rudder trim
Strasnuts
PostPosted: Thu Mar 15, 2012 8:13 pm    Post subject: rudder trim Reply with quote
I just installed a rudder trim today that Aerosport Products made. I am testing the design and was very pleased with the results. I didn't want the electric rudder trim since it was a lot of labor and put weight in the rudder. I was holding out for a bias system that used the entire rudder. I know builders who installed the electric version and like them but this new product was just what I was looking for. It literally took me 30 minutes to install and worked perfect. I didn't know where to set it for the first test run so I took off normally. At cruise I dialed it in and immediately was grateful to pull my foot off the right rudder where I had been resting it for the 180 hours I have on the plane. This system uses a dial which is geared to two cables attached to springs and finally hooked on to two clamped arms on the rudder crossover tubes. I can dial in the cruise descent and cruise climb in a few seconds. It is very compact as you can see in the photo. I'm already happy with it and I only flew with it for a fairly short flight today. I took a quick pic with my iphone and will get some better pics later. Feel free to contact me with any questions.
 Filesize:  114.79 KB
 Viewed:  3534 Time(s)
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
johngoodman
PostPosted: Sat Mar 17, 2012 5:29 am    Post subject: Re: rudder trim Reply with quote
It looks like the same system that I installed - bought from M.L. Skunk Works several years ago. It works great. I will admit that the RV-10 needs very little rudder trim in cruise that I can see.
rleffler
PostPosted: Sat Mar 17, 2012 7:39 am    Post subject: rudder trim Reply with quote
Not really, the concept is similar. The control head is significantly smaller and my very biased opinion is that it's better engineered.
On Mar 17, 2012, at 9:29 AM, "johngoodman" <johngoodman(at)earthlink.net> wrote:
#40572 Phase One complete and flying.
http://forums.matronics.com/viewtopic.php?p=368764#368764
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
