		capedavis(at)yahoo.com Guest
				 Posted: Mon Feb 20, 2012 3:03 pm    Post subject: NI-CAD |
				Kolbers , I forgot to ask in  my last post asking about the 377s , Do the NI-CAD batteries the light ones, have enough power to start a ROTAX 377- 447 ? Has anyone tried one? Thanks Chris
 Chris Davis
 KXP 503 492 hrs
 Glider Pilot
 Disabled from crash building Firefly
		herbgh(at)nctc.com Guest
				 Posted: Mon Feb 20, 2012 3:23 pm    Post subject: NI-CAD |
				Chris
 A fairly small  motor cycle battery  works..  ES14L-A2  from
 Wally  ...  My buddy who died last May used it to start his 447...
    By the way...I may sell his 447... New From SMLA   in 2010...  Has
 13 hours...I have the Bill of Sale from them..
    After market GPL  electric start...Heads torqued after 1 hour...
 One of the last "new" 447's...  from what I hear...
   $4499 .00 when he bought it in June of 2010...  B Box 2.58 to 1...   Herb
 At 05:01 PM 2/20/2012, you wrote:
  	  | Quote: | 	 		  Kolbers , I forgot to ask in  my last post asking about the 377s ,
 Chris Davis
 KXP 503 492 hrs
 Glider Pilot
				 Posted: Mon Feb 20, 2012 4:29 pm    Post subject: NI-CAD |
				On 02/20/2012 05:01 PM, chris davis wrote:      	  | Quote: | 	 		                  Kolbers , I forgot to ask in  my last post asking             about the 377s , Do the NI-CAD batteries the light ones, have enough power to start a             ROTAX 377- 447 ? Has anyone tried one? Thanks Chris
          Chris Davis
            KXP 503 492 hrs
            Glider Pilot
       | 	       Hi Chris,
      I think you're looking for 'SLA' (sealed lead acid) or 'VR-RG'     (valve regulated recombinant gas) batteries (same thing, different     names). There were a few NI-CAD batteries certified for 'big iron'     a/c, but there's a history of fires with them, too. SLA batteries     have pretty much taken over the market for larger high current     batteries used in everything from computer backup power supplies to     powered wheel chairs to starting batteries for motorcycles &     watercraft. SLA batteries use the same charging technology as old     flooded cell batteries, don't leak, can be installed in any     position, & aren't prone to thermal self destruction like the     big ni-cads were.
      An SLA battery that weighs about 12-14 lbs (about 1/2 the size of a     lawn tractor battery) will easily start a 360 cu in a/c engine.
      When you start looking, look for ones intended as starting     batteries. The ones made for computer backup and wheel chairs don't     have quite as much short term 'grunt' for starting, & won't last     quite as long if used to start a motor. (Though anything over about     10 ampere-hours would probably work on a small motor like a 337.)
      Charlie
				 Posted: Mon Feb 20, 2012 7:33 pm    Post subject: NI-CAD |
				Date: Mon, 20 Feb 2012 15:01:23 -0800 (PST)
 Chris,
 I have been using an UltraStart Red Battery.  They are quite expensive but
 very light.  You can view the battery and the holder that I used at:
 http://jackbhart.com/firefly/firefly142.html
 The first battery did very well, but I was disappointed with the second, in
 that, it did not last very long.  I popped the top red part off the battery
 and discovered the actual battery model number.  The cost of this original
 unmodified battery is about one quarter of the UltraStart Red.  I was able
 to purchase a replacement battery at a local shop and add the original heavy
 terminals to the new battery.  How it was done can be seen at:
 http://jackbhart.com/firefly/firefly160.html
 I have been working on a LiFepo4 battery.  I havew four  A123 cells mounted
 and the terminal connections welded.  I believe it will shave another pound
 or so off the FireFly, but it has to wait until I get FireFly back in the
 air this coming Spring.
 I hope this helps.
 Jack B. Hart FF004
 Winchester, IN
				 Posted: Mon Feb 20, 2012 9:00 pm    Post subject: NI-CAD |
				Jack Thanks alot for the email o  the batteries I looked for the data. It is a Portalac PX12050SHR and distributed by GS Battery. Internet replacement batteries can be purchased I got a price of $14 for a 4.5 ib 12volt battery very nice .   thanks again Chris
  p.s. do you know anything about the SkiDo 377s ?
  Chris Davis
 KXP 503 492 hrs
 Glider Pilot
 Sent: Monday, February 20, 2012 10:37 PM
 Subject: Kolb-List: NI-CAD
 --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
 From: chris davis <capedavis(at)yahoo.com (capedavis(at)yahoo.com)>
 Chris,
 I hope this helps.
 Jack B. Hart FF004
 Winchester, IN
 ref="http://www.matronics.com/Navigator?Kolb-List" bsp;                     ==================
		Ducati SS
				 Posted: Tue Feb 21, 2012 6:07 am    Post subject: Re: NI-CAD |
				Along with full scale I also fly RC airplanes. When we went to the new lithium batteries the increase in performance was dramatic. This technology is now finding it' way to cars and motorcycles. I believe the motorcycle version is supposed to start a 500cc engine at .8lbs the car version starts at less than 2lbs. I plan to do a bit more research and if the charging system is compatible buy one for my track car. When first introduced the price was 1200 but has dropped to less than $200.
				 Posted: Tue Feb 21, 2012 9:09 am    Post subject: NI-CAD |
				Date: Mon, 20 Feb 2012 20:59:42 -0800 (PST)
  	  | Quote: | 	 		  Jack Thanks alot for the email o  the batteries I looked for the data. It
 very nice .   thanks again Chrisp.s. do you know anything about the SkiDo 377s ?
 Chris,
 I don't have any experience with SkiDo 377s.
 I did weigh my prototype LiFepo4 battery, and it came out at 11.4 ounces.
 This includes the original four cells, the two wood mounting brackets, and
 the connector strips that were welded to the cells. It will put out 70
 continuous and a 120 ampere pulse for 10 seconds.  It is rated at a 2.5
 ampere battery.  The MZ 34 starter pulls 30 ampere continuous, so this
 battery will crank the engine for about five minutes.  The properly primed
 engine usually starts in about five seconds.
 Jack B. Hart FF004
 Winchester, IN
				 Posted: Tue Feb 21, 2012 9:00 pm    Post subject: NI-CAD |
				Duc,thanks for the tip the battery is a place Im sure I can cut a lot of weight I will spend some time finding the best price . Chris
  Chris Davis
 KXP 503 492 hrs
 Glider Pilot
 Sent: Tuesday, February 21, 2012 9:07 AM
 Subject: Kolb-List: Re: NI-CAD
 --> Kolb-List message posted by: "Ducati SS" <hiwingflyer6219(at)yahoo.com (hiwingflyer6219(at)yahoo.com)>
 http://forums.matronics.com/viewtopic.php?p=366822#366822
 <> httpbsp;                 -Matt Dralle, ===========
