klehman(at)albedo.net Guest
Posted: Fri Apr 13, 2012 3:38 pm Post subject: Open source product development for OBAM aircraft |
Another option is a $20. Atmel Butterfly demo board from digi-key. It is
based on the Atmel 169 and has many on board capabilities to grow into.
For example I use a Butterfly to monitor amphib gear position, hydraulic
pressure, engine rpm and to trigger appropriate voice alerts. It also
integrates EFI pulses and displays fuel flow and fuel remaining for me
on its aphanumeric LCD display. Not bad for $20. of hardware. The
butterfly comes with a 3 volt coin cell or it accepts external power and
it also just needs a serial (RS232) cable to program it.
Ken
On 13/04/2012 4:45 PM, Daniel Hooper wrote:
Quote: |
Hooper<enginerdy(at)gmail.com>
Yes, check out this fairly minimal implementation here:
http://arduino.cc/en/uploads/Main/Arduino-Pro-schematic.pdf
U2 is the 3.3v or 5v regulator, depending on the board variant, and
the odd-looking 0.1uF cap (C2) coupled to DTR allows the serial
dongle to reset the chip. This makes programming the Arduino simpler
with many of the USB<->serial TTL converters out there. (the chip
must be reset to enter the bootloader, and if it times out before
programming begins, it will not work. This allows the Arduino IDE to
enter the bootloader/programming mode without requiring the user to
press reset)
Additionally, following the 'FTDI Basic' header convention at JP5
gives you several options for plug-and-play arduino programmers.
(Make sure you pick the right one, either 3.3v or 5v!) And don't
forget the ISP port JP3 so you can load the Arduino bootloader, or
alternately load programs with AVR Studio and an AVR ISP device,
without taking the chip out of the board.
Overall, making an Arduino clone should be pretty straightforward.
--Daniel
On Apr 13, 2012, at 1:49 PM, gregmchugh wrote:
> Can a generic AVR chip be made Arduino compatible with the download
> of the Arduino Loader onto the chip?
> Greg McHugh
retasker(at)optonline.net Guest
Posted: Sat Apr 14, 2012 1:20 pm Post subject: Open source product development for OBAM aircraft |
Uh, no... REAL programmers program in machine code or at worst assembly...
Jeff Luckey wrote:
Bob,
Your assessment of the Picaxe is right on. They are great for
beginners/simple/low performance devices but their interpreter is at least a
couple of orders of magnitude slower than devices programmed w/ a compiler.
There is a myriad of experimental aviation applications where that level of
performance would be adequate.
Several years ago when I first started programming uControllers, I examined
PICAXE& Parallax Stamps. I settled on the Stamps (They also have built-in
interpreters). They are great for getting up and running simply& quickly,
which is key for the initial learning curve, but I quickly outgrew them.
As I'm sure you are aware the standard in BASIC programming w/ PICs is
microEngineering Labs PICBASIC PRO Compiler. It is a great product and
reasonably priced at $120-$270. I know several people who use& really like
it.
And, of course, Real Programmers program uCons in C
-Jeff
ainut(at)knology.net Guest
Posted: Sat Apr 14, 2012 7:09 pm Post subject: Open source product development for OBAM aircraft |
Arghhhh.....
REAL programmers cannot program complex notions in machine (toggle switches!) or
assembler. It is simply too hard. It is hard enough to do in third generation
languages like 'C' or 'Fortran' or Basic or Pascal or ... Even as long ago as
the 1980's, real world tests showed that compilers had gotten so good that
executables were better by all metrics when written in a higher level language
than in assembler.
I have written in assembler and even (once) did the toggle thing on a PDP-11.
Once the translators are written (compilers), let the computer do the donkey work
that they're good at and let the people work at the conceptual levels, which they
are good at.
In some environments, the slow speed of interpreter execution is still good
enough, as you've said.
What the world still needs is a good fourth or fifth generation language but that
is REALLY hard to build and build well. In the database world, we had a product
that used relational calculus (high level programming) instead of relational
algebra (clunky SQL). The product was called ZIM by Zanthe Information Systems
out of Canada at the time. Extremely powerful language that even CEO's could use
to query their information. Sadly, it never caught on in the marketplace. There
are some current attempts at 4th and 5th G languages but they are still in their
infancy after 40 years of trying.
David M.
On Sat 04/14/12 4:16 PM , "Richard E. Tasker" retasker(at)optonline.net sent:
er(at)optonline.net>
Jeff Luckey wrote:
Luckey"JLuckey(at)p
acbell.net>>
> Bob,
are great for> beginners/simple/low performance devices but their
interpreter is at least a> couple of orders of magnitude slower than devices
programmed w/ a compiler.>
applications where that level of> performance would be adequate.
uControllers, I examined> PICAXE& Parallax Stamps. I settled on the Stamps
(They also have built-in> interpreters). They are great for getting up and
running simply& quickly,> which is key for the initial learning curve, but I
quickly outgrew them.>
programming w/ PICs is> microEngineering Labs PICBASIC PRO Compiler. It is
a great product and> reasonably priced at $120-$270. I know several
people who use& really like> it.
