OT: Old electronics info.
raymondj(at)frontiernet.n
PostPosted: Mon Mar 05, 2012 7:29 pm    Post subject: OT: Old electronics info. Reply with quote
Greetings,
I have an Acme Voltrol type T-2-1404 variable transformer I'm using to
set up a power supply for my bench. Can anyone tell me where I can get
the max Amps or VA rating for it?
I also have a big red rectifier that is about a 6" cube of fins and an
inductor that is the size of a softball and weighs >10lb. Neither have
any identifying marks on them.
Any sources where I can find info on these things would be appreciated.
Thanks in advance,
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
PostPosted: Tue Mar 06, 2012 8:40 am    Post subject: OT: Old electronics info. Reply with quote
At 09:23 PM 3/5/2012, you wrote:
--> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net>
Greetings,
I have an Acme Voltrol type T-2-1404 variable transformer I'm using to set up a power supply for my bench. Can anyone tell me where I can get the max Amps or VA rating for it?
What are the physical dimensions of this device?
Sounds like a selenium rectifier . . .
http://en.wikipedia.org/wiki/Selenium_rectifier
Certainly something you'd want to replace with
a silicon bridge rectifier.
and an inductor that is the size of a softball and weighs >10lb. Neither have any identifying marks on them.
The inductor would be used in concert with one or more
capacitors to smooth the full-wave rectified DC output
current.
How would you want to use this supply? Variable transformers
are auto-transformers that generally deliver 0-100% or perhaps
135% of input voltage depending on how they are wired. The
have output wires in common with the input wires. In other words
they are not isolated from the AC line . . . so there are potential
shock hazards to consider when using these as the sole controlling
device for variable voltage. Further, unless you need to do testing
at voltages above 14 or 28 volts, you would not be able to use
much of the transformer's dynamic range.
You would probably want to use the variable transformer to
drive a 120 to 12 or 24 volt transformer. This will make
better use of the variable transformer's utility and
possibly get you more current capability too.
Getting smooth DC is another problem. You can probably
use the inductor you have and add some capacitors . . .
but you're going to find that the output voltage is
very poorly regulated with respect to changing loads.
Suggest you consider an electronically regulated
bench power supply like:
[img]cid:.0[/img]
Devices like this will give you stable, current limited,
smooth and very adjustable output. This one is $75 off
of ebay. You might be able to sell your venerable
components and cover much of the cost a supply like this.
I have 5 such supplies here in shop ranging in output
from 200 Ma to 50 amps. They're invaluable tools when
they perform well . . . I'm pretty sure that after you
spend the time hammering a supply together using the
parts you have, you'll be disappointed in the performance.
I have one variable transformer controlled supply. It's
for providing low current, 0-500 volts dc for some vacuum
tube work I was doing years ago. Haven't used it in years
but I'll be showing it (and the vacuum tubes) to my grandsons.
 Filesize:  13.82 KB
 Viewed:  2744 Time(s)
PostPosted: Tue Mar 06, 2012 9:39 am    Post subject: OT: Old electronics info. Reply with quote
I think you correct in identifying the rectifier.
The Voltrol is about 4x4x8. It has 2 ranges covering 0-140 V. Weighs
about 20 lb.
It was originally set up with 2 50V caps and the inductor.
I have it breadboarded with a bridge rectifier and cap/resistor filter.
I have some projects which require 50-90 V DC and 10-15 amps. I don't
think the Voltrol will pass more than about 5 amps based on the size of
the wire on the windings. But I'd rather know than guess.
How critical is the matching of the inductor with a pair of caps to use
as filter, similar to the one that was originally used? Of course I
would use caps with high enough voltage ratings. I'm willing to deal
with the poor filtering to get the utility for little $. Might even
consider building a regulating circuit at a later time.
I have a couple of Heathkit regulated power supplies for most of the
electronic bench work.
One other question. I have a couple of Simpson amp meters, the one's
that are about 3" in diameter. One ac and one dc. Are those designed to
be wired in series with the load, or do they need a shunt of some sort?
Unfortunately I didn't pay close attention when I salvaged these.
I regret having to take time on the list, but I've spent hours on the
net without any success.
Thanks for taking time to share your knowledge.
Raymond Julian
Kettle River, MN
> Greetings,
current.
Emacs!
PostPosted: Tue Mar 06, 2012 2:51 pm    Post subject: OT: Old electronics info. Reply with quote
Almost forgot. If all you want to do is fire up
your airplane or car's accessories on the bench,
perhaps you don't even need an adjustable power
supply and meters. These power supplies are
http://tinyurl.com/7dqjkve
[img]cid:7.1.0.9.0.20120306104210.01dfb188(at)aeroelectric.com.0[/img]
an excellent value. This 13.5 volt, 28A power supply
is $40 delivered to your door. 28 amps will run a lot
of stuff.
 Filesize:  32.49 KB
 Viewed:  2737 Time(s)
