wdaniell(at)etb.net.co Guest
Posted: Sun Feb 26, 2012 4:08 am Post subject: post curing |
For the assembled wisdom
I need to post cure my flying surfaces. How have people done this? I
constructed a home-made "oven" as per the manual and didn't even get within
hailing distance of the temps required.
How did others do this?
Yours
Will
rlborger(at)mac.com Guest
Posted: Sun Feb 26, 2012 5:38 am Post subject: post curing |
Will,
You can see what I did by going to: http://www.europaowners.org/main.php?g2_itemId=60876
I have pictures of the oven, heaters and temperature.
The oven was made by covering a rolling work bench I made up with 1" blue insulating foam.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Yours
Will
kjburns(at)btinternet.com Guest
Posted: Sun Feb 26, 2012 4:00 pm Post subject: post curing |
Will,
another solution is to wrap in electric blanket layered with old duvets, controled by constructing an aquarium controler in to a power suply lead....http://www.ebay.co.uk/itm/AC-220-240V-Digital-Temperature-Controller-Thermostat-C-/160591018252
The electric blanket will blow its thermal fuse if you do not insulate enougth to achieve the temperature you have dialed in.
Also avoid over lapping the electric elements in layers or the element will fail, also good practice to suply through an ELCB, and consider safety of your set up and how and where you use it !
Kevin Burns.
Sent: Sunday, 26 February 2012, 13:37
Subject: Re: post curing
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)>
Will,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
Quote: | --> Europa-List message posted by: "William Daniell" <wdaniell(at)etb.net.co (wdaniell(at)etb.net.co)>
Yours
Will> p; -Matt Dralle, Libution" =======
keithhickling(at)clear.ne Guest
Posted: Sun Feb 26, 2012 9:59 pm Post subject: post curing |
William,
You need to take the thermostat out of circuit if you are using a fan
heater. They mostly have the adjustable thermostat which you can turn up
to about 30 degrees, and an additional safety thermostat which cuts the
power off at around 40 degrees as far as I recall. Aircraft Spruce
supply a kit with a thermostat that cuts the power off at about 80
degrees C and 2 thermometers. I used this as a safety backup, but found
that I could control the temp at 50 - 70 degrees by manually turning it
on and off. It would stay close to the required temp for 15 - 20 mins
after turning off. I also had a seperate fan to keep the air
circulating. I never went too far away from it during the whole process
and checked frequently that nothing was melting !
Keith Hickling.
Keith Hickling,
New Zealand.
Kit 613.
kelvin.cobb(at)gmail.com Guest
Posted: Mon Feb 27, 2012 3:38 am Post subject: post curing |
Hi all, I have a 10m autoclave in the Bristol area if anyone needs it....
Kelvin (G-BZAM) On Feb 27, 2012 6:04 AM, "keith hickling" <keithhickling(at)clear.net.nz (keithhickling(at)clear.net.nz)> wrote:[quote] --> Europa-List message posted by: keith hickling <keithhickling(at)clear.net.nz (keithhickling(at)clear.net.nz)>
William,
Keith Hickling.
Keith Hickling,
New Zealand.
Kit 613.
riddon(at)sent.com Guest
Posted: Mon Feb 27, 2012 6:30 am Post subject: post curing |
Hi William.
I built an 'oven' out of 2in Polystyrene sheets and used an electric greenhouse fan heater turned up to max for heat. To maintain an even temperature I wired a thermostat from an immersion heater into the mains supply and poked the sensor probe through the polystyrene. Worked a treat.
Richard Iddon
G-RIXS
Airborne once more.
On 27 Feb 2012, at 11:37, Kelvin Cobb wrote:
[quote] Hi all, I have a 10m autoclave in the Bristol area if anyone needs it.....
Kelvin (G-BZAM)
On Feb 27, 2012 6:04 AM, "keith hickling" <keithhickling(at)clear.net.nz> wrote:
William,
Keith Hickling.
Keith Hickling,
New Zealand.
Kit 613.
rparigoris
Posted: Mon Feb 27, 2012 8:24 am Post subject: Re: post curing |
Hi Guys
I sewed up a post curing tent. It's a round sausage made out of vinyl using a 4" muffin fan to keep it inflated and a zipper to get to your stuff. I forget the exact dimensions but the aluminium tubes ate 10 feet long so it's close to that.BTW a YKK Zipper leaks very little pressure compared to Velcro. Inside I have a 1500 watt articulating heater and a small fan to keep the air inside from stratifying. I used a pyrometer or two from my hot air balloons to keep track of the temps as well as a digital probe style. We just drape some bubble wrap over the top to insulate a little better. Works great. I only have one pic. of it:
http://www.europaowners.org/main.php?g2_itemId=27251
Here we have two thin wall aluminium tubes holding it opened as we were using it in the winter to keep new layups warm after we shut down the heat. All our post curing was done at Waynes home with no tubes. A small square of Duct tape closes the holes for the tubes. It stores in a bag smaller than a shopping bag.
