Sensitive Elevator
Goto page Previous  1, 2, 3  Next
steve.freeman(at)syntaxds
PostPosted: Fri Feb 24, 2012 7:59 am    Post subject: Sensitive Elevator Reply with quote
This whole thread has been confusing to me. Why would you want to change the characteristics of the controls before flying the controls? This is purely a subjective issue and you won’t know if you have improved the performance as you will have no original point of reference. I haven’t flown left seat in a 601 for many years but I have flown right seat for many hours and I can tell you the controls are responsive without being “twitchy.” Even though it takes minor stick movement to make big changes there is no difficulty establishing fine control. I think having to “throw” the controls for longer distances would make an already tight cockpit even tighter. I think you could be hunting unicorns here but even with that said therein lies the beauty of experimental aircraft. Go forth and BUILD!
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Randy
Sent: Friday, February 24, 2012 8:40 AM
Subject: Re: Re: Sensitive Elevator
"making the stick less sensitive which is a good thing"
Not for me! I love the way the stick feels. Wouldn't change it for the world.
Randy
aprazer
PostPosted: Fri Feb 24, 2012 8:24 am    Post subject: Re: Sensitive Elevator Reply with quote
Greetings Andrew,
Keep us informed as to what the factory has to say about your suggestion. It is an interesting concept!
Mack
The poh-oh-unemployed farm boy from Idaho
pmaxpmax(at)HOTMAIL.COM
PostPosted: Fri Feb 24, 2012 9:00 am    Post subject: Sensitive Elevator Reply with quote
I agree with Dr. Gary Ray.  When flying, the "unbalanced" controls are not a problem for me.  I frequently hold the control stick below the handle grips because the force required is so low.  A new pilot flying an XL will frequently over control it.  It happens almost every time a person grabs the stick for the first time in my plane.  I say, "You just have to think about it, and it will turn."
This falls into the category of "stuff that seems important when building, but is not important when flying."  I wrote about this in a chapter in William Wynne's, Corvair Flight Operations Manual.  Many things fall into this category for me: single stick/Dual stick, single throttle/dual throttle, standard engine rotation/left turning.  I worried about these, but they just don't matter to me when flying.
My advice: build and fly.  Staying with the plans makes for the simplest (quickest) build.
Phil Maxson
601XL-B/Corvair
Center Stick, Hingeless Ailerons
Northwest New Jersey
Date: Fri, 24 Feb 2012 06:41:45 -0500
--> Zenith-List message posted by: "Gary Ray" <davgray(at)sbcglobal.net>
Andrew
The controls on my 601XLB require only small inputs during flight. Even in
a 60 degree bank it only requires two fingers for pressure and no trim
adjustments.
Compare that to C & P models where the nose drops fast. The relative
displacement of the controls is pretty close. The pressure for full aileron
deflection at slow speed
is higher than the elevator with my hinge-less ailerons but not irritating.
The overall impression is good.
<<SNIP>>
andrewtub
PostPosted: Fri Feb 24, 2012 9:10 am    Post subject: Re: Sensitive Elevator Reply with quote
The gods have spoken. From my understanding, It looks as if Zenith has addressed the issue and will soon release a "part" on the 650 that will better balance the controls. I hope this will be applicable to the 601 series.
Here is the response I received from Zenith:
Hi Andrew,
There are a couple things at play here that most people lump into "sensitivity" and they are actually two distinctly different things and you have to be very careful trying to change it as one affects the other. There is "balance" and there is "sensitivity" and the two are very different but one changes the other. You might know this but I will explain the difference and I think you will see the problems with your plans.
When I say balance, I mean comparing the stick loads for the ailerons versus the elevator. Sensitivity is the amount of stick movement to get a certain roll rate. You are correct in what you are thinking about changing the sensitivity but as you said, the stick loads will be lowered. The XL/650 controls are not balanced to begin with. The elevator is lighter than the ailerons and what you are talking about doing will further unbalance the stick loads. You don't want to do remove sensitivity at the expense of making the stick loads too unbalanced.
We have been looking at this very issue with the controls. Part of this has been done and are included in the next revision of the 650 drawings, they should be released next week. The part that is in the new drawings will balance the stick loads but doesn't address the elevator sensitivity.
I really like how the 650 flys with just the balanced stick loads. I think it will surprise you how much differently the controls feel when the loads are balanced. Even though the elevator sensitivity isn't changed, having the stick loads about the same you will tend to have less issues with the sensitivity.
