mrspudandcompany(at)veriz Guest
Posted: Wed Apr 18, 2012 1:12 pm Post subject: Red Dot SWR Meter |
Thanks much for procuring and testing the Red Dot SWR meter. I will put it
to use testing my installed antennas mounted inside my wooden aircraft. No
doubt, there will be questions how best to do these tests, and what are
acceptable parameters.
Have you published the results of your testing of this meter with your
reference?
Roger
 Download |
| Filename: |
winmail.dat |
3.45 KB |
| Downloaded: |
407 Time(s) |
Posted: Sat Apr 21, 2012 3:43 am Post subject: Red Dot SWR Meter |
During a previous discussion on this forum, we were kicking around the
relative use and accuracy of the small Red Dot SWR meter. You purchased one
and performed some comparison tests with your lab equipment. I purchased
this unit from you, at a good price, I might add, and will be using it
shortly to test the built in antennas in my nearly completed wooden
airplane.
reference? It would be interesting to note the actual tested accuracy of
this device.
Roger
 Download |
| Filename: |
winmail.dat |
3.83 KB |
| Downloaded: |
409 Time(s) |
Posted: Sat Apr 21, 2012 4:53 am Post subject: Red Dot SWR Meter |
At 06:40 AM 4/21/2012, you wrote:
airplane.
this device.
I did a mini-review here on the List when the
unit I ordered arrived. I don't recall the exact
details but I was favorably impressed with its
performance as compared to the Bird and Measurements
Corp instruments I have here.
Nothing real quantitative. I recall that there were
differences at some frequencies and power levels on
the order of 10% . . . but in the field of RF power
measurement tolerances of plus or minus 10% is
pretty good.
I'm still hoping that I have a chance to participate
in some activities that will take me back inside the
walls of NIAR at WSU. If this happens, I think I can
get access to the EMC labs for a quick looksee at
the HID lamp assemblies on my bench for conducted
and radiated emissions. If those programs spool up,
I'll pick up another Red Dot to evaluate over a wider
range of frequencies and power levels than I can
generate here.
Given the instruments compact size and relative
robustness of enclosure and inspection of
the interior, I think the Red Dot SWR meter is a
great value.