If anyone is interested I also sewed up a 10' wide by 20" long and 9 foot high tent that lives resident in my Tin hangar in NY. The sides are Velcroed in place and can easily be removed to turn it into a hangar (top stays put 9' off the ground). Wew have heat from our home made heat exchanger and air conditioning.
Also is a sewn up was our paint booth. It rolls up to a big Q-tip when not being used. It has filtered air coming through a huge filter sewn to one side:
http://www.europaowners.org/main.php?g2_itemId=27216
The pics only show it 10 feet long, but I can add extra to make it large enough to paint the fuse and glider wings. The idea is the large 30" fan is blowing in fresh air through the filter that is close to the size of the wall. The air is going very slow. Then I have an attic fan in the door with a furnace filter in it. The 30" overcomes the attic naf and pressurizes the tent. I have to be careful, we need to put a restrictor over some of the intaqke side of the 30" fan or it will make the tent so hard it will fail. I should really sew up a "horses ass" relief valve, just a 8" tube with a rubber band holding it closed. It hangs fro two 10' tubes and once inflated can easily support 50 or more pounds hanging from the tubes.
Ron Parigoris
Posted: Tue Feb 28, 2012 4:01 am Post subject: post curing |
Thanks for the suggestions...
Crikey - there seems to be a lot of work in this and a requirement for
stable electrical supply which presents a challenge in Colombia. I think I
am going to be lazy and seek a car paint oven or autoclave.
Yours
Will
kheindl(at)msn.com Guest
Posted: Tue Feb 28, 2012 5:22 am Post subject: post curing |
It really isn't difficult or expensive, Will.I used polystyrene sheets (4 of 4x8') to make the oven against a wall. That takes maybe an hour, and you can re-use the sheets to insulate your house.
Put in a fan to circulate the air, a 3kw fan heater, and one or two of the cheap 'outdoor' thermometers, where you drop the probes through one or two holes in the top. With the oven empty,turn it all on and play with the settings on the heater until the temperature stabilizes where you want it.
Make sure you put some kind of baffle in front of the heater so there is no hot spot. Beforehand you also need to modify the heater to bypass the thermal safety cutout.
Karl
[quote] From: wdaniell(at)etb.net.co
Subject: RE: Re: post curing
Date: Tue, 28 Feb 2012 07:00:54 -0500
--> Europa-List message posted by: "William Daniell" <wdaniell(at)etb.net.co>
Yours
Will
rparigoris
Posted: Tue Feb 28, 2012 6:59 am Post subject: post curing |
Hi Will
You could always construct a black plastic sheet tent outside in the summer sun. Watch out for overhrating though! Open the doors and carefully monitor. Applied Arcaic Technology!
Ron Parigoris
"and a requirement for stable electrical supply which presents a challenge in Colombia." [quote][b]
Posted: Tue Feb 28, 2012 8:20 am Post subject: post curing |
thanks that sounds more like a “developing market” solution
When I use a heat gun sometimes all the lights go out….followed by wisps of smoke from the electrical outlet. The toil and strife gets a little peeved when the lights go out…again
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of rparigor(at)suffolk.lib.ny.us
Sent: 28 February, 2012 09:58
To: Europa
Hi Will
Ron Parigoris
"and a requirement for stable electrical supply which presents a challenge in Colombia." Quote: | http://www.matronics.com/Navigator?Europa-List | 01234567
budyerly(at)msn.com Guest
Posted: Tue Feb 28, 2012 9:09 am Post subject: post curing |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Ron, and everyone so kind to share your setups.
Just keeping the work in the un-airconditioned shop during cure works well for me during the Florida summers. The barn gets 115 degrees in the summer.
I share the concern of many of you on post curing. Especially now that Gurit Manufacturing no longer supplies Ampreg 20, and Europa is now forced into using Ampreg 21 exclusively in the kits. This is a great laminating resin, it is more difficult to cure at room temp of 18C or about 65 degrees with all but the fast hardener and the time to pull from the mold or pull the peel ply is at least 16-20 hours, increasing shop cure time... Gurit recommends a 50C or 122F cure for 16 hours before de-molding, which is a long time..
I am working with Dave Goddard and Jon Pool at the Europa center to explore a new chapter on heat curing the 21. In the European and northern markets, you may find the 21 cures way too slow and the MSDS and instructions from Gurit require a well above room temperature post cure to allow sanding and handling the next day. I have no alternatives for those of you in Europe. See the the Gurit instructions: http://www.gurit.com/files/documents/ampreg-21v7pdf.pdf
As many of you know I use Aeropoxy (similar to Ampreg 20) for my laminations as it cures at 75F in modest humidity and is sandable in 12 hours. So overnight post cure is simply: set the thermostat in the shop and go home. This is not the case everywhere of course, but very easy to achieve...
I'll let you all know what we come up with.
Glad to hear and see your post cure ideas. I have used an old dryer with thermostat but alas the old girl gave out and I need to build a new post cure heater.
Bud Yerly
Europa Tech Support
