Kolb quit revealed
Goto page Previous  1, 2
russk50(at)gmail.com
PostPosted: Sat Mar 31, 2012 6:51 am    Post subject: Kolb quit revealed Reply with quote
In re the famous/infamous "Kolb Quit", as RV 40072 says, it's nothing but a stall. However, the Kolb has a straight wing, which means it will stall all at once; it's flying one minute, and then at 2-3 MPH slower, the whole wing has stalled. That's why it's been called violent, gets your attention and can be terrifying. That's also why you should never get too near a stall unless you're just a few feet above the ground.
Those who have flown GA aircraft are used to a much more gentle stall -- that's because the wing has some twist, or wash-out, where the wing root stalls first and the rest of the wing is still developing lift. The tips stall last, so the ailerons are still effective as long as possible.
To be accurate, stalls are a function of angle of attack, not airspeed; but since we don't have AOA indicators we have to use airspeed instead. It does work.
An experienced pilot will do it mostly by feel anyway, at the landing flare.
Russ K
On Mar 30, 2012, at 11:13 PM, Rv40072wrote:
I have been following these discussions about Kolb quits for some time. In case anyone has not figured it out, Kolb quit is nothing more than a stall. The first thing to grasp is that stalls are not a function of airspeed. They are function of Angle of Attack. Depending on weight, g-load applied, air density, the airplane will stall at different airspeeds., and can in fact be stalled at any airspeed. The airplane will however, always stall at the same angle of attack. The following link will give one a good start on understanding stalls. http://en.wikipedia.org/wiki/Stall_(flight)
Vic, cudos for pursuing a better understanding, but instead of focusing on what airspeed it stalls at, focus on how it feels just before it stalls. The second alternative would be to build a simple angle of attack indicator, then you would have a visual warning of impending stall.
Have fun, and safe flying.
http://forums.matronics.com/viewtopic.php?p=369668#369668
racerjerry
PostPosted: Sat Mar 31, 2012 6:54 am    Post subject: Re: Kolb quit revealed Reply with quote
Well, I am certainly glad that we got rid of the hostility and returned to a friendly technical discussion.
Vic claims that he is experiencing a difference in stall speed at different ATTITUDES. On the surface this seems implausible, but he may be quite correct. Pitot tube error at higher angles of attack could be causing a false (lower) airspeed indication. I would suggest repositioning the pitot to a slightly lower angle to confirm.
Jerry King
Vic Peters
PostPosted: Sat Mar 31, 2012 8:18 am    Post subject: Kolb quit revealed Reply with quote
Hey guys and others
No more hostility from me. I'm brewing my own beer.
I agree with everyone so far.
These recent posts are very helpful. I like the idea of 2 finger stick control and I've read up on stalls and
ground effect on wicked pedia till my head exploded.
" The critical angle of attack in steady straight and level flight can be attained only at low airspeed"
" Ground effect causes higher air pressure under the wing (more lift) and lower drag"
So it still just doesn't make sense that at altitude straight and level no stall at 35mph (unless I'm sinking and don't know it). Ground effect should lower stall speed not be the same. Pitot could be wrong but always seems to match gps, no wind ofcourse. VG's are'nt really working in level flight but at high angle of attack they really kick in. (28mph)
That's what they are supposed to do I think. The boys at Kolb got that stall in an Extra by lowering the leading edge
of the wing. I assume to get lift from the big flat fuselage bottom.
Still stumped
Vic
912ul Xtra
Maine
Too old to cut the mustard but not the cheese.
pj.ladd(at)btinternet.com
PostPosted: Sat Mar 31, 2012 9:42 am    Post subject: Kolb quit revealed Reply with quote
<<That's also why you should never get too near a stall unless you're just a
few feet above the ground.>>
Good grief!. If ever a statement is guaranteed to get someone killed that
is it.
A stall `a few feet ` above the ground will just allow enough room for a
nosedive straight onto mother Earth.
