Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
pfdwind(at)live.com Guest
Posted: Sat Mar 10, 2012 3:30 pm Post subject: Lycoming Engine/Carb AD |
All,
I have a Lycoming O320 in my TR1 and I am having a difficult time starting it during these cold mornings. I am not sure if it is due to a low cranking capacity battery or the lack of a primer. I do have an electrical fuel pump. Is anyone else experiencing this? Any suggestions or recommendations? Thanks.
Peter
Date: Sat, 25 Feb 2012 09:15:00 -0600
Subject: Re: Lycoming Engine/Carb AD
To: kis-list(at)matronics.com
Also, the Carburetor manufacturer, Marvel-Schebler Aircraft Carburetors LLC has issued and revised an Emergency Service Bulletin (SB) No. SB-18, dated October 14, 2010, to Revision A, dated March 15, 2011. Their position is to do comply with the SB before further flight.
http://msacarbs.com/pdf/SB-18_A%20031511.pdf
Pass this on to anybody you know that has a Lycoming normally aspirated engine.
Galin
On Sat, Feb 25, 2012 at 8:52 AM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]All;
The FAA has issued an AD for a particular carburetor installed on many Lycoming engines. Check and make sure you don't have one of the affected carburetors on your engine.
Here is a link to the AD: http://www.eaa.org/news/2012/2012-03-07.pdf
Galin
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
rget="_blank">http://www.matronics.com/Navigator?KIS-List
http://forums.matronics.com
sstearns2(at)yahoo.com Guest
Posted: Sat Mar 10, 2012 4:26 pm Post subject: Lycoming Engine/Carb AD |
Do you have an accelerator pump on the carb? It should on a 320 or larger. It pumps some extra fuel in to accelerate the engine when you increase the throttle. You can pump the throttle a few times while the engine is cranking to get some more fuel into the dense cold air. You do not want to pump too much or pump with the engine stopped since fuel will drip out of the carb.
You could always go to fuel injection. I like my silverhawk setup.
Also, if you do not already have one, a modern battery like the Oddessy batteries in aircraft spruce should give you more cranking power for the same weight and size.
Scott
On Mar 10, 2012, at 3:29 PM, Peter Duran <pfdwind(at)live.com (pfdwind(at)live.com)> wrote:
[quote] All,
Peter
From: [url=mailto:galinhdz(at)gmail.com]galinhdz(at)gmail.com (galinhdz(at)gmail.com)[/url]
To: [url=mailto:kis-list(at)matronics.com]kis-list(at)matronics.com (kis-list(at)matronics.com)[/url]
Galin
On Sat, Feb 25, 2012 at 8:52 AM, Galin Hernandez <[url=mailto:galinhdz(at)gmail.com]galinhdz(at)gmail.com (galinhdz(at)gmail.com)[/url]> wrote:
Posted: Sun Mar 11, 2012 3:15 pm Post subject: Lycoming Engine/Carb AD |
Thanks Scott. I am not sure if the pump in the plane is an accelerator pump, I will check. A few aviator friends have mentioned the Optima batteries which have significantly higher crank capacity.
Pete
Subject: Re: KIS-List: Lycoming Engine/Carb AD
Date: Sat, 10 Mar 2012 16:33:42 -0800
Scott
On Mar 10, 2012, at 3:29 PM, Peter Duran <[url=mailto:pfdwind(at)live.com]pfdwind(at)live.com[/url]> wrote:
[quote] All,
Peter
From: [url=mailto:galinhdz(at)gmail.com]galinhdz(at)gmail.com[/url]
To: [url=mailto:kis-list(at)matronics.com]kis-list(at)matronics.com[/url]
[url=http://msacarbs.com/pdf/SB-18_A%20031511.pdf]http://msacarbs.com/pdf/SB-18_A%20031511.pdf[/url]
Galin
On Sat, Feb 25, 2012 at 8:52 AM, Galin Hernandez <[url=mailto:galinhdz(at)gmail.com]galinhdz(at)gmail.com[/url]> wrote:
| Quote: | All;
Here is a link to the AD: [url=http://www.eaa.org/news/2012/2012-03-07.pdf]http://www.eaa.org/news/2012/2012-03-07.pdf[/url]
Galin
et="_blank">[url=http://www.matronics.com/Navigator?KIS-List]http://www.matronics.com/Navigator?KIS-List[/url]
_blank">[url=http://www.matronics.com/contribution]http://www.matronics.com/contribution[/url]
rget="_blank">[url=http://www.matronics.com/Navigator?KIS-List]http://www.matronics.com/Navigator?KIS-List[/url]
[url=http://forums.matronics.com]http://forums.matronics.com[/url]
="_blank">[url=http://www.matronics.com/contribution]http://www.matronics.com/contribution[/url]
ef="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
st" target="_blank">http://www.matronics.com/Navigator?KIS-List
lank">http://forums.matronics.com
rget="_blank">http://www.matronics.com/contribution
