rose9065f
Posted: Fri Apr 06, 2012 5:54 pm Post subject: smooth tires |
KF2, original tires 15 years old, smooth 20x7-8, not looking so good, so I am going to replace them. I looked up the old posts, atv tires, golf cart etc. Dumb question, why do I want smooth tires? What is the advantage, why not some type of tread?
Jim
KF2/582
Pahrump
_________________ KF2 582 |
rose9065f
Jim
KF2/582
Pahrump
redrocketrider
Joined: 13 May 2011 Posts: 67 Location: Nervino airport
Posted: Fri Apr 06, 2012 8:17 pm Post subject: smooth tires |
Depends on where you land......paved or dirt. knobby tires for dirt, smooth/tread on runway. You do not want knobby tires on a runway....We just replaced ours from knobby to regular tread much better landings The ship came with knobby tires!.......Bob KitFox 4/1200 Beckwourth, CA O02
Quote: | From: rez (rrr.cavu(at)yahoo.com)
Sent: Friday, April 06, 2012 6:53 PM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: smooth tires
Jim
KF2/582
Pahrump
Quote: |
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Description: |
 Download |
Filename: |
.vcf |
Filesize: |
72 Bytes |
Downloaded: |
711 Time(s) |
_________________ Keep the dirty side down/Blue skies. Bob |
KeysFox
Posted: Sat Apr 07, 2012 6:14 am Post subject: smooth tires |
smooth less likely to pick up stones and throw them into fabric
low inflation on stiff tread tire can cause rolling resistance on touch
down, tendency to swerve or pull to one side a bit
sand spurs can go thru thin skinned tires-cause lots of little slow leaks,
less likely with thicker tread type tires
pick what works for your situation
BJ
Kitfox IV 912
Quote: | Depends on where you land......paved or dirt. knobby tires for dirt,
of tread?
Jim
KF2/582
Pahrump
_________________ B Jones
N154K
443-480-1023 |
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Sat Apr 07, 2012 7:09 am Post subject: Re: smooth tires |
Would there really be any reason to use knobby tires? Other than a few treads for water to go through on wet pavement, it seems like like you'd want the smoothest tire for the most traction. I mean, since the wheels aren't actually driven by the engine, there is no need to have "gripping" treads. Knobby tires would serve no purpose other than adding drag, right?
_________________ Kitfox IV-1200
Indianapolis, IN |
dave
Posted: Sat Apr 07, 2012 9:09 am Post subject: Re: smooth tires |
just put on King fox and 8" wheels on a Raven - Kitfox clone........
Will put up a movie soon on my you tube channel
smooth is the way to go
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
brubakermal(at)yahoo.com Guest
Posted: Sat Apr 07, 2012 5:40 pm Post subject: smooth tires |
i got treaded tires for my 2 becouse they wher cheep. they wear off and i flip them over now ther almost tottly bald fter 5 years and no sign of thread showing. I land mostly on pavement.
o wore the king fox out in one summer had thread showing not a good thing on a 2 ply tire.
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Sent: Saturday, April 7, 2012 1:09 PM
Subject: Re: smooth tires
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
http://forums.matronics.com/viewtopic.php?p=370222#370222
Paul A. Franz, P.E.
Posted: Sun Apr 08, 2012 1:11 pm Post subject: smooth tires |
On Sat, April 7, 2012 7:13 am, bjones(at)dmv.com wrote:
That's a good point.
Quote: | sand spurs can go thru thin skinned tires-cause lots of little slow leaks,
If you have inner tubes then there is a very nice product called tuff-skins. They are
sold at bicycle shops. They absolutely prevent flats from sand burrs, cockle burrs and
bits of glass at the edge of roadways. They are very light and thin and have a
slightly sticky surface so you lay them in the inside of the tire in just the road
contact area and then the inflated inner tube holds them in place.
I think that ribbed tires are the best since they offer a slight resistance to
skidding and aid landing on wet runways. In my opinion knobbies are just extra weight
and air drag. They really pickup mud and splatter the bottom of the fuselage and even
the wings in muddy conditions. Even landing on fresh mowed grass with knobbies
splatters grass fragments that make green stains when the hit the aircraft.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
_________________ Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
rose9065f
Posted: Mon Apr 09, 2012 10:38 am Post subject: smooth tires |
Wet runways not a factor here in Pahrump, maybe four inches rain per year. I do land on asphalt at the home field, but also on dry lakes and sand.
Regarding traction though, I am not sure it is a good thing. The consensus seems to be that it is more difficult landing a KF on a hard surface than on grass or gravel. If I touch down a little cockeyed and those tires grab hold of the runway, then the back end wants to come around hard for another ground loop. If I do the same on gravel or grass, the mains may slip sideways a little, giving me a bit of time to get it straight.
Comments?
Jim
KF2/582
lcfitt(at)sbcglobal.net Guest
Posted: Mon Apr 09, 2012 12:27 pm Post subject: smooth tires |
Jim,
My understanding is similar to your comments. Traction is not necessarily a good thing with a tail wheel airplane on landing. But, since the Kitfox has had smooth tires from day one with lots of stories of ground loops, I doubt that the smooth tires help much in that regard on pavement. Sort of like the low pressure slicks on a dragster. Another thought on traction - not a good thing with heavy braking either as it is not too difficult to nose over. I have lifted the tail a time or two with the brakes. Then again, it is probably better to have the brakes being the weak spot and slipping rather than the wheels slipping against the pavement when braking.
Lowell
Sent: Monday, April 09, 2012 11:37 AM
Comments?
Jim
KF2/582
