fire. Not
 very fun anyway.
 What I did later to improve the situation? Nothing
 but try to stay more clear about CBs.
 Raimo
 OH-XRT
 FINLAND
 -----Alkuperäinen viesti-----
 Sent: Monday, February 13, 2012 12:17 PM
 the glider.
 Martin.
 browse
 Un/Subscription,
 FAQ,
 Forums!
 List Admin.
		| Back to top |  |
		| Martin Olliver
				|  Posted: Tue Feb 14, 2012 2:21 am    Post subject: Re: Lightning Strike |   |
				| Thank you all for your input.
Martin.
		| Back to top |  |
		| nigel_graham(at)m-tecque. Guest
				|  Posted: Tue Feb 14, 2012 2:32 am    Post subject: Lightning Strike |   |
				| Just remember to take a pee before you take off  BODY { font-family:Arial, Helvetica, sans-serif;font-size:12px; }
 On Tue 14/02/12 10:21 , "Martin Olliver" martflynut(at)aol.com sent:
 Thank you all for your input. The good news here is that those of you who have had a lightning strike, seem to have only suffered minor or no damage at all. The situation with the glider seems to be different because of the moisture in the wings. I think we can all fly with cautious optimism on this one.
 Martin.
 [url=parse.php?redirect=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D366258%23366258]http://forums.matronics.com/viewtopic.php?p=366258#366258[/url]
 Navigator%3FEuropa-List" target=_blank>http://www.matronics.com/Navigator?Europa-List
 " target=_blank>http://forums.matronics.com
 contribution" target=_blank>http://www.matronics.com/contribution
		| Back to top |  |
		| frans(at)privatepilots.nl Guest
				|  Posted: Tue Feb 14, 2012 2:39 am    Post subject: Lightning Strike |   |
				| On 02/13/2012 11:17 AM, Martin Olliver wrote:
  	  | Quote: |  	  | Hi All. Has anyone experienced a lightning strike in a Europa? If not what is the perceived result of such a strike?
 The result is impossible to predict. Lightning stikes comes in all sizes
 and shapes. You can get a little protection against very light strikes
 (for of course a weight penalty), but since you don't know what is going
 to strike you there is just one effective measure: stay away from
 anything that looks like a TS.
 If you embed copper mesh in your wings it will make your wings much
 heavier, and of course if the strike is heavy enough the mesh will melt
 anyway and take the wing with it. Any strike generates heat, and as we
 all know our Europa's can not tolerate much heat, not much what we can
 do about it except for using aluminium instead of glass fiber.
 As much as the size and direction of lightning strikes vary, so do the
 results. The best in terms of survivability are vertical strikes. They
 don't search for your airplane, you just have to fly through a strike in
 progress. Alas, they are the least occuring stikes in airplanes. Much
 more occuring are spanwise and lenghtwise strikes. Your airplane offers
 an electric charge a comfortable path to find its opponent. Also, your
 exhaust fumes leave a trail of extra conductive air, due to the carbon
 and extra moisture in it. Any charge following that trail will find your
 airplane. Spanwise strikes bring the risk of welding the aileron
 controls, and of course the heat expands the air in the wings and the
 wings may just blow apart. Lenghtwise strikes will likely travel via the
 rudder cables. Apart from taking the ruddder out when the tiny cables
 melt, they might melt through the fuel tank which is just an inch away.
 Heat and fuel don't go along very well. And of course the rudder cables
 end at the rudder pedals, so I hope you don't have wet feet when it happens.
 The avionics and electric systems are the least of your concerns, but
 anything might fail, if not everything. It is likely you can't talk to
 anyone anymore, have no navigation anymore, and have to land your
 crippled airplane trimmed for cruise speed and possibly without rudder
 or aileron control without assistance. If you survived the initial
 strike at all of course.
 I remember the story of someone who got hit by lightning. They found his
 airplane with all the controls welded. Some research revealed that the
 poor pilot had flown for at least 10 minutes after all the controls
 where welded inmovable before he crashed...
 So, I will avoid thunderstorms at all costs.
 In my airplane I installed a stormscope. If it indicates anything
 threatening closer than 100nm, I will just land and fly another day.
 Frans
		| Back to top |  |
				|  Posted: Tue Feb 14, 2012 2:41 am    Post subject: Lightning Strike |   |
				| On 02/14/2012 11:21 AM, Martin Olliver wrote:
  	  | Quote: |  	  | Thank you all for your input. The good news here is that those of you who have had a lightning strike, seem to have only suffered minor or
 cautious optimism on this one. Martin.
 I think you can not. These people had just tremendous luck. The wings of
 an Europa will explode if the strike is anything more than "extremely
 light".
 Frans
		| Back to top |  |
		| Speedbird
				|  Posted: Tue Feb 14, 2012 2:43 am    Post subject: Lightning Strike |   |
				| If you don't have farradays, stay well clear of CB's and where to suspect discharging!
I have flown at least 5000 hours in King Airs with multiple hits and it never fells secure or "god enoug" around thunder and lightning...
 I have seen composite parts hit by lightning and it has always destroyed parts beyond repair!
 Don't fly near it...
 My 2 cents of recommendations
 Cheers!
 Ivan
 KajakCenter Halland
 Org nr; 5805034625
 P: +46 703 621310
 P: +46 704 694444
 M: midwing(at)telia.com
 W: www.kajakcenter-halland.se
 14 feb 2012 kl. 11:21 skrev "Martin Olliver" <martflynut(at)aol.com>:
  	  | Quote: |  	  |
 Martin.
		| Back to top |  |
		| Martin Olliver
				|  Posted: Tue Feb 14, 2012 2:53 am    Post subject: Re: Lightning Strike |   |
				| Not looking good then.
Martin
		| Back to top |  |
		| Speedbird
				|  Posted: Tue Feb 14, 2012 2:55 am    Post subject: Lightning Strike |   |
				| Frans,
That is the best approach!
 I do fully agree.
 Don't fly in or near clouds especially those convective ones...
 There is no such thing as a "mild" TS...
 Blue Skies!
 Ivan
 Frmr FC at SOS Flygambulans AB
 KajakCenter Halland
 Org nr; 5805034625
 P: +46 703 621310
 P: +46 704 694444
 14 feb 2012 kl. 11:37 skrev Frans Veldman <frans(at)privatepilots.nl>:
  	  | Quote: |  	  |
 Frans
		| Back to top |  |
				|  Posted: Tue Feb 14, 2012 3:01 am    Post subject: Lightning Strike |   |
				| Martin, I would like to think you are right but I doubt
you are! I think that any Europa (at least the XS, which
 is constructed in very much the same way as the K21 glass
 fibre glider) is just as likely to have dampness in the
 wings. On top of that, if you look at the AAIB report  (
 www.aaib.gov.uk/cms_resources.cfm?file=/dft_avsafety_pdf_500699.pdf
 ) there is no mention of water as far as I can see - it
 appears to be just a shock wave associated with the very
 high energy electrical discharge. For me the point at
 issue is the size of the lightning bolt. As well as
 blowing up the wings the current fused or destroyed most
 of the aileron  control mechanisms so that it would have
 been unflyable even with the wings intact. It seems that
 the 3 reported Europa strikes have all been low energy
 ones, and I have no optimism about an unmodified Europa
 surviving a medium or large strike. Regards, David Joyce,
 G-XSDJ
 On Tue, 14 Feb 2012 02:21:36 -0800
 Martin.
 Un/Subscription,
 Forums!
 Admin.
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
