		jchang10
				 Posted: Sun Feb 19, 2012 12:45 am    Post subject: Ram Air Boost? |
				Just out of curiosity, has anyone else noticed getting any kind of ram air boost in MAP? I am stock plans, engine, etc.
 Specifically, i notice a little boost when pitching over to start a descent from cruise. I noticed this a few times now where I am cruising along at 22" x 2200 rpm or so at 3,000ft and 145 to 150 KIAS. Shortly after pitching over a bit and having only lost 500ft of altitude but now showing 160 KIAS, i will notice i am running oversquared at 24" x 2200 rpm for instance. How did i gain 2 inches all of a sudden?
 I wonder if the MAP reading is accurate? The plane doesn't know it's pitched down per se, so is there something special about 160 KIAS? Sanity check?
 Jae
  _________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
				 Posted: Sun Feb 19, 2012 7:21 am    Post subject: Ram Air Boost? |
				I know nothing about ram air, MAP, etc, but intuition has me believing
 that this is as it should be.  That we do have a ram air inlet, that a
 forward facing inlet gives us a positive boost in MAP at all speeds, and
 that if all things are equal, a 10 knot increase in speed would result
 in some increase in MAP.  The pitch angle is not really involved, it's
 just speed.
 But I don't have a clue....
 "Curious" Bill
  Jae
		partner14
				 Posted: Sun Feb 19, 2012 8:10 am    Post subject: Ram Air Boost? |
				I think if you monitored the MP closely/continuously, you would see that part of the increase is due to altitude change, and part is due to increased airspeed.  I continually reduce my MP on decent,,, usually maintaining somewhere between 18 and 19".Don
  Sent: Sunday, February 19, 2012 2:45 AM
  Subject: Ram Air Boost?
  --> RV10-List message posted by: "jchang10" <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)>
 Jae
 #40533 RV-10
 http://forums.matronics.com/viewtopic.php?p=366580#366580
 t;
40636 |
		rv10flyer
				 Posted: Sun Feb 19, 2012 10:09 am    Post subject: Re: Ram Air Boost? |
				I'll have to check that out next time we go up.
 The decrease in angle of attack exposes a slightly larger engine air inlet area. Then you have the airspeed increase, altitude decrease, propeller pitch increase that will also raise MP.
 When I begin descent I slowly pull power back to maintain cruise airspeed and leave mixture alone until I get down close to pattern altitude.
  _________________ Wayne G. |
		jchang10
				 Posted: Mon Feb 20, 2012 10:29 am    Post subject: Re: Ram Air Boost? |
				I generally try to do the same. I am a bit of a speed addict, so sometimes i just push over first, let speed increase a bit then adjust the descent speed with power.
 It is generally right after the push over that i notice the gain in MAP.
 Jae
  	  | rv10flyer wrote: | 	 		  I'll have to check that out next time we go up.
 When I begin descent I slowly pull power back to maintain cruise airspeed and leave mixture alone until I get down close to pattern altitude. |