One thing that you will need to really watch out for in moving the holes for the elevator cables on the stick is the cable routing. There isn't a lot of room and you might have conflicts with the other controls and the structure that may require new fairleads or pulleys. You can make this change if you want but realize the other effects that the changes will make, not all of them will be what you want and may well make your controls "feel" worse.
Caleb Gebhardt
craig(at)craigandjean.com
PostPosted: Fri Feb 24, 2012 9:17 am    Post subject: Sensitive Elevator Reply with quote
In other words "when all else fails ask the factory" Wink
-- Craig
PostPosted: Fri Feb 24, 2012 9:27 am    Post subject: Sensitive Elevator Reply with quote
Hi Phil…
Can you elaborate on “single throttle – Dual throttle” Issue. What about Single Brakes dual brakes. I am spending a great deal of time and effort installing dual brakes and I am beginning to think it not worth it.
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Phil Maxson
Sent: Friday, February 24, 2012 10:00 AM
To: Zenith List
Subject: RE: Re: Sensitive Elevator
Phil Maxson
601XL-B/Corvair
From: davgray(at)sbcglobal.net (davgray(at)sbcglobal.net)
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
--> Zenith-List message posted by: "Gary Ray" <davgray(at)sbcglobal.net (davgray(at)sbcglobal.net)>
Andrew
adjustments.
<<SNIP>>
andrewtub
PostPosted: Fri Feb 24, 2012 9:34 am    Post subject: Re: Sensitive Elevator Reply with quote
LOL, yep!
-- Craig
goodings(at)yorku.ca
PostPosted: Fri Feb 24, 2012 9:43 am    Post subject: Sensitive Elevator Reply with quote
Andrew:
Good work. The overly sensitive elevator is an undesirable trait if the
aircraft is aimed at the "low-time pilot and first-time builder" - that is
a quote from Chris Heintz. It might not be a bad idea to run your mod
past Chris/Zenith people, just in case there is some other consideration
not appreciated. And, as a long-time Cessna driver, I can sympathize with
the undesirably insensitive controls of the C-150/152/172. Sports cars
and Mack trucks come to mind. Perhaps my problem in the early days of our
CH601HD stemmed from relatively sensitive pitch combined with rather
insensitive roll. Cessnas are insensitive in both.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Orillia.
BARRY CHECK 6
PostPosted: Fri Feb 24, 2012 11:31 am    Post subject: Sensitive Elevator Reply with quote
In other words. When stupid ideas run through your head Call The Factory...  Better yet the designer.
On Fri, Feb 24, 2012 at 12:34 PM, andrewtub <andrewtub(at)yahoo.com (andrewtub(at)yahoo.com)> wrote:
[quote]--> Zenith-List message posted by: "andrewtub" <andrewtub(at)yahoo.com (andrewtub(at)yahoo.com)>
LOL, yep!
> -- Craig
http://forums.matronics.com/viewtopic.php?p=367141#367141
target="_blank">http://www.matronics.com/Navigator?Zenith-List
le, List Admin.
BARRY CHECK 6
PostPosted: Fri Feb 24, 2012 11:35 am    Post subject: Sensitive Elevator Reply with quote
If one thinks a 601 is 'sensitive'  they better not fly an RV or a Grumman or a Pits or a Night Twister or an Extra or any plane that is RESPONSIVE.  Responsive not sensitive.
On Fri, Feb 24, 2012 at 12:10 PM, andrewtub <andrewtub(at)yahoo.com (andrewtub(at)yahoo.com)> wrote:
Hi Andrew,
Caleb Gebhardt
http://forums.matronics.com/viewtopic.php?p=367137#367137
le, List Admin.
entecrj(at)sbcglobal.net
PostPosted: Fri Feb 24, 2012 11:57 am    Post subject: Sensitive Elevator Reply with quote
Sent: Fri, February 24, 2012 1:35:25 PM
Subject: Re: Zenith-List: Re: Sensitive Elevator
Reminds me of years ago when I was one of the instructors for our remote control club.
I had a pattern plane setup on a transmitter with dual rates, flip the switch on and the airplane was quite docile, flip it off and it became very responsive.
After one of the students would become confident that they could fly anything once the trainer plane was mastered, I would let them fly the pattern ship with the dual rates on. They would usually get the hang of it rather quickly. Then I would flip the switch off, and watch out!!!
The last thing I would show them was to move the balance weights back to about 38 percent of MAC, now you were talking about something that was sensitive to fly.
R. Johnson
BARRY CHECK 6
PostPosted: Fri Feb 24, 2012 12:29 pm    Post subject: Sensitive Elevator Reply with quote
You are correct RusselOne does have to learn to fly the BASICS - TRAINERS before they advance.  That is what the C152 was all about.
