		dlm34077(at)q.com Guest
				 Posted: Mon Feb 27, 2012 6:04 pm    Post subject: AP procedure |
				Shortly after start, I apply power to my TT VSGV. The words AP OFF show on the screen. A friend indicated that he did not apply power to the TT until airborne; I suggested that was an unwise procedure because if inadvertently encountering IMC (dark night, low clouds or dark night and unlighted terrain) the AP can be used to maintain control of the aircraft. A touch of the round black knob will automatically synchronize the aircraft to the current heading by leveling wings and maintaining pitch attitude i.e. rate of climb. The TT AP has its own solid state pitch and roll sensors and the straight and level sensors are set at power up, preferably on the ground.  My TT is my third way to keep the clean side up and dirty side down, after the Cheltons and the GRT Sport.
				 Posted: Mon Feb 27, 2012 6:43 pm    Post subject: AP procedure |
 "After start up, turn on the autopilot master switch and hold the
 aircraft stationary as the internal gyros are initialized. The model
 and software	version will be displayed for approximately ten seconds
 in the lower left. Then PWR UP in the lower right takes approximately
 another ten seconds. When initializing is complete PWR UP will change
 to AP OFF."
 The take-away is don't move the plane the until the AP reads AP OFF.
 Asking it to initialize in flight doesn't always give great results.
 I haven't timed it but my sense is that it doesn't really take 20
 seconds for it to initialize.  I put it early in the checklist so I'm
 doing other stuff anyway.
 --Dave Saylor
 On Mon, Feb 27, 2012 at 6:03 PM, DLM <dlm34077(at)q.com> wrote:
  	  | Quote: | 	 		   Shortly after start, I apply power to my TT VSGV. The words AP OFF show on
		amekler
				 Posted: Tue Feb 28, 2012 1:19 am    Post subject: AP procedure |
				I do the same. It takes less time then the adhrs .
 Alan
 On Feb 27, 2012, at 9:03 PM, "DLM" <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
 [quote]           <![endif]-->       <![endif]-->
		rv10flyer
				 Posted: Tue Feb 28, 2012 5:17 am    Post subject: Re: AP procedure |
				Same for me. Toggle switch near ap. Startup all avionics with aux bat once plane is pulled out. By the time I hop in grt and xm is all ready to go. In case something goes wrong with me my wife knows how to hit the round knob too. She has been learning alot on the last 5 flights with the family. I would not build an RV without ap. In no time you are turning and then descending into a spiral dive.
  _________________ Wayne G. |
				 Posted: Tue Feb 28, 2012 6:49 am    Post subject: AP procedure |
				I have the AP (and the GRTs) on a 2nd buss - not same as starter     buss - so they come on with power up and complete their     initialization by the time I've started the engine and thought about     moving.
      Makes no sense to apply power after liftoff unless one has some     unfounded fear about the AP 'taking over' inadvertently.
      Bill
      On 2/27/2012 9:03 PM, DLM wrote:     [quote]                          <![endif]-->       <![endif]-->
				 Posted: Tue Feb 28, 2012 7:12 am    Post subject: AP procedure |
				Another thing I set was that the GRT is connected by its various power inputs to the primary bus and essential bus. The AP is on the primary bus only and the Cheltons are on the essential bus only.
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson
  Sent: Tuesday, February 28, 2012 7:47 AM
  Subject: Re: AP procedure
  Bill
    <![endif]-->        <![endif]-->Shortly after start, I apply power to my TT VSGV. The words AP OFF show on the screen. A friend indicated that he did not apply power to the TT until airborne; I suggested that was an unwise procedure because if inadvertently encountering IMC (dark night, low clouds or dark night and unlighted terrain) the AP can be used to maintain control of the aircraft. A touch of the round black knob will automatically synchronize the aircraft to the current heading by leveling wings and maintaining pitch attitude i.e. rate of climb. The TT AP has its own solid state pitch and roll sensors and the straight and level sensors are set at power up, preferably on the ground.  My TT is my third way to keep the clean side up and dirty side down, after the Cheltons and the GRT Sport.
    0123456789012
		Bob Turner
				 Posted: Tue Feb 28, 2012 2:37 pm    Post subject: Re: AP procedure |
				I have a Trio autopilot (which I like a lot btw), and I also boot it up prior to takeoff, not because I have to (it boots in flight just fine) but because it is my "third source" of attitude information, should there be a disagreement between the other two. The Trio shows a symbolic turn coordinator, even when disengaged, so it is easy to compare to the other 2 attitude sources. I also use the autotrim feature, manually, if the autopilot is not engaged. So I always boot it up prior to takeoff.
  _________________ Bob Turner
RV-10 QB |
