Deems Davis
Posted: Thu May 25, 2006 9:54 am Post subject: Grounding question |
The RV-10 requires the battery to be mounted aft of the baggage area for
CG purposes. I just got back from Bob's seminar and like the idea of a
common ground buss on the firewall. (with the engine grounded on the
forward side and everything else on the aft side) In Van's wiring
harness they have the battery grounded to the airframe close to where
it's mounted. (way aft) I would prefer to not have to pull/run two (pos
& neg) 8-10 ft #2 welding cables all the way from the battery forward.
If I were to ground the battery close to it's mount on the airframe,
whould this cause any problems using a 'common ground buss'?
Thanks for any illumination to this 'electron challenged' builder.
Deems Davis # 406
Fuse
http://deemsrv10.com/
rvbuilder(at)sausen.net Guest
Posted: Thu May 25, 2006 11:23 am Post subject: Grounding question |
Hey Deems,
I gave this some thought too and decided to sacrifice the weight for =
a good solid electrical path. For 95% of the stuff you would probably =
be fine. The single item that comes to mind is the starter. I also =
wanted to make sure I didn't have as much of a chance of corrosion =
between the joints at the tailcone attach point and the fuselage, or any =
place else the high currents need to travel to get to the starter. The =
only way to get good bonding is with a bonding strap which would require =
some type of hole through the skin.
Another thing is if you truly want to use the battery location as a =
common ground point you would then need to run all of your grounds back =
to there which will rapidly negate the benefit.
I am going to be running #2 from the batteries to the firewall common =
ground point which will then have a through bolt to a mirror image =
engine side common ground point. 95% of my grounds will terminate at =
one of these two points. The only exceptions will probably be the LED =
wingtip lights, HID landing light (Duckworks DS1 with the starter on the =
bulb), and other low current/noise incandescent type things. My strobe =
pack and baggage lights are back by the batteries so they will be =
grounded right at the batteries which will still give the desired =
effect. The whole point to this exercise is really to provide the best =
current handling for the weight, eliminate ground loops, and use the =
batteries as big filters.
Hope this helps!
Michael Sausen
-10 #352 Fuselage
Posted: Thu May 25, 2006 12:08 pm Post subject: Grounding question |
Deems,
I did exactly as you suggest and have had no problems with it. Note in
the link below, the
positive side to each contactor and the negative sides bolt-connected to
the battery tray with five A5 rivets
on the negative ground lug. It has good contact area being riveted to my
rear spar and elsewhere. The firewall ground
block and lug work really well, even considering the firewall, which is
.015 stainless.
http://www.macsmachine.com/images/electrical/full/chargebatteryconnection.gif
I also used a #4 welding cable for positive going forward to the
firewall, but my engine is also a 100 h.p. Subaru.
Larry McFarland - 601HDS at www.macsmachine.com
Deems Davis wrote:
Deems Davis # 406
Fuse
Dan.Beadle(at)hq.inclines Guest
Posted: Thu May 25, 2006 1:23 pm Post subject: Grounding question |
Sounds like you are putting the battery in the rear. Vans recommends a
frame ground instead of running a #2 ground back to the firewall. I
need the battery aft for balance considerations. Light is great, but I
am concerned about grounding through the airframe. =20
=20
Also, I was figuring to ground the Duckworks HIDs back with a #18. I do
want light weight, but I want trouble free.
=20
Any thoughts? =20
=20
nuckollsr(at)cox.net Guest
Posted: Thu May 25, 2006 7:59 pm Post subject: Grounding question |
Battery can be locally grounded as can other devices REMOTE
from the cockpit equipment like:
(1) Landing, taxi and recognition lights,
(2) nav lights,
(3) strobe power supply,
(4) most fuel pumps ground through their mounting bases,
(5) hydraulic landing gear pumps,
(6) pitot heaters,
(7) and of course antennas which always ground locally
and are independent of power system grounding
considerations.
The picture Larry posted is a good example of a technique
which I've amplified with captions on Larry's picture posted
at:
http://www.aeroelectric.com/Pictures/Grounding/Local_Battery_Grounds_1.jpg
At 03:01 PM 5/25/2006 -0500, you wrote:
<larry(at)macsmachine.com>
Deems,
the link below, the
.015 stainless.