I have been flying R/C for over 40 years, trained 100's and the EASIEST planes to fly are PATTERN SHIPS.  They go where YOU put them, you don't have to over correct for dihedral or try to guess where the plane is going to be when you do a roll.
NOW... Who in their right mind goes out and buys a kit without first getting a ride in the plane they intend to build.  And who in their right mind doesn't become VERY proficient in that type of plane before they become a TEST PILOT in the plane they just built. OR do they intend to strap that plane on some other dumb-ass with all those HOMEMADE modifications.  After all, the OTHER Test Pilot has 100 Hrs in Type but NOT in Homemade Modification MAKE.
On Fri, Feb 24, 2012 at 2:56 PM, Russell Johnson <entecrj(at)sbcglobal.net (entecrj(at)sbcglobal.net)> wrote:
[quote]From: FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)>
R. Johnson
andrewtub
PostPosted: Fri Feb 24, 2012 1:05 pm    Post subject: Re: Sensitive Elevator Reply with quote
Delete...
PostPosted: Fri Feb 24, 2012 1:51 pm    Post subject: Sensitive Elevator Reply with quote
What kind of dumbass post such nonsense to a public forum?
Steve
andrewtub
PostPosted: Fri Feb 24, 2012 3:54 pm    Post subject: Re: Sensitive Elevator Reply with quote
Steve
My point exactly
Afterfxllc(at)aol.com
PostPosted: Fri Feb 24, 2012 6:51 pm    Post subject: Sensitive Elevator Reply with quote
Steve it would simply be a matter of preference it wouldn't effect the amount of travel the elevator has just would take more input from the pilot to achieve the full deflection. One could make the argument that less travel on the stick could cause an inadvertent over control and thus stress the airframe. After the upgrade the stick travel is much less thus making the stick travel a lot less. You could do the same thing to the ailerons to allow more stick travel left to right also if you wanted to.
In a message dated 2/24/2012 11:01:48 A.M. Eastern Standard Time, steve.freeman(at)syntaxds.com writes:
This whole thread has been confusing to me. Why would you want to change the characteristics of the controls before flying the controls? This is purely a subjective issue and you won’t know if you have improved the performance as you will have no original point of reference. I haven’t flown left seat in a 601 for many years but I have flown right seat for many hours and I can tell you the controls are responsive without being “twitchy.� Even though it takes minor stick movement to make big changes there is no difficulty establishing fine control. I think having to “throw� the controls for longer distances would make an already tight cockpit even tighter. I think you could be hunting unicorns here but even with that said therein lies the beauty of experimental aircraft. Go forth and BUILD!
Steve
Randy
----- Original Message -----
From: Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)
Sent: Friday, February 24, 2012 9:19 AM
If I read your email correct.....
I have thought about doing the exact same thing for my next 2 planes I build.... What you are suggesting makes sense because it would allow more stick movement for the same elevator movement thus making the stick less sensitive which is a good thing.
Jeff
In a message dated 2/24/2012 6:43:25 A.M. Eastern Standard Time, davgray(at)sbcglobal.net (davgray(at)sbcglobal.net) writes:
Andrew
adjustments.
Mine displays completely neutral stability which makes it feel nimble but
does not self correct and return to level flight by itself when disturbed.
For that reason I did put Dynon's autopilot in. It is easier to check a map
or look up a frequency without deviating from course and flight level.
Gary Ray davgray(at)sbcglobal.net (davgray(at)sbcglobal.net)
Zenith 601XL-B, William Wynne Corvair 0.060 over, Roy's 5th bearing,
Mark's Falcon Heads, Marvel Schebler MA3-SPA Carburetor, 175 Hrs TT
PostPosted: Fri Feb 24, 2012 6:57 pm    Post subject: Sensitive Elevator Reply with quote
Now there is the list we all know and love........
In a message dated 2/24/2012 4:09:32 P.M. Eastern Standard Time, andrewtub(at)yahoo.com writes:
--> Zenith-List message posted by: "andrewtub" <andrewtub(at)yahoo.com>
Yea, what kind of "DUMBASS" would make HOMEMADE modifications to a plane in the first place with out consulting the manufacture. Kinda like some of these "stupid" "DUMBASS"'s that would but in the middle of a conversation with out knowing all of the facts of the matter.
[quote="BARRY CHECK 6"]You are correct RusselOne does have to learn to fly the BASICS -�TRAINERS�before they advance. �That is what the C152 was all about. �
I have been flying R/C for over 40 years, trained 100's and the EASIEST planes to fly are PATTERN SHIPS. �They go where YOU put them, you don't have to over correct for dihedral or try to guess where the plane is going to be when you do a roll.
