VGs on vertical stabilizer
mburdge39
PostPosted: Tue Mar 20, 2012 3:38 am    Post subject: VGs on vertical stabilizer Reply with quote
Hi all! I am hoping someone can help me with my placement of VGs on my vertical stabilizer. The directions on my Airwave vortex generators state "5 degrees from level flight". Would someone be able to give me the angle, in relation to the rudder, as my Firefly sits on the ground? Installing on the wing & horizontal stabilizer went smoothly and don't want to screw this up.
Thanks!
 Filesize:  5.36 KB
 Viewed:  12223 Time(s)
Firefly
Mike Welch
PostPosted: Tue Mar 20, 2012 3:52 am    Post subject: VGs on vertical stabilizer Reply with quote
Mike,
Wouldn't "level" flight be referenced from your horizontal stabilizer. Raise you hor. stab. up to level position,
and that is "level flight". No?
Mike Welch
Thanks!
Firefly
http://forums.matronics.com/viewtopic.php?p=368947#368947
http://forums.matronics.com//files/vertical_stab_195_798.jpg
mburdge39
PostPosted: Tue Mar 20, 2012 4:27 am    Post subject: Re: VGs on vertical stabilizer Reply with quote
I guess I have over-complicated things here. With the boom tube angled up during level flight it appeared to me that the horizontal stabilizer was also at an angle.
Thanks!
Firefly
Richard Pike
PostPosted: Tue Mar 20, 2012 6:48 am    Post subject: Re: VGs on vertical stabilizer Reply with quote
I suspect that gap sealing the vertical stab to the rudder would also help. But you've probably already done that.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
byoungplumbing(at)gmail.c
PostPosted: Tue Mar 20, 2012 7:58 am    Post subject: VGs on vertical stabilizer Reply with quote
Firefly
First of all,,, do you lack rudder authority? if no,, why vg's there? which side of the rudder or both sides? in straight and level flight, do you need to hold right or left rudder to center the ball? maybe you only need one side. for W&B it says to have your wing at some angle of attack,,,, with the wing at that angle, is the horizontal stabilizer level? if so you could measure from there. OR you could go for a flight and take a level and some shims with you, while in level flight place the level on the floor along the center line of the plane. and see what size of shim is needed to show level, then calculate from there. OR, an electronic level on the floor, then push the hold lock button and read the angle. duplicate that on the ground, then measure. OR better yet, tuft the tail and have someone take a picture with you in the air. that way you would be 5 deg from the air flow, not withstanding where level is. the wind from the prop may cause some swirling of the air past the vertical stabilizer, which would be different if the engine quit, or at an idle on approach.
as for me, I don't lack for rudder authority. I have considered vg's,,,, on the wing and bottom of the horizontals... but never the vertical. the empennage on the kolbs have a long moment arm and accelerated air from the prop, it should not run out of authority.
food for thought
boyd young
mkiii
pj.ladd(at)btinternet.com
PostPosted: Tue Mar 20, 2012 9:32 am    Post subject: VGs on vertical stabilizer Reply with quote
placement of VGs on my vertical stabilizer>>
You need extra lift on your VERTICAL stab.?
You fly on your side a lot do you?
Pat
mburdge39
PostPosted: Tue Mar 20, 2012 10:57 am    Post subject: Re: VGs on vertical stabilizer Reply with quote
Haha! I really just didn't want to waste half a box of VGs! I will just keep them with my other "extras". I will stick with just the horizontal stabilizer & wing.
Firefly
beauford
PostPosted: Tue Mar 20, 2012 1:28 pm    Post subject: VGs on vertical stabilizer Reply with quote
Brother Mike:
I put 'em on both sides of my Fly's vertical stab... For two reasons:
1. Had extra VG's and they were paid for.
2. They looked cool and drew lots of questions from gullible onlookers.
They have been on there for about five years... Probably have some slight
effect on rudder authority, but likely not as much as Brother Pike's
suggestion
to seal the gap would have.
Not to put too fine a point on it, but suspect the agony over the VG
mounting angle may
not have a high payoff fer ye... Kinda like using a micrometer on a
buttermilk biscuit...
Worth what ye paid fer it...
beauford
FF-076
Brandon, FL
jbhart(at)onlyinternet.ne
PostPosted: Tue Mar 20, 2012 3:42 pm    Post subject: VGs on vertical stabilizer Reply with quote
Firefly
Additional rudder authority lets one hold greater forward and side slips. This can be helpful in spilling altitude and enables landing in higher cross winds.
Jack B. Hart FF004
Winchester, IN
