bill_dom(at)yahoo.com Guest
Posted: Sun May 28, 2006 1:31 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
I have all my rudder parts built as per plans. I did a
test fit clamping the ribs to the spar and rib #7 and
#8 (6T4-7 and 6T4- are narrower right where it meet
the spar. My rudder spar is within .5 millimeter
accurate from top to bottom. According to the plans,
rib #2 is 340 mm and #3 is 590 mm from the beginning
of the doublers, that are 30 mm extended from the
bottom of the spar.
The width of the spar at the point where rib #2 should
be located is 91 mm however, the plans call for rib #2
to be 88 mm in its wide side (projected). Im getting
exactly 1.5 mm difference in each side between the
flange of rib #2 and the flange of the spar. For rib
#3 the difference is 2 mm in each side. I presented a
piece of .016 skin and this difference would be
noticeable. My rudder spar flange has the correct
angle. I even presented the ribs in a drawing template
of the spar that is 100% accurate with the plans
dimensions and still getting this difference.
If I slide up the ribs to the point where they fit
correctly, #2 would have moved 35 mm and #3 would have
moved 80 mm.
I searched the archives and no one has had this
problem so I dont know what to do. It seems that I
might misinterpreted the plans but I cant see where.
I have measured my parts several times and they are
accurate with the plans.
Any thoughts?
William Dominguez
Plansbuilt Zodiac 601XL
Working on the rudder
Afterfxllc(at)aol.com Guest
Posted: Sun May 28, 2006 1:52 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
did you extend your doublers behond the spar by 30 mm? If not that is your
problem.
Posted: Sun May 28, 2006 2:07 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
William,
You might shim your form a bit and stretch out the rib width or consider
shims. It's not uncommon to
have to add shims between rib and skins to get perfect skin alignments.
In your case, the difference could
be had by reforming your ribs a little. Better to reform than shim if
it's possible.
Larry McFarland - 601HDS at www.macsmachine.com
William Dominguez wrote:
bottom of the spar.
moved 80 mm.
Any thoughts?
William Dominguez
Posted: Sun May 28, 2006 3:05 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
Yes.
William Dominguez
Thanks. What do you mean by reforming?
By shim, do you mean adding material as spacer?
William Dominguez
--- LarryMcFarland <larry(at)macsmachine.com> wrote:
William,
reform than shim if
it's possible.
Dominguez <bill_dom(at)yahoo.com>
did a
and
meet
plans,
beginning
>bottom of the spar.
should
#2
getting
rib
a
template
have
>moved 80 mm.
where.
>Any thoughts?
>William Dominguez
browse
Subscriptions page,
FAQ,
Admin.
Posted: Sun May 28, 2006 4:06 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
William,
If you've got the forms you used to bend the rib/flanges, you could re
cut the form and spread the rib
outward some and re-bend the rib to pick up the 1.5mm. Or you could
just remake the ribs with new
forms. You're only talking small parts and an hour and a half at most.
I misspoke on the shims because
the skin material is too thin to accept the shift from shim to rib
flange. I have 3 shims on my center section
ribs that are tapered to nothing to gain precise support and alignment
of the skin from rib to rib, but the
skins are thicker.
Larry McFarland
William Dominguez
>William,
>reform than shim if
>it's possible.
admin(at)arachnidrobotics Guest
Posted: Sun May 28, 2006 4:53 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
You must come from the same type of fabrication background I did William. I made the exact same mistake you did when I first began my project.
The 88mm dimension on Rib #2 is NOT the width of the rib. It's the width of the rib's FORMING BLOCK. If you add two materials (roughly 0.8 mm) and account for spring-back during forming you will end up with a 91mm wide rib, or very nearly so. As I formed these on a CNC brake, the forming block dimension didn't even register in my head. I have since added 1.5 mm to each dimension when omitting the forming blocks. Everything has fit well since then.
I sent an email to Zenith months ago regarding this very subject. I was informed that many of the dimensions are to the limits of the forming blocks, and not the parts themselves. I find this to be very in-exact and confusing at times, but manageable.
It would pay DOUBLE my plans price to receive fully dimensioned prints from Zenith with the FINISHED dimensions depicted. When I began laying out the parts in Solidworks (3D CAD) to throw at the CNC punches and lasers, I had no end of compounding calculations to arrive at the finished product.
I'm hoping one day that Chris at Zenith actually reads some of these posts and shells out the $ for a professional to re-work the drawings. Heck, I'd offer mine if I thought he'd take them. lol Anyway, I hope this helped you.
bottom of the spar.
moved 80 mm.
Any thoughts?
William Dominguez
Posted: Sun May 28, 2006 5:39 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
Thanks. My forming block is 88mm. But I used the
bending brake only to pre-bend the part, then I used
the mallet to complete the bend and the part came up
just a fraction of millimeter bigger than the forming
block.
block.
Right now Im leaning toward remaking the parts
completely using new forming blocks with the right
dimensions.
William Dominguez
--- Tom and Bren Henderson
<admin(at)arachnidrobotics.com> wrote:
Henderson <admin(at)arachnidrobotics.com>
then.
manageable.
William Dominguez <bill_dom(at)yahoo.com> wrote: -->
Zenith-List message posted by: William Dominguez
a
and
meet
beginning
bottom of the spar.
should
#2
a
template
have
moved 80 mm.
Any thoughts?
William Dominguez
browse
Subscriptions page,
FAQ,
Admin.
hewettproperties(at)cox.n Guest
Posted: Sun May 28, 2006 7:42 pm Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
Did you build the spar closed 5.5 degrees?
taffy0687(at)yahoo.com Guest
Posted: Mon May 29, 2006 5:44 am Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
William-- with the aft rudder ribs, I found it much easier to do the complete bend on the bending brake as they have straight edges and not bother to build the forming blocks. ( it might be necessary to "tweak" the narrow edge (10 mm) with the hand seamer pliers.
Fritz-- Corvair
block.
block.
dimensions.
William Dominguez
wrote:
Henderson
then.
manageable.
William Dominguez wrote: -->
a
and
meet
beginning
bottom of the spar.
should
#2
a
template
have
moved 80 mm.
Any thoughts?
William Dominguez
browse
Subscriptions page,
FAQ,
Admin.
Everyone is raving about the all-new Yahoo! Mail Beta.
Posted: Mon May 29, 2006 7:10 am Post subject: Rudder Rib #7 and #8 Underfitting in Spar |
Yes.
William Dominguez
Plansbuilt 601XL
--- Hewett Properties <hewettproperties(at)cox.net>
wrote:
Properties" <hewettproperties(at)cox.net>