The idea of making a landing is to stall a few INCHES above the ground.
Cheers
Pat
PostPosted: Sat Mar 31, 2012 9:45 am    Post subject: Kolb quit revealed Reply with quote
Russ?
(Stalling a few feet above the ground.)
I just realised who sent that message. I cannot believe it was you. Tell me
you didn`t mean it
Pat
lcottrell
PostPosted: Sat Mar 31, 2012 10:20 am    Post subject: Kolb quit revealed Reply with quote
Maybe your nose is shorter than ours. You do remember that we seem to be just a little different over here.
Larry
On Sat, Mar 31, 2012 at 11:41 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
--> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
<<That's also why you should never get too near a stall unless you're just a few feet above the ground.>>
Good grief!.  If ever a statement is guaranteed to get someone killed that is it.
A  stall  `a few feet ` above the ground will just allow enough room for a nosedive straight onto mother Earth.
Cheers
Pat
le, List Admin.
Eugene Zimmerman
PostPosted: Sat Mar 31, 2012 10:57 am    Post subject: Kolb quit revealed Reply with quote
Kinne,
Not sure what airplane you are describing but it certainly is not a characteristic any of Homer's designs I am familiar with.
If you are terrified by the stall characteristic of the Kolb planes I'd strongly suggest you either never park your butt in another airplane, or have an experienced pilot take you up to altitude in most any plane other than a kolb, and do an intentional stall to recalibrate your meter for "terrified".
Gene Z
zeprep251(at)aol.com
PostPosted: Sat Mar 31, 2012 12:20 pm    Post subject: Kolb quit revealed Reply with quote
If you have had the opportunity to fly a Kolb model with vg's and the same Kolb model without vg's, all the way through it's speed range including a full stall,you will have formed a very definite opinion about their worth on this designed wing.
G.AmanMK3C
byoungplumbing(at)gmail.c
PostPosted: Sat Mar 31, 2012 4:18 pm    Post subject: Kolb quit revealed Reply with quote
ok folks,,,,, I had time this afternoon to do some research,,,, I found this on the Kolb web sight, frequently asked questions page. http://www.kolbaircraft.com/faqs.htm I should have done the search before I posted the last question.
I don't know how this was determined... maybe if Dennis Souder is around maybe he could comment.
anyway if the statement by Kolb is correct the entire wing wont stall at once.
boyd young
mkii
utah
quote
"It does not look like there is any twist in your wings, are you sure that is okay?
You are correct. Our wings are completely flat on the bottom. Twist is used to ensure that the root of the wing will stall before the wing tip. If the wing tip were to stall first, the airplane would be very dangerous to fly. Our wings are low aspect ratio which means they do not have a very long span for their cord; low aspect ratio wings have very good stall characteristics, the root will stall before the wing tips do. In addition, the rectangular plan form that we use is less prone to tip stalling than a tapered wing. So, for our design wings, twist is totally unnecessary, plus it makes building the wings much easier." end quote
PostPosted: Sat Mar 31, 2012 6:55 pm    Post subject: Kolb quit revealed Reply with quote
Gene Z
Gene Z/Folks:
Don't think Russ K has near as much time in a Kolb as Gene Z does.
To me, a Kolb, all models, stall just the opposite of a Cessna 152, etc.
Lots of Kolb pilots get in trouble because of this gentle stall
characteristic. They get themselves into a mush/stall, the aircraft remains
in a level attitude, and the pilot does not realize he is stalling. That's
a pretty gentle stall in my book.
In ground effect, the Kolb stalls and drops, just like it does at altitude.
Only difference is the Kolb smacks the ground in ground effect.
Stalling a Kolb from a couple feet in ground effect will not put the nose in
the ground and will probably not kill you, at least in the US. Maybe in GB.
