Jabiru 3300 Over Voltage
Goto page Previous  1, 2
PostPosted: Wed Mar 14, 2012 12:06 am    Post subject: Re: Jabiru 3300 Over Voltage Reply with quote
Good points Noel. In Rich's airplane, the alternator is actually a permanent magnet dynamo. There are no field coils or brushes.
Rich, You mentioned in an earlier post that the circuit breaker was cool only when the voltage sense wire is connected directly to the battery. That tells me that the voltage regulator sense wire is carrying excessive current. That is another indication that the regulator is bad.
Heat could be causing the regulators to fail. I suggest that a shroud be installed over the regulator and that cooling air be forced into the shroud with 5/8" duct.
Joe
Joe Gores
PostPosted: Wed Mar 14, 2012 12:29 pm    Post subject: Jabiru 3300 Over Voltage Reply with quote
At 09:37 PM 3/13/2012, you wrote:
> Have you seen any data source that argues with what's shown above?
No, I was going by Rich's schematic that shows the lamp connected to
the outside terminal of the voltage regulator. But now Rich has
explained that his drawing is a schematic and not a wiring
diagram. He is confident that the voltage regulator is wired
correctly. I believe him.
Okay.
I see 3 possible causes for the high voltage:
1. There is a wiring error.
2. There is an intermittent high resistance connection between the
main bus and the ignition terminal of the regulator, or between
regulator ground and aircraft ground.
I like this one. The whole purpose of a
dedicated sense lead is to prevent a sharing
of operating currents with measurement currents.
Obviously, the negative lead of the regulator
output is the case ground . . . which is also
the negative sense lead!
I'd go for an experiment to un-mount the regulator
from it's present location, attach a robust ground
lead from regulator case to ship's single point
ground. 10AWG would be good. Then go fly it and
see what the voltage does.
3. The voltage regulator is bad.
Maybe . . . but 'bad' regulators generally work
or don't work. This regulator is behaving like it
it is in distress but not failed.
_
Due to the fact that the 5amp circuit breaker gets warm, I suspect
the voltage regulator is bad.
It would be interesting to see what kind of
breaker he's using. The size of the heater in
a miniature breaker is so small
http://aeroelectric.com/Pictures/Breakers/Klixon_1.jpg
I cannot imagine how you get a enough continuous
load to 'warm' the breaker. Let's say you get
4.9999 amps flowing in the breaker to 'warm' it up
without tripping it. This implies that some soft
fault downstream of the breaker is dissipating
4.999 x 14 = 70 watts! That amount of energy being
dumped inside the regulator would probably get
you some form of gross failure or at least some
bad smells.
It seems to me that the voltage between the regulator ground
terminal and the regulator voltage-sense terminal should never go
above the set point (14.2). If it does, then the regulator is not
doing its job, regardless of any loose connections elsewhere.
Exactly . . . and the ground lead is highly
suspect.
The voltage is still too high, even with the voltage-sense wire
connected directly to the battery. That eliminates the circuit
breaker and the master switch as potential problems.
Bob, please correct me if my reasoning is faulty. Just do not tell
my wife that I made a mistake.
Sounds good so far.
PostPosted: Fri Mar 23, 2012 5:42 am    Post subject: Re: Jabiru 3300 Over Voltage Reply with quote
Rich,
Did you ever solve the high voltage problem? Did you try adding a robust ground lead from regulator case to ship's single point ground as Bob Nuckolls suggested? Or was the regulator bad? I am curious to know the answer.
Joe
Joe Gores
Page 2 of 2