> -Jeff
henador_titzoff(at)yahoo. Guest
Posted: Sun Apr 15, 2012 4:56 am Post subject: Open source product development for OBAM aircraft |
I agree with David wholeheartedly but would like to add one more simple comment. Real programmers these days do not program because they're out of work. While machine code is efficient, real programmers are inefficient. They can do only the simplest of tasks, and even a programmer using Basic will outrun him and leave him in the dust. Guess which one will get the job done? The days of writing machine code are over except for the simplest tasks that somehow need specialized hand tweaking.
So if you know any machine code real programmers, they're probably bag boys at your local supermarket because they can't get a job. The rest are either in the ground or on display at your local dinosaur museum.
Henador Titzoff
Sent: Saturday, April 14, 2012 11:07 PM
Subject: Re: Re: Open source product development for OBAM aircraft
--> AeroElectric-List message posted by: David <ainut(at)knology.net (ainut(at)knology.net)>
Arghhhh.....
than in assembler.
are good at.
David M.
On Sat 04/14/12 4:16 PM , "Richard E. Tasker" retasker(at)optonline.net (retasker(at)optonline.net) sent:
[quote] --> AeroElectric-List message posted by: "Richard E. Tasker" retask
er(at)optonline.net (er(at)optonline.net)>
Jeff Luckey wrote:
> --> AeroElectric-List message posted by: "Jeff
Luckey"JLuckey(at)p
acbell.net>>
> Bob,
> -Jeff
Posted: Sun Apr 15, 2012 4:00 pm Post subject: Open source product development for OBAM aircraft |
My comment on "real programmers" was merely a response to the comment that "real programmers program uCons in C".
In fact, real programmers program in either what they are told to use for the particular project. Or, if they work for an intelligent company, they program in whatever gets the job done most
efficiently and the definition of that depends on what the constraints are. If there is plenty of memory to store the program, then any language will work. If the program storage is limited, then
what language one chooses is also limited.
Do not archive.
Henador Titzoff wrote:
[quote] I agree with David wholeheartedly but would like to add one more simple comment. Real programmers these days do not program because they're out of work. While machine code is efficient, real
dinosaur museum.
Henador Titzoff
*To:* aeroelectric-list(at)matronics.com
*Sent:* Saturday, April 14, 2012 11:07 PM
*Subject:* Re: Re: Open source product development for OBAM aircraft
Arghhhh.....
than in assembler.
are good at.
David M.
On Sat 04/14/12 4:16 PM , "Richard E. Tasker" retasker(at)optonline.net <mailto:retasker(at)optonline.net> sent:
> er(at)optonline.net <mailto:er(at)optonline.net>>
> do not archive
> Jeff Luckey wrote:
> Luckey"JLuckey(at)p
> acbell.net>>
> > Bob,
> > -Jeff
Posted: Sun Apr 15, 2012 10:24 pm Post subject: Open source product development for OBAM aircraft |
I will stick my neck out and say that real programmers (aka software engineers)
tell the company what language to use.
David
On Sun 04/15/12 6:53 PM , "Richard E. Tasker" retasker(at)optonline.net sent:
program in whatever gets the job done most efficiently and the definition of
Quote: | If there is plenty of memory to store the program, then any language will
work. If the program storage is limited, then what language one chooses is
also limited.
Quote: |
Do not archive.
simplest tasks that somehow need specialized hand tweaking.>
> dinosaur museum.
> Henador Titzoff
--------------------------------------------------> *From:* David ainut(at)knolo
gy.net>> *To:* aeroelectric-list(at)matronics.com> *Sent:* Saturday, April 14,
2012 11:07
Quote: | PM> *Subject:* Re: Re: Open source
product development for OBAM aircraft>
ainut(at)knolo
gy.net>>>
> Arghhhh.....
machine (toggle switches!) or> assembler. It is simply too hard. It is hard
enough to do in third generation> languages like 'C' or 'Fortran' or Basic or
Pascal
Quote: | or ... Even as long ago as> the 1980's, real world tests showed that compilers
had gotten so good that> executables were better by all metrics when written
in a higher level language> than in assembler.
toggle thing on a PDP-11.> Once the translators are written (compilers), let
the computer do the donkey work> that they're good at and let the people work
at the
execution is still good> enough, as you've said.
fifth generation language but that> is REALLY hard to build and build well. In the
database world, we had a product> that used relational calculus (high level
programming) instead of relational> algebra (clunky SQL). The product was
called ZIM
Quote: | by Zanthe Information Systems> out of Canada at the time. Extremely powerful
language that even CEO's could use> to query their information. Sadly, it
never caught
[quote] on in the marketplace. There> are some current attempts at 4th and 5th G
languages but they are still in their> infancy after 40 years of trying.