NOW... Who in their right mind goes out and buys a kit without first getting a ride in the plane they intend to build. �And who in their right mind doesn't become VERY�proficient in that type of plane before they become a TEST PILOT in the plane they just built. OR do they intend to strap that plane on some other dumb-ass with all those HOMEMADE modifications. �After all, the OTHER Test Pilot has 100 Hrs in Type but NOT in Homemade Modification MAKE.
If one thinks a 601 is 'sensitive' �they better not fly an RV or a Grumman or a Pits or a Night Twister or an Extra or any plane that is�RESPONSIVE. �Responsive�not�sensitive.
�Responsive not sensitive
I had a pattern plane setup on a transmitter with�dual rates, flip the switch on and�the airplane was quite docile, flip it off and it became very responsive.
� After one of the students would become confident that they could fly anything once the trainer plane was mastered, I would let them fly the pattern ship with the dual rates on. They would usually get the hang of it rather quickly. Then I would flip the switch off, and watch out!!!
R. Johnson
> _blank">http://www.matronics.com/contribution
http://forums.matronics.com/viewtopic.php?p=367165#367165
bryanmmartin
PostPosted: Sat Feb 25, 2012 7:24 am    Post subject: Sensitive Elevator Reply with quote
As far as "single throttle - dual throttle" is concerned: The original plans call for a throttle on each side so a pilot flying from either seat can work the throttle with his non off stick hand. I did not particularly like the complexity of the dual throttle setup and I wanted to install a vernier throttle.
The thing I like about a vernier throttle is the fact that you don't have to adjust a friction control to keep the throttle from drifting from its setting, the throttle will stay where you put it without any further consideration. You can also fine tune the throttle setting by turning the knob. A vernier throttle installed on one side would render the second throttle control inoperative unless you rigged up something to release the lock on the vernier throttle. I found that a while sitting in the right seat I could reach the throttle on the left side of the panel if I changed hands on the Y-stick and reached across with my left hand. It wasn't ideal but it wasn't difficult and I didn't plan on flying the plane solo from the right seat anyway. So I eliminated all the mechanism associated with the dual throttle and just ran a single control cable through the firewall to connect to the carburetors.
As far as the dual brakes are concerned, unless you are planning on flying solo from the right seat, they would be of limited usefulness. They might be useful if a passenger had to land the plane in the event of pilot incapacitation, but that's a pretty rare event. A long grass runway would probably solve that issue.
On Feb 24, 2012, at 12:26 PM, Steve Freeman wrote:
Hi Phil…
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
do not archive.
Bryan Martin
do not archive.
jeffrey_davidson(at)earth
PostPosted: Sat Feb 25, 2012 10:21 am    Post subject: Sensitive Elevator Reply with quote
My take on the throttle question was the consideration of two pilots flying together. A throttle on each side made it easy. You could put one throttle in the middle, but then you need two sticks rather than the center stick with the Y. I addessed the friction lock concern by removing the fiction bushing from the right seat throttle. Only the left friction lock is operative. That was a five minute job prior to installation. The only concern with the dual throttle setup was needing slots in the firewall for the cables going to the throttle rod. The plans showed a hole thru the firewall but the cable rises and falls flexing the firewall. I used a small bellows to seal the slot and n66 to line it for a very nice feel. The throttle rod was from USJabiru but I made attachments per the Zenith plans to capture the rod ends mechanically.
Jeff Davidson
CH601-HD/Jab 3300A
psm(at)att.net
PostPosted: Sat Feb 25, 2012 10:58 am    Post subject: Sensitive Elevator Reply with quote
Hi Jeff,
I agree with you about having two throttles when the plane has a center
Y stick. I tried the UsJabiru approach and didn't like it. I copied
their basic idea but moved the torque tube inside the cabin with the
control arms facing down rather than up. I also mounted the throttle
controls on the side of the cabin instead of on the instrument panel.
That way guys with short arms like mine could still rest their hand on
the throttle control in normal flight. The finished layout has both
throttle knobs, the torque tube arm ends, and the carburetor all at
about the same height. This allows for very smooth throttle control
movement.
I left the friction locks on both throttle knobs. So far I have only
flown my plane solo, so I don't know if this will be a problem or not.
I will keep your idea in mind of removing the friction lock from the
copilot side if this becomes a problem.
Paul
Camas, WA
XL in phase I flight test
Jeff Davidson
CH601-HD/Jab 3300A
Page 2 of 3