Wink
PostPosted: Sat Mar 31, 2012 7:01 pm    Post subject: Kolb quit revealed Reply with quote
Kolb model without vg's, all the way through its speed range including a
full stall, you will have formed a very definite opinion about their worth
G.AmanMK3C
I have been fortunate to have done that. The difference with and without
VG's was negligible.
There was an improvement in softening a full stall three point landing if I
initiated one a little high.
PostPosted: Sat Mar 31, 2012 7:47 pm    Post subject: Kolb quit revealed Reply with quote
confirm.
Jerry King
Mr. Steve Whitman shared with me at Sun and Fun 1993, to cut my pitot tube
at a 45 degree angle to improve ASI accuracy at high angles of attack. This
came out during a discussion of how to improve accuracy of static pressure.
I asked him, initially, what type static system he used in his aircraft. He
told me he used nothing. His static port was the static port on the rear of
the ASI. Told me the stall speed was going to indicate the same whether
accurate or not.
PostPosted: Sun Apr 01, 2012 4:52 am    Post subject: Kolb quit revealed Reply with quote
Maybe in GB.Wink
John,
the gravity is MUCH stronger over here.Bent undercarriage at least.And of
course it depends on the pilots reaction. In your case with thousands of
hours the reaction is keep the stick back and give a burst of power. Thats
it. A tyro will probably do what he has been taught to do when the airspeed
falls Push the stick forward. He dives smartly into the ground.
The trouble with this entire question is that there are so many variables.
Firstly. I reckon that no two Kolbs whether kit or factory built are EXACTLY
the same. Even in the unlikely event of everything during the building being
done precisely the same with every angle exactly similar no two planes have
the same colour scheme so there is at once a variation in weight and
balance.
The pilots are all different. They arrange their cockpits differently.Some
have minimal instrumentation. Some look like 747`s.
Normally this makes no difference but we are trying to carry out an EXACT
test or comparison.
So the base line for all other measurements is flawed.
Secondly. The sort of test we are trying to do is being carried out in
`real` conditions. Variable wind, variable approach angle, variable speeds,
(as no ones ASI is the same)
The sort of testing which we are doing under field conditions can only
properly be carried out in a wind tunnel. We just cannot expect to produce
results with spittin` distance of each other
The `Kolb quit` means nothing really. It is just a nice alliterative phrase
to describe something we have all experienced. Its a stall. At 500ft you
ease the stick forward and it goes away. Do that at 5ft and it catches you
out. Thats Kolb Quit`
I hope no one produces an answer that irrevocably solves all this. What
should we talk about?
Cheers
Pat
beauford
PostPosted: Sun Apr 01, 2012 5:16 am    Post subject: Kolb quit revealed Reply with quote
racerjerry
PostPosted: Sun Apr 01, 2012 6:36 am    Post subject: Re: Kolb quit revealed Reply with quote
“Mr. Steve Whitman shared with me at Sun and Fun 1993, to cut my pitot tube at a 45 degree angle to improve ASI accuracy at high angles of attack...�
Now THAT is interesting, and makes sense too. A straight cut pitot tube would present less ram area to incoming air at any angle other than straight ahead; circle turns into an ellipse with increased vertical dimension at higher angles of attack. With an angle cut pitot tube, the same area is presented in level flight; but at higher angles of attack, increased area is presented to incoming air (angle cut with longest portion of tube at top).
John, thank you for sharing.
Jerry King
PostPosted: Sun Apr 01, 2012 6:53 am    Post subject: Kolb quit revealed Reply with quote
Well John,
We agree on Most things.
G.Aman
PostPosted: Sun Apr 01, 2012 9:15 am    Post subject: Kolb quit revealed Reply with quote
..Seafoam...?
Seafoam?. What is that? I have never heard of it. Please tell me all about
it.
racerjerry
PostPosted: Mon Apr 02, 2012 6:23 am    Post subject: Re: Kolb quit revealed Reply with quote
…Seafoam? That is something you get when you pee into the surf.
Jerry King
Page 2 of 2