> David M.
retasker(at)optonline.net retask
er(at)optonline.net> sent:> >
E. Tasker" retask> > er(at)optonline.net er(at)optonline
.net>>> > Uh, no... REAL programmers program in machine
code or at worst assembly...> >
> > do not archive
> > Jeff Luckey wrote:
"Jeff> > Luckey"JLuckey(at)p
> > acbell.net>>
> > > Bob,
They> > are great for> beginners/simple/low performance
devices but their> > interpreter is at least a> couple of orders of
magnitude slower than devices> > programmed w/ a compiler.>
aviation> > applications where that level of> performance
would be adequate.> > >
programming> > uControllers, I examined> PICAXE& Parallax
Stamps. I settled on the Stamps> > (They also have built-in> interpreters). They
are great for getting up and> > running simply& quickly,> which is key for the
initial learning curve, but I> > quickly outgrew them.>
BASIC> > programming w/ PICs is> microEngineering Labs
PICBASIC PRO Compiler. It is> > a great product and> reasonably priced at
$120-$270. I know several> > people who use& really like> it.
in C> > >
> > > -Jeff
Eric M. Jones
Posted: Tue Apr 17, 2012 4:40 am Post subject: Re: Open source product development for OBAM aircraft |
Tip:
As in most cool electro-parts, "Deal Extreme" has Arduino (and other) parts and a vast selection of extremely cheap accessories for wanna-be-programmers. Cheap cheap cheap. And free shipping.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Tue Apr 17, 2012 7:04 pm Post subject: Open source product development for OBAM aircraft |
I don't know what you use for board layout, but if you use something like Eagle from http://www.cadsoftusa.com/ the layout connections will always agree with the schematic since they are linked.
They have a freeware version that is complete and only limited by the layers (2 allowed) and the board size (100 x 80 mm) - neither of which is a limit to most of us. If you pay $69 you can use the
same program to make boards that you can sell. There are other levels that allows progressively more (up to 16 layers and 4m x 4m size).
I use it at home for home projects and we have one of the professional multi-user copies at my business.
Highly recommended!
Dick Tasker
Quote: |
The ECB layout is done. I'll put it down for a few
hours and then 'proof' it against the schematic.
I'll publish the ECB layout and schematic as soon
as I've confirmed their agreement.
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Eric M. Jones
Posted: Wed Apr 18, 2012 4:15 am Post subject: Re: Open source product development for OBAM aircraft |
Quote: | I don't know what you use for board layout, but if you use something like Eagle from http://www.cadsoftusa.com/ the layout connections will always agree with the schematic since they are linked. |
I love Eagle and have used it extensively. Express PCB is better for my purposes now (my average PCB is under one-square inch). Furthermore Express PCB's learning curve is almost ZERO. You can be set up and using it in minutes. Please note: Express PCB's schematic program is also linked to the PCB.
113 Brentwood Drive
(508) 764-2072
Posted: Wed Apr 18, 2012 6:45 pm Post subject: Open source product development for OBAM aircraft |
I will answer and comment to all the previous inquiries.
S. Ramirez: Eagle has schematic capture that, in my opinion, is very good. I have not used one of the PADS suites in many years so I cannot really comment on how it compares. Eagle does have
schematic capture that is linked to the board layout. It has an auto-router that seems to be pretty good if you want to use it. I don't use it myself. You can download a free copy and try it out
for yourself. It is pretty easy to learn.
Bob N.: I too started with the same stuff you mention. Doing layouts on a drafting board at 5:1 and flipping translucent sheets to make multilayer boards - the "good old days". I don't use the
auto-router in Eagle myself, although it is there if one wants it. I would really recommend you download a copy of the Eagle freeware and check it out. It is really easy to use and definitely helps
with the final checkouts to make sure you didn't miss anything and that you haven't done anything stupid. I do the boards I design just like you describe, except I enter the schematic first and then
switch to the board where all the parts are waiting for me to place wherever I want them. Then auto-route if you want or manually rout if you prefer (I prefer). Don't know if it will work, but I
have attached a copy of one of our schematics so you can see what it looks like. If you don't like what it looks it, you can make and add your own symbols for anything to the library and use them
instead.
Eric: Express PCB is also very good. The only disadvantage is that it is linked to the particular board supplier - which is fine as long as that is who you want to deal with. With Eagle you can use
the Gerber files it generates with any board supplier.
Dick Tasker
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=371144#371144
Please Note:
Description: |
 Download |
Filename: |
Voltage_Output.pdf |
Filesize: |
42.67 KB |
Downloaded: |
363 Time(s) |
Eric M. Jones
Posted: Thu Apr 19, 2012 5:12 am Post subject: Re: Open source product development for OBAM aircraft |
Quote: | Eric: Express PCB is also very good. The only disadvantage is that it is linked to the particular board supplier - which is fine as long as that is who you want to deal with. With Eagle you can use
the Gerber files it generates with any board supplier. |
Dick, ExpressPCB is full of surprises. They will send you the Gerber Files for a small fee after the first run, I believe. (Check with them for the most recent policy). Their mini-board service also expands to almost anything else you want, other sizes, two or four layers, other quantities, for competitive prices. They also don't quibble about the number of boards you put on one sheet, although they have a limit of 350 holes per sheet on their standard 3-PCB mini-board service (...and I bump up against the hole-limit all the time!).
ps: Don't confuse the original "Express PCB" with the copycat "PCB Express".
113 Brentwood Drive
(508) 764-2072
