Rotax Fuel Injected Engine Rotax 912 IS - finally. I wonder
peterz(at)zutrasoft.com
PostPosted: Thu Mar 08, 2012 7:02 am    Post subject: Rotax Fuel Injected Engine Rotax 912 IS - finally. I wonder Reply with quote
Scraped from the Pipstrel newsletter.....fwiw
Pete
A239
ROTAX, a name that is synonymous with light aircraft, LSA aircraft and
even military drones and in a co-operation with Pipistrel today marks a
very important milestone in the history for ROTAX with the release of the
new fuel injected 912 IS aircraft engine.
**[image: Pipistrel Virus SW 912 iS]**
This new engine the ROTAX 912 IS produces 100 hp from what is basically the
same engine core as the 912 ULS with the exception that the carburettors
are gone, now replaced with modern fuel injection. This relieves the engine
from carburettor imbalance and provides perfect start-up/shutdown and idle
just like a modern car. The choke has gone and the engine responsiveness
has been increased substantially along with an approximate 10% reduction in
fuel consumption at normal cruising speeds.****
As the world's leading supplier of aircraft engines for Ultralight and LSA
aircraft, ROTAX aircraft engines have truly revolutionized the aircraft
industry. The popularity of these engines continues to soar higher and
higher, from the original two-stroke engines through to the modern four
stroke engines ROTAX produce an engine for just about every aviation
application and many hundreds of non-aviation applications.
**[image: Rotax 912 iS]**
The 4-stroke 4-cylinder boxer engines we are now familiar with and known as
the ROTAX 912 series started development in 1984 having advanced technology
and superior weight/performance ratio and have propelled experimental,
Ultralight, LSA aircraft and motorgliders for many years gaining themselves
an enviable reputation for reliability, low noise, fuel efficiency and most
important actually reaching the TBO times. ROTAX aircraft engines are
available in two configurations including fully certified engines as well
as noncertified engines; both are very similar and enjoy a fantastic
reputation.
Today is a significant milestone for both Pipistrel and ROTAX with the
release of the 912 IS engine, ROTAX have chosen Pipistrel as the 912 IS
release customer and the engine has been fitted and tested on the
award-winning Pipistrel Virus SW aircraft. Those that have flown the
aircraft report increased smoothness, faster throttle response, lower idle
and most importantly for the environment less fuel consumption for this
exciting new engine.****
*Now a little history lesson.*
*1920* The company was founded in Dresden, Germany as ROTAX-WERK AG.****
*1930 *Taken over by Fichtel & Sachs AG, the company transfers its
operations to Schweinfurt/Germany.****
*1943 *The company’s operations are relocated to Wels, Austria.****
*1947 *The company’s operations get relocated to Gunskirchen near Wels.**
*1959 *This year sees LOHNERWERKE GmbH of Vienna acquiring a majority
shareholding.****
*1962* For the first time, a ROTAX engine is installed in a Ski-Doo
snowmobile developed by bombardier.****
*1970 *This year sees integration of Bombardier and ROTAX. The former
Bombardier Inc. branch BRP, now an independent company, uses ROTAX engines
in its motorcycles, personal water craft, and snowmobiles.****
*1977 *High orders of snowmobile spare engines ROTAX*® *185, 248, 284,
294 are also used in Ultralight aircraft.****
*1978 *Ultralight engines 501, 505 developed (based on snowmobile engine
503).****
*1982 *The company begins development of ROTAX 4-stroke aircraft
engines, a landmark in ROTAX history.****
*1983 *The company starts producing ROTAX motorcycle engines for APRILIA