>Deems Davis # 406
>Fuse
-- incoming mail is certified Virus Free.
Checked by AVG Anti-Virus.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu May 25, 2006 8:00 pm Post subject: Grounding question |
At 10:51 AM 5/25/2006 -0700, you wrote:
Batteries (and lots of other stuff) have been grounded locally
to airframe structure since day-one. ALL of our aircraft at RAC
ground batteries to local structure. This isn't an inherently
evil thing to do as long as potential victims (generally stuff in
cockpit and on panel) get the single-point ground treatment. See
My response and amplification to Larry's photo cited in his
reply to this thread.
Dick Sipp
Posted: Thu May 25, 2006 8:26 pm Post subject: Grounding question |
Deems,
I asked the exact same question about 6-8 months ago, answer: try it as the
plans suggest and see if it works OK.
I still have not made up my mind. Grounding the battery locally to the
airframe will probably work fine, but on the other hand I would much rather
run the ground cable now while it is easy rather than later after the
airplane is flying. I don't like the weight but will probably run the bat
ground to the common ground at the firewall. It may not be much of a factor
but all of my structural parts were primed before assembly so there are
numerous thin coats of paint in an airframe ground path.
Dick Sipp
40065
mstewart(at)iss.net Guest
Posted: Fri May 26, 2006 4:30 am Post subject: Grounding question |
In my case in my RV Super 8 with my Batt in the back, I grounded it
locally & ran a 12ga to the front, from the battery, for grounding of
all the 'stuff' to a single point. I have a perfectly quiet electrical
system. For all practical purposes, only the starter & alternator, are
using the airframe ground.
Mike
dennis.glaeser(at)eds.com Guest
Posted: Fri May 26, 2006 5:05 am Post subject: Grounding question |
Bob,
I'm also using rear mounted batteries (RV-7A - electrically dependent
engine) and I found a diagram somewhere on your site that showed rear
mounted batteries with a note NOT to ground them locally to the airframe
- it showed a ground going to a forward mounted grounding point (forest
of tabs). So I'm curious: what circumstances would prompt this
recommendation?
2 questions to enhance my understanding:
- In this situation, are there any considerations required for single
heavy power wire running forward (i.e. things to avoid running along the
same path)? =20
- Are there any practical advantages to running a parallel ground as
well (which might balance the disadvantage of the added weight)?
Dennis Glaeser
Posted: Fri May 26, 2006 6:16 am Post subject: Grounding question |
At 08:23 AM 5/26/2006 -0400, you wrote:
<mstewart(at)iss.net>
Mike
Not a good deal. That long ground isn't really a ground. Please
consider using the single point ground block mounted on the firewall
as depicted in the Connection and making all cockpit and forward
accessory grounds at that point limiting your local airframe grounds
to the list cited in my posting of last night.
Posted: Fri May 26, 2006 6:23 am Post subject: Grounding question |
At 09:02 AM 5/26/2006 -0400, you wrote:
<dennis.glaeser(at)eds.com>
Bob,
recommendation?
The independent ground for battery minus leads is the electrically
elegant technique. If I were building an airplane, I'd probably run
the independent ground.
Local grounding for batteries and the list of items in last night's
posting poses no risks to those accessories because they are not
particularly large contributors as antagonists nor are they potential
victims.
| Quote: | 2 questions to enhance my understanding:
same path)?
What we're trying to avoid is having MULTIPLE grounds to an airframe
where heavy current accessories like landing lights, pitot heat, etc
SHARE the airframe with multiply grounded potential victims like
intercom and radios. It is 99.99% sufficient to pay attention to
single point grounding of potential victims while letting the airframe
go ahead and carry the ugly amps for devices which are not potential
victims.
| Quote: | - Are there any practical advantages to running a parallel ground as
Small and probably negligible as long as the victims remain "protected".
rv8ch
Posted: Fri May 26, 2006 7:15 am Post subject: Grounding question |
| Quote: | > In my case in my RV Super 8 with my Batt in the back, I grounded it
> Mike
I'm confused. Why wouldn't Mike's 12ga wire extended to an
isolated forest of tabs be a ground?
