BNC Shells touching
rvg8tor
PostPosted: Thu Mar 08, 2012 12:58 pm    Post subject: BNC Shells touching Reply with quote
My GNS-430W is a tight fit and the connections for the 4 antenna cables are very close to each other. One of them is close to a cross cabin brace and the outside of the BNC can touch this metal brace.
Is this a big deal, should I wrap the outsides of all the BNC connectors so that they can't make metal to metal contact or does it matter.
Cheers
Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor
PostPosted: Thu Mar 08, 2012 3:00 pm    Post subject: BNC Shells touching Reply with quote
Making contact isn't a big deal electrically but having
things bang together or rub mechanically can wear things
where they were not intended to wear.
Certainly some sort of buffer between otherwise touching
parts is a good idea. We wouldn't be allowed such liberties
in a TC airplane. As much as we'd like to think that
the machine is a rigid body, there are in-flight stresses
that can cause clearances to change under certain
conditions. I recall reading a spec at Beech on minimum
clearances both for access and separation.
But anything you stick in the gap might be the occasion
for considerable force to bear against the connectors
if that gap were to close for any reason.
In the best of all worlds, you'd strive for a half inch
or so of clearance.
