Mike Whisky
Posted: Thu Apr 05, 2012 3:36 am Post subject: Exhaust installation plan |
Hi,
I can´t find the handwritten exhaust installation plans from Vetterman. Could someone please post them as pdf? I installed them from what I remember seeing but I can´t get them fit close enough to the belly and to the gear to not inter fear with the bottom cowling. Installation pictures are welcome as well.
Michael
_________________ RV-10 builder (flying)
#511 |
rv10flyer
Posted: Thu Apr 05, 2012 7:36 am Post subject: Re: Exhaust installation plan |
You will need to cut a half moon shape out in lower cowl to provide 1/2" clearance. No more than that is needed due to large amount of cooling air at high power settings.
_________________ Wayne G. |
Jim Berry
Posted: Thu Apr 05, 2012 9:35 am Post subject: Re: Exhaust installation plan |
I did not need to cut the lower cowl to get clearance, but it did take a fair amount of fiddling with the exhaust hangers to get it right. I would not cut the cowl except as a last resort.
Jim Berry
N15JB
Mike Whisky
Posted: Thu Apr 05, 2012 10:16 am Post subject: Re: Exhaust installation plan |
I agree Jim,
could someone please send me a scan of the plan though because the way I did mount it, it does´t really fit.
Mike
| Jim Berry wrote: | I did not need to cut the lower cowl to get clearance, but it did take a fair amount of fiddling with the exhaust hangers to get it right. I would not cut the cowl except as a last resort.
Jim Berry
N15JB |
#511 |
davidsoutpost(at)comcast. Guest
Posted: Thu Apr 05, 2012 2:20 pm Post subject: Exhaust installation plan |
I trimmed my cowl per plans and there is plenty of clearance for the pipes.
David Clifford
RV-10 Builder
Howell, MI
Sent: Thursday, April 5, 2012 2:16:55 PM
Subject: Re: Exhaust installation plan
--> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net>
I agree Jim,
Mike
Jim Berry wrote:
| Quote: | I did not need to cut the lower cowl to get clearance, but it did take a fair amount of fiddling with the exhaust hangers to get it right. I would not cut the cowl except as a last resort.
Jim Berry
N15JB
RV-10 builder (interior & finishing)
#511
http://forums.matronics.com/viewtopic.php?p=370115#370115
toaster73(at)embarqmail.c Guest
Mike Whisky
Posted: Thu Apr 05, 2012 9:29 pm Post subject: Re: Exhaust installation plan |
Thanks Chris,
This is exactly what I needed!
It looks as if I'll have to cut back my breather tube a bit as it is in the way of the exhaust pipe.
Michael
#511 |
jchang10
Mike Whisky
Posted: Sun Apr 08, 2012 4:20 am Post subject: Re: Exhaust installation plan |
Ok the right right muffler is mounted an it worked out perfectly.
However the left one doesn't work at all because the metal muffler bracing either is not wide enough when bent to achieve the necessary height to keep the exhaust pipe up. Or it interferes with the heating duct.
Not sure if I am the only one with this issue and what is wrong.
Any ideas anyone.
Mike
#511 |
Posted: Sun Apr 08, 2012 4:57 am Post subject: Exhaust installation plan |
Yep - same problem with my left side.
I ended up cutting the lower hanger bolt (the one on the end of the cable) and snugging up the brackets such that I had the shortest overall length between the bent hanger and the exhaust attach point. Cutting the lower bolt is needed as the end hits the exhaust attach point long before you run out of threads. I also mounted the bent hanger as high as possible. Combined these solved the problem.
Carl
First engine start - next week.
On Apr 8, 2012, at 8:20 AM, "Mike Whisky" <rv-10(at)wellenzohn.net> wrote:
Any ideas anyone.
Mike
#511
http://forums.matronics.com/viewtopic.php?p=370276#370276
