JLuckey(at)pacbell.net Guest
Posted: Wed Mar 21, 2012 1:35 pm Post subject: wingtip vor antenna - SWR Meter |
Can this radio shack be used for aviation comm radios?
http://www.radioshack.com/product/index.jsp?productId 36239
(at < $40, the price is sure right)
IIRC, CB's are around 27 Mhz & airplane radios operate 118-136 Mhz. Is that
a problem?
Float Flyr
Posted: Wed Mar 21, 2012 2:45 pm Post subject: wingtip vor antenna - SWR Meter |
Yes, it is a problem the diodes in this meter are not nearly fast enough to
break the RF (Radio Frequency) of VHF into digital segments needed to
measure SWR. This unit is usable for frequencies 30 mHz and below.
You may find a serviceable meter on eBay. If you buy a Bird Wattmeter make
sure the element for 100-250 mHz comes with it.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Wed Mar 21, 2012 4:09 pm Post subject: wingtip vor antenna - SWR Meter |
At 05:42 PM 3/21/2012, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
sure the element for 100-250 mHz comes with it. |
The Bird products are the gold standard for
RF wattmeters. A few months ago we had some
discussion on the List about the HF SWR
meters common to CB radio frequencies and
below. These are not suited to VHF as their
sampled transmission line is too long with
respect to a wavelength at the frequencies
of interest for VHF. They tend to give 'good'
readings to poor antennas.
We also had some discussions about this device:
[img]cid:7.1.0.9.0.20120321190040.01dfbec0(at)aeroelectric.com.0[/img]
Which you can get off eBay for about $60 postage paid.
http://tinyurl.com/7cl4bba
I purchased one of these and found it a quite good
value. Reasonably accurate for power readings down
into the 100 milliwatt range.
The one I have here on my bench is spoken for and
will be out of here next week . . . but the folks
offering it on eBay have plenty more. Be sure to
get two N-Male/BNC-Female adapters.
[img]cid:7.1.0.9.0.20120321190040.01dfbec0(at)aeroelectric.com.1[/img]
http://tinyurl.com/6m7ujmw
These are about $2.50 each postage paid.
65.5 KB |
3322 Time(s) |
94.11 KB |
3322 Time(s) |
Posted: Thu Mar 22, 2012 1:48 pm Post subject: wingtip vor antenna - SWR Meter |
At 01:52 PM 3/22/2012, you wrote:
| Quote: | | Reading the page on this meter I assume it is not a good meter for use on RF below 100mHz. |
It's accuracy will degrade as you depart the
manufacturer's specified range of performance.
If you buy a 'slug' for a Bird wattmeter
[img]cid:7.1.0.9.0.20120322164307.0467ecc0(at)aeroelectric.com.2[/img]
It is characterized for a power level and a
range of frequencies for which it will meet
the manufacturer's specs for accuracy.
The 'Red Dot' SWR meter is simply a power
meter with a 'fixed slug'.
42.01 KB |
3314 Time(s) |
