Battery location
steve.freeman(at)syntaxds
PostPosted: Mon Apr 23, 2012 10:59 am    Post subject: Battery location Reply with quote
Hi List –
Anyone out there who might be building a 601XL or 650 using a Lycoming 0235 engine…Where are you putting your battery and what kind are you using? I know this engine is heavier than a lot of other solutions so I am concerned about the forward C/G and have no idea how to figure that BEFORE the airplane is complete.
Any help or advice is certainly appreciated.
Steve Freeman
jaybannist(at)cs.com
PostPosted: Mon Apr 23, 2012 11:31 am    Post subject: Battery location Reply with quote
Steve,
My 601XL has a Corvair engine. I mounted the battery, along with the battery contactor and battery bus (fuse block) behind the passenger side seat. (see photo). I later moved the fuse block to the floor to make it more accessible.
Jay
 Filesize:  204.29 KB
 Viewed:  5752 Time(s)
JohnDRead(at)aol.com
PostPosted: Mon Apr 23, 2012 1:25 pm    Post subject: Battery location Reply with quote
Hi Steve,
 Have you tried calling the Zenith factory? I am told that Caleb has a spreadsheet that positions battery versus engine type and weight.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
Joe(at)hambrothers.com
PostPosted: Tue Apr 24, 2012 7:21 am    Post subject: Battery location Reply with quote
steve i have the same engine in 601xlb my battery is 4" from 6b1-1
i can move
up to 6to8" foward i have not flown yet wt & balance checed good.
have air worthenes cert.working on byanual.
PostPosted: Tue Apr 24, 2012 8:05 am    Post subject: Battery location Reply with quote
Hi Joe,
If I am not mistaken this puts your battery 4” in front of the Front HT Frame. I have never seen a battery this far back. Did you also install an access door so you can get to the batter for service? Can you describe how you get your cables to the front and where are you grounding the negative terminal?
Also – what kind of battery do you have and how much does it weigh?
Thanks for responding,
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Joe
Sent: Tuesday, April 24, 2012 8:20 AM
Subject: Re: Battery location
i can move
PostPosted: Thu Apr 26, 2012 7:31 am    Post subject: Battery location Reply with quote
i,m using a power sonic battery # ps 12350
have an access just below and a little foward of the elavator
grounded to door frame ran the wire through a plastic tube mtd
under neath 6b164 battery wt 25 lb,s
mtherr(at)yahoo.com
PostPosted: Thu Apr 26, 2012 8:18 am    Post subject: Battery location Reply with quote
What wiring gauge do you use? 2awg? 4awg?Sent from my BlackBerry device on the Rogers Wireless Network
Sender: owner-zenith-list-server(at)matronics.com
Date: Thu, 26 Apr 2012 11:29:23 -0400
To: <zenith-list(at)matronics.com>
ReplyTo: zenith-list(at)matronics.com
Subject: Re: Zenith-List: Battery location
i,m using  a power sonic battery # = ps=20 12350
 have an access just below and a = little foward=20 of the elavator
grounded to door frame ran the wire = through a=20 plastic tube mtd
under neath 6b164  battery wt 25=20 lb,s
