Poor Wiring Practice for VHF Noise?
stearman456
PostPosted: Fri Mar 16, 2012 5:45 am    Post subject: Poor Wiring Practice for VHF Noise? Reply with quote
Hi Bob,
Would it be poor practice from an RFI point of view to run the avionics bus + wire and the strobe light power supply (Whelan A13A, HDA CF-14/28 ) + wire in the same bundle? Or the VHF + wire (remotely located Garmin SL40) and strobe light power supply + wire in another bundle? My switch panel is almost finished and will have these two bundles coming in and then going out of it. The "fat" wires are all up front on the firewall about 4 ft away.
Dan
PostPosted: Fri Mar 16, 2012 10:19 am    Post subject: Poor Wiring Practice for VHF Noise? Reply with quote
At 08:45 AM 3/16/2012, you wrote:
Hi Bob,
In the heavy iron bird business, products bolted
to airplanes are expected to be friendly citizens
of the avionics community. In fact, there is a
price of admission for gaining a seat aboard a type
certificated aircraft. See:
http://www.aeroelectric.com/articles/Philosophy/Whats_all_this_DO160_Stuff_Anyhow.pdf
When every systems guy has to fight for and then
jealously guard space on the airplane allotted to
his efforts, it would be a disaster of some discovery
were made where separation of certain wires from certain
other wires was necessary or useful.
Short answer is that wire bundles properly installed
do not need to be separated for the purpose of
protecting the performance of the home system
or its neighbors.
( -Thomas Paine 1776- )
stearman456
PostPosted: Sat Mar 17, 2012 6:17 am    Post subject: Re: Poor Wiring Practice for VHF Noise? Reply with quote
Of course! I never stopped to look at it from that angle. That makes perfect sense. Thanks very much for the help.
Dan
