efraim.otero(at)gmail.com Guest
Posted: Wed Mar 07, 2012 6:18 am Post subject: Simple electrical System for wooden biplane VFR |
Jerry!
Thanks for your answer. I have SL 40 magnetos and an aviation ignition
harness. Spark plugs are Champion massive electrode REM40E. Curious
thing is that a few months before I didn't get that noise. I have a
whip antenna connected to the Icom with RG58 coax... Any ideas?
On 3/7/12, racerjerry <gki(at)suffolk.lib.ny.us> wrote:
Sent from my mobile device
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Thu Mar 08, 2012 6:31 am Post subject: Re: Simple electrical System for wooden biplane VFR |
I am unfamiliar with your magneto. Check to see if your magneto āPā leads are shielded. Typically, the āPā leads are made from 16 gauge shielded wire. Look at the magneto end of the wire and you should see the shielding separated out and terminated into a separate ground connection at the magneto housing.
Due to vibration, it is fairly common to see this ground connection break and open up. Since you say the interference problem only recently began, I suspect that this is what has occurred.
_________________ Jerry King |