I considered doing the same, but decided to ground the
forest of tabs to the front of the aircraft as well.
Here's how mine is set up:
http://www.rv8.ch/article.php?story=20060301215616213
I added the "fat" ground wire between the front forest
of tabs to the batteries in the back mainly to carry
starter currents a bit more efficiently. I was afraid
that if I didn't, something between where I ground
the engine and the battery would get welded together
when I cranked the starter.
BTW, the engine cranks fine, but I have no idea about
noise, since I don't yet have my radio installed.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Everything goes to a single point ground block up front. That block is
isolated from the airframe and gets it ground supply from the 12ga
coming directly from the battery in the back.
larry(at)ncproto.com Guest
Posted: Fri May 26, 2006 8:58 am Post subject: Grounding Question |
Hi All,
I too have an aft-mounted battery and semi-crucial
starter requirement (high-compression pistons) and had
been assuming a dedicated ground wire of the same size
as the positive lead running forward. After thinking
about the posts on this; would it be reasonable to
locally ground the battery and run a smaller-sized
ground lead forward to a grounding-buss; with the
reasoning that the starter load would use both this
smaller ground lead and the airframe?? Or is this plain
obvious How then would one size this ground lead??
If I had primed all (and bonded some) of my airframe
parts before riveting - would this approach be
not-a-good-idea??
Larry E. James
Bellevue, WA HR2
dangerous content by Up Time Technology, and is
believed to be clean.
steveadams
Posted: Fri May 26, 2006 10:33 am Post subject: Re: Grounding question |
Seems like everyone is talking in circles here. You can ground all your peripheral stuff (battery, landing lights, strobes etc) locally to the airframe (if it's not plastic), and use the common block on the firewall for your panel and engine stuff. Vans recommends it, Bob recommends it, Zenith/Zenair recommends it, and most certified small metal planes do it that way. You don't have to re-invent the wheel, you won't make it any better, you might make it worse, and you'll definitely add complexity to the system.
Posted: Sat May 27, 2006 7:05 am Post subject: Grounding question |
At 05:12 PM 5/26/2006 +0200, you wrote:
<mick-matronics(at)rv8.ch>
>> Mike
"Ground" systems are much more than multiple systems
simply sharing a common conductor to satisfy their
individual needs for conductivity. The dynamic nature
of "ground" is dependent on its conductivity, geometry
and discontinuities. The ideal vehicular "ground" conductor
would probably be a welded joint, relatively thick sheet
of highly conductive material . . . say copper or silver
and have the minimum possible surface area to enclose
a given volume . . . hence a sphere.
Spheres and copper do not lend themselves well to
the fabrication of vehicular structures so instead
we find ourselves dealing with a variety of materials
ranging from excellent insulators (epoxy/glass) to
pretty good conductors (stir-welded aluminum) and all
technologies in between. Further, they're not spherical.
To make matters more interesting, the conduction pathways
for systems that share "ground" in any vehicle are never
straightest lines between two points on the system.
Just to make matters still more interesting, the
prudent designer has to consider the effectiveness
and cross coupling of signals for frequencies ranging
from DC to microwave. There's a condition in the
RAC Hawker 800 series aircraft where an antenna system
using airframe for part of the antenna's RF 'ground'
excites spaces in the hell-hole to the tune of over
100 volts/meter at various HF frequencies when the
transmitter is keyed. It varies from airplane to airplane
and is not a "problem" for most airplanes. But the effects
are present on every airplane and from time to time,
rise up and halt delivery of a multi-million dollar
machine because the ground system was not properly
configured for this application. Worse yet, it
would cost staggering amounts of money to fix it
now. Instead, we craft individual Band-Aids
on an airplane-by-airplane basis when a particular
combination of circumstances rise to intolerable
interference levels.
