Tom463(at)aol.com Guest
Posted: Fri May 26, 2006 5:44 pm Post subject: 503 Running Cold |
I have a Rotax 503 DCDI, with oil injection, on a Firestar II. The engine
is about 50 hours out from a total rebuild and has been performing flawlessly,
except during the past 5 or 6 hours, it has started running cold. The EGT's
stay around 9 and 10 on the gauges at 5000 RPM, which is where I regularly
cruise. My one CHT gauge used to read around 2.5, but lately it is getting
down to 1.5 or less. I suspected a problem with the gauge; however, when I
throttle back to idle for landing, it will climb back up to between 2 and 2.5, by
the time I'm at a full stop on the ground. The readings on the EGT's increase
and decrease in conjunction with the RPM's of the engine. The engine doesn't
seem to perform or sound any differently. The Tiny Tach says my max RPM on
take-off is 6200 on a 3 blade Warp Drive. I'm no mechanic. Any suggestions?
_Tom463(at)aol.com_ (mailto:Tom463(at)aol.com)
HShack(at)AOL.COM Guest
Posted: Fri May 26, 2006 7:32 pm Post subject: 503 Running Cold |
In a message dated 5/26/2006 9:45:06 PM Eastern Standard Time, Tom463(at)aol.com
writes:
2.5, by
increase
My guess is that either your gage or sensor or wiring is wrong. Temps should
be around 300 degrees or so; what's with the 1.5, 2.0, etc.? Can't think of
anything that would actually make CHT's go down.
I also think your max RPM on takeoff should be about 200 rpm higher; take
about 1 degree pitch out of your prop.
Howard Shackleford
FS II
SC