This dissonant array of conditions that never
approach the ideal ground system is NEVER a problem
for any one system operating by itself . . . nor is
it a problem for systems that are generally not vulnerable
to ground induced coupling of noises from a potential
antagonist to a potential victim system.
This gives rise to many builder's assertions that
their particular version of a ground system "works
just fine" . . . and he's not wrong. Just as I've cited
for the Hawkers above, there are ground system issues
that while they are predictable and even measurable,
the magnitude of the 'interference' is below the
threshold of deleterious effects. This is why
99.9% of all airplanes crafted over the last
100 years are considered by their owners to be
'satisfactory' performers. Only the occasional
machine comes to the attention of some poor
avionics tech who now has to figure out how to
work around a noise problem that would have best
been designed out in the first place.
Ladies and gentlemen, to offer a comprehensive
course in ground system design features and effects
of poor science is beyond the scope of activities
we can offer in this venue. You folks need to concentrate
on getting first-light-under-the-wheels with a minimum
of $time$ and lowest practical cost of ownership later.
Be wary of variations on a theme for ground system
features that depart from those suggested in the
'Connection and in the considered words of the
grey-beards on the List. Virtually every variation
offered to you by some builder you met at a fly-in
will be touted as a 'solution' to some unfounded
concern or a desire to cut a corner . . . and since
the airplane flew to that gathering, no doubt the
owner will report "it works fine". The grounding
philosophies offered in this venue are a prophylactic
effort designed to avoid that 0.1%, pain-in-the-arse
airplane that's going to be expensive in $time$
at some point in the future. These same philosophies
also attenuate the 10-20% of the airplanes that have
some degree of noise issue which the owner is willing
to accept as below his personal threshold of deleterious
performance.
The double-grounding architecture described above is
generally not a significant improvement in ground
system performance and opens the doors for new issues.
In another time, I'll tell you the saga of a "double
ground" issue that rose up in a Beechjet a year or
so ago that had a very expensive airplane down for
months (at taxpayer expense) and took hundreds of
hours to find and fix.
"Extending" ground busses for major chunks of system
hardware on the end of a 12AWG wire makes everything
'grounded' by that wire subject to single point failure
of one wire. Further, the resistance/inductance
contributed to the system by the wire length makes
it less than ideal ground.
These are 'experimental' airplanes and one can certainly
do as he/she wishes in terms of personalizing the
electrical system architecture. Most variations will
be found to function in a 'satisfactory' manner.
Just be aware that departures from architectures
configured with use of well considered science and experience
tosses out the $time$ invested in crafting those architectures.
They also elevate the risk for added expense and aggravation
at some later date. The fruits of those investments are being
shared with you at virtually zero expense so as to minimize
$time$ to first-light and $time$ needed to fix something later
when you'd rather be flying.
Posted: Mon May 29, 2006 1:50 pm Post subject: Grounding Question |
Bob,
I appreciate your sentiments to the effect that our
focus needs to be to "get light under the wheels" .....
boy do I agree !!
But you went over my head. Is the short version that
one big Ground wire the same size as the main Positive
lead (2awg) should run forward to a combo
thru-the-firewall-lug / Gound "forest" ?? In other
words; one ground wire to one ground block and
continuing to the starter?? I'm after just the simple
answer
Larry E. James
Bellevue, WA HR2
lhelming(at)sigecom.net Guest
Posted: Tue May 30, 2006 3:03 am Post subject: Grounding Question |
Posted: Tue May 30, 2006 5:30 am Post subject: Grounding Question |
At 02:44 PM 5/29/2006 -0700, you wrote:
Bob,
boy do I agree !!
answer
Yes, the ground lead should be the same size as the
(+) lead and 2AWG is a good size for a remotely
mounted battery.
2AWG other than nice, soft welding cable should
not be bolted directly to a battery. If you run
22759 or copper clad aluminum wire from batteries
to the firewall ground stud, I'd recommend
a short (6") 4AWG welding cable jumper be used to
make the leap from battery(-) to the end of the
battery ground feeder.
You could bolt the two wires together with ring
terminals and cover with heatshrink.
For local airframe grounding of batteries, I've
published a new Shop Notes at:
http://aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html
